Question about Hoover Dryers
Does anyone have a Manual for Hoover Apollo 402 dryer? I just want to know how to use it properly.
  • 147 Answers
SOURCE: Needing Manual
do a search on googles for your model (include the word manual) and Ill bet many will come up. Most of the time you can get a operation manual at the company web site..
Posted on Sep 24, 2008
  • 30 Answers
SOURCE: not getting hot
Sounds like the heating element has broke. If it spins and doesnt produce heat its best to call someone out, or buy a new one. If nothing works, check fuses and connections
Posted on Apr 13, 2009
SOURCE: Hanging Hoover Apollo Deluxe dryer unit from the wall
you will need to get a wall mount bracket. I found a couple on ebay for about $30.
Posted on Dec 15, 2009
BarrettDenCo
  • 1772 Answers
SOURCE: My Hoover Apollo 401 dryer
their is no fuse, heater coil is defective, a common problem, or this is not common, over heat safety sensor has tripped
Posted on Dec 19, 2010
HansPP
  • 2510 Answers
SOURCE: How do I change the
Remove the top cover by removing the screws at the back of the machine and sliding the cover off forwards. Now you need to obtain access to the complete circumference of the drum to fit the belt. Depending on your machine you can either remove the front of the dryer, or release the rear bearing support so that you can slide the new belt over the drum and under the bearing retainer, which may entail removing the back cover as well. The belt then just slips over the motor pulley and you need to check on the belt tension, usually done by adjusting the motor or the tensioner.
Posted on Apr 28, 2011
Hoover apollo deluxe dryer
Can you give a model number?
Jan 30, 2014 | Dryers
Hoover apollo deluxe timer
Probably a new timer... Which will probably cost almost as much as a new machine
Dec 27, 2013 | Dryers
Hoover Clothes Dryer Apollo 100 D6176
Most electric dryer problems not heating are due to the heater coil circuit being broken. The wiring can be replaced by the coil kit being purchased from an appliance parts store. Need make and model numbers. Follow directions in package.
Oct 13, 2013 | Dryers
Sep 30, 2009 | Hoover Dryers
Hoover Apollo Delux not drying properly and takes ages. Outlet air is hot but my wife says it's not drying as well as it used to. The front filter is clean but is there an inlet filter that I'm overlooking...
T^o much lint in duct work, causing moisture and not allowing cloths to dry. Vacuum out duct work in dryer and from dryer to outside of home.
Jul 17, 2009 | Dryers
Hoover dryer Apollo 411
what is it you need? you make no mention of that.
Jun 20, 2009 | Hoover HDC7FM Dryer
Hoover 410 Apollo clothes dryer throws 10amp fuse
Thank you,
My machine problem was resolved by changing the heater element to one from an old machine.
Jun 18, 2009 | Hoover HDC7FM Dryer
Hoover Apollo Delux dryer
i dont think so , even if you could get the parts it would be quite tricky to fix without the proper tools and if you bought the tools they would cost more than a replacement dryer
Sep 20, 2008 | Master Appliance HAS011K Replacement...
Dryers Logo
172 people viewed this question
Top Hoover Dryers Experts
Tim Whalen
John Tripp
John Tripp
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
