WHO HAS THE ANSWER THE MANUFACTURE DOESN'T
I purchased a LG Home Theater system model LHT734. On the back of the receiver there is a connection for a wireless transmitter (DC 7V OUT). This wireless transmitter kit must be purchased separately. I called LG USA, they were no help. They only distribute and couldn't tell me the model number for the wireless transmitter kit. I called where I purchased the LG system and they say they don't know either. I need help in this if any one can lead me to a web site or store who sells it I would appreciate it. On the back of the speakers the is a connection for a screw in antenna, I'll need four antennas and one transmitter.
    Master:
  • 518 Answers
I see this one on their site, and it has a 7V DC input.
Is that what you're looking for?
Hope that fixed ya...
Geno
Posted on Mar 26, 2008
6ya staff
SOURCE:
I have the philips mcm530 micro system and want to tune in a wireless speaker to the system so I can take the speaker outside. Is that possible?
The philips only receives bt audio it doesn't transmit them. You need a wireless system that includes a receiver and transmitter. The transmitter needs to be able to be connected to the speaker outputs of your philips system. Since I don't know what country you live in it is difficult to recommend anything as what is available in one area may not be available in another
Sep 01, 2016 | Philips Audio Players & Recorders
Scpt950k wireless speakers don't work
there may be some loose connections or connections may get lost inside the speakers or it may blown due to high voltage so check that
Jun 30, 2008 | Panasonic Home Theater System System
I had Bose lifestyle V35, V20 try to link together. Bose link AL8 transmitter will not connect to receiver. both led is light solid green. Please help.
The commands for the Bose link system are actually going through the remote control system. In order to use the system you need not only a set of AL8 sender and receiver, but also a special remote control model RC48S2-40 these model numbers are slightly different for the US and for Europe. In addition you will need to activate the BoseLink connection through the system settings menu and you will need to tell the remote to which system it needs to talk. When you have done all that, there should not be any problem to "connect" the two systems. If this does not work, you may need some specialized help from a Bose specialist who understands this multi room set-up.
Nov 09, 2014 | Bose link AL8 wireless home-wide audio...
How to adjust tone settings manually for my LG LHT743 DVD receiver? I have several preset settings but no Bass, trebal control
I did some research on this, but was unable to find out how to adjust bass and treble control individually. this is a link to the users manual (not sure if you have or not). You can download it if you like. I did, read through it, and didn't find anything to solve your issue. Unfortunately, this is a common setup for a lot of newer sound systems. Since they are digital, to achieve superior performance, they keep the settings digital and dont allow for fine tuning of the lower and upper frequencies (bass and treble).
http://www.retrevo.com/support/LG-LHT734-Home-Theater-Systems-manual/id/3126dj199/t/2/
I hope this helps.
JD
Mar 24, 2011 | LG LHT734 System
Just purchased SBHS100AE-K rear speakers to connect to my SC-BT100. I want to connect them wired rather than purchase the wireless transmitter, but I can't figure out how to connect the wired rear speakers...
This unit is not as flexible as traditional receivers are as far as speakers are concerned. Speakers are labeled and *must* be connected to the correct speaker terminals.
Upon reading the manual - it is quite apparent that the only provisions for rear surround speaker connections is <i>only</i> via the optional wireless transmitter / receiver hardware. The optional digital transmitter is connected via a proprietary plug on the rear of the SC-BT100. The optional receiver amplifies the received signal and passes it to the connected surround speakers. I would bet that there are no provisions for amplifying a surround L and R speaker channel inside the SC-BT100, and that it only provides a low level (like a "tape out") or un-amplified signal to the transmitter plug. Even if you were to manage to get the surround speaker connections made up there - you would not be able to hear anything from them - as there is no amplifier. The amplifier is contained in the wireless receiver, and is largely why it requires a connection to house current.
Unfortunately, I doubt you'll find a way to listen the surround channel audio from the SC-BT100 without the optional transmitter / receiver and the integrated amplifier.
You can review the manual like I did here:
http://service.us.panasonic.com/OPERMANPDF/SCBT100.PDF
I hope this answered your question.
Jun 11, 2010 | Panasonic SC-BT100 Theater System
I have and lg tv and a samsung home theater
optical audio cable from home theater to tv. can be purchased on line for a few bucks.
Dec 21, 2009 | LG LHT854 Theater System
No Audio Out through the Optical OUT jack
just press the DVD button on the remote contol and you will be ok.. :)
Jun 16, 2008 | LG LHT734 System
First and foremost when the chance comes along buy a Harmony remote. Your spouse will love the simplification. A couple of things, On the tv with the optical hose connected and the other end in your hand, do you see the light. Its not a laser and eye safe. Should be a red glow. If not, implies two things the tvs optical is bad or it needs to be enabled via tv menu audio settings. If you see the red glow, then its a protocol issue. Verify your tv is setup on the proper audio mode that your receiver is wanting to see. Probably PCM. I am not directly farmiliar with the tv, but using the dish receiver as a reference (you know its working) set the audio options on the tv similar to the dish receiver. IE pcm, dts, etc.. Let me know thanks
Jun 16, 2008 | Zenith C34W23 34" TV
LG Model LHT754 stuck in demo mode
hold the stop button on the receiver not the remote! for twenty seconds
May 24, 2008 | LG LHT734 System
Hook up sylvania lc370ss8 LCD TV to a lg lht734 DVD home theater system
Hook a digital optic cable from the Tv's digital ouput to the Recievers digital sound in. This should fix it. You might have to switch the input of the reciever.
Mar 21, 2008 | LG LHT734 System
210 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
