Question about Behringer DJx700 5-Channel Pro DJ Mixer with Digital Effects & Bpm Counter
I have an operational problem.
I need an updated version of an operational manuals for a mixer console of various types.
    President:
  • 1,137 Answers
Here is Behringers website:http://www.behringer.com/EN/Support/ If you look at whatever model you want under products, the download link for the manual is usually on that page. For any other manufacturer, try typing the manufacture,model number and support or manual into Google or your search engine.
Posted on May 19, 2010
I need driver update to connect with pre sonus artist one software
If you use the Behringer ASIO drivers (available from their web site) it will connect just fine, you should also be able to use the sound card drivers that came with the computer as they should pick up on the mixer (assuming it is a USB version) but you do not say if you have a Mac, PC or what operating system you are running so it is impossible to be precise
Mar 15, 2016 | Behringer XENyX 1204 XENyX 1204 12 Channel...
Is there a reset button or a fuse on the stanton m 203 mixers ive lost power
Officially, there is no user servicable fuse, However- there is usually one in the wall wart, which you can check simply by using a voltmeter and sometimes there is one internally. soldered to a small powe buss type of board such as was the case wth an older version of that basic mixer I repaired a number of years ago..
If warranty is not an issue, open it up and check. Just make sure to get all the screws out as nothing needs to be forced apart to open it up- just lots of screws.
Dec 17, 2012 | Stanton M.303 3 Channel 10 Inch Dj Mixer
Help with hooking up a compressor for vocals.
The compressor is a really good idea and should be connected between your mixer and your amplifiers. Your "integrated" mixer/amp is a bit tricky in that you will have to "insert" the compressor in the signal path.
If you have the "console" model....
1. "Main 1 Out" left and right to the input of your compressor and the output of the compressor connected to the "PWR Amp Insert."
2. What is known as Tip, Ring, Sleeve patch cable and plug connected ONLY to the "PWR Amp Insert." This type connection breaks out into a "Input" and "Output" using a single 1/4 stereo plug.
If you have the "square box with knobs on front" model
1. "Main Output" to input of comressor and compressor outputs to "Input to Main" (aka "AUX IN").
Check your owners manual for hookup details or suggestions and remember, all outputs feed inputs and all inputs feed outputs.
Oct 29, 2012 | Behringer Music
Power mixer to a power amp.
You have two aux sends on that mixer so quite easy to use one of those to feed the external power amp. You could have one set of spkrs connected to that amp and another connected to the powered mixer. This would give you full independent control over each set.
Aug 09, 2012 | Samson Xm910 8Channel Powered Mixer...
My mixer wont power up. the only light that comes on is red led +48 v
This MAY be a power supply problem. We need to find if the power supply is putting out what it is supposed to. Using a meter, put one probe in pin 1 (ground) of one of the mic connectors, say channel1. Put the other probe in either pin 2 or 3 of another mic connector... Note we are using different connectors as there often isn't enough clearance for the probes in the same one... With Phantom power turned on and LED +48 lit, how much voltage do you read? If it is say 40 volts or more, then power supply is operating.
If the supply is operating then a POSSIBLE problem is a connector has fallen off where it connects to the supply or the main board.
The power supply provides several voltages such as 5 volts, 12 volts and 15 volts of various polarity.
If the 48 volt supply is found to be operating with the above test, then since the switcher and transformer are shared, it is likely the other voltages are available.
CAREFULLY open the unit and look for a loose cable.
PLEASE NOTE: This is a switching type power supply and part of the supply runs at power line potential. Only work on the supply if you are skilled and have an isolation transformer for your own safety.
Sep 21, 2010 | Behringer XENYX 2442FX Mixer
Hi everybody, please help me.
If you have the owners manual it explains it all. Page 71 tells you about the various options.
Jul 11, 2009 | Tascam 2488mkii 24 Track Recording...
Mixing headphone levels
More important than your keyboard for this question is the mixer you are using.
Put the metronome on a channel and only pot it up in an Aux send. Set up the mix for your phones using that same aux send. Use the main outs for PA.
That would be one way to do it. The idea is, you want to set up a mix for you, and a separate mix for everyone else. Mixers are capable of having several different mixes sent on their various outputs, so pick one to use for your headphones, and use a different set of outputs for the other mix.
A mixer does exactly that. It mixes. If you think of a graph, the X side would be your inputs, the Y side is your outputs. You can mix different versions of X at each Y.
May 25, 2009 | Yamaha Music
Behringer DJx700 5-Channel Pro DJ Mixer with Digital Effects & Bpm Counter Logo
147 people viewed this question
Top Behringer Music Experts
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
