Question about Bunn NHB Coffee Maker
My bunn coffee msaker isd about two months old and it now will not allow the water to pass to the filter, oly about a cups worth came through
  • 189 Answers
If you will call Customer Service, either a new brewer will be sent to you with return shipping label to return the defective brewer or troubleshooting can be done to determine and correct the problem.
Posted on May 19, 2010
Testimonial: "amazing thank you"
How to activate a 10 cup bunn coffee brewer model nhb?
I don't understand the question, but here is a try.
1 - put in two pots of water.
2 - put in third pot, the water should start coming out
Allow the water to heat (thirty minutes) then put coffee in filter housing, put in one pot of water, put empty pot on warmer, close lid, wait for brew cycle, enjoy coffee.
Feb 27, 2015 | Bunn 10 Cup Home Coffee Brewer
Why does my Bunn coffeemaker spill over the filters when I use Bunn Filters.
I purchased a special flow restrictor sprayhead from BunnAtHome.com because I use decaf coffee. Also if you use a finer grind then you need this to slow the water so it doesn't overflow.
Jul 07, 2014 | Bunn 10 Cup Home Coffee Brewer
Programing for best cup
when feeling upper crusty, I like the pre-soak method, using my good old bunn machine a small blast of 195 degree water to steep for 45 seconds to a minute, followed by the remaining 195 degree water to brew my desired quantity. but I seldom wish to muck about when I want some coffee, so use my good old bunn old school brewer the way it was originally designed,... add grounds, pour water, enjoy coffee!
Feb 13, 2013 | Bunn ICB-DV Coffee Maker
I just purchased a new a10 bunn coffee maker and it just doesn't brew a hot pot of coffee. It is warm enough to drink without cooling it like my old bunns and the cup of coffee is almost cold before you...
Plug in brewer and turn on vacation switch on side
of brewer. Allow 15 minutes for water to heat to proper
temperature. This is a quote from bunns troubleshooting page. Also it should be under warranty in which case you could go to www.bunn.com and call their service line and either have them send a tech to look at it or have you send it off for warranty repair. Hope this helps.
www.midstatebeverage.com
Nov 30, 2010 | Bunn BT10B Coffee Maker
The water dont seem to brew all the coffee in the filter....parts of the coffee is still dry....i have cleaned the pot and spray head and empty the tank and refilled with water...my bunn is only 3 months...
It sounds like you are either missing a sprayhead or need the flow restrictor sprayhead. If you will call customer service at 800-352-2866 we will be happy to resolve this issue for you.
Sep 17, 2010 | Bunn 10 Cup Home Coffee Brewer
Grounds in coffee. am using bunn coffee filters and still have a mess in my cup and in filter
Are you using a finer ground coffee? Or do you have a water softener, use filtered water or bottled water? If so, please call customer service to get a flow restrictor sprayhead which will eliminate this issue.
Dec 07, 2009 | Bunn NHB Coffee Maker
When we make a pot of coffee, the water goes through to quickly and the coffee looks like weak tea, how can we fix this, we only got the coffee maker about a month ago
This is usually caused by a missing sprayhead above your filter basket. take out the filter basket, and see if there is a sprayhead up there, or if there is just a little round pipe that the prayhead screws on to. If it is missing, you can contact your local Bunn dealer, or phone bunn directly, and they will take care of you. You can get a list of repair centers in your area at www.bunn.com
Nov 20, 2009 | Bunn 10 Cup Home Coffee Brewer
Bunn coffee maker leaks all over the counter. What
there's probably a 'silicon rubber' hose that feeds hot water to the 'grounds basket'- it may be loose, or damaged. is it leaking water, or coffee?? we have a bunn 8-cup, which has a pre-heated water tank that brews a pot in about 3 min. energy waster, but when you need coffee, you need coffee!!! is your filter holder properly centered? is the carafe lid hole clean and un-obstructed?
if it's leaking water, and not too costly to replace- you may consider replacing it with a new one!
good luck!
Oct 09, 2009 | Bunn GRX-B Original 10-Cup Home Coffee...
Bunn auto coffee maker two warmer, only makes about 3-4 cups
The machine will allow you to brew from 4-10 cups. It works on a displacement systems so if you pour in 4 cups of water, then 4 cups of coffee should come out. If it isn't, then get the model and date code from the bottom of the unit and call customer service. If you machine is 3 years old and less, it will be replaced at no cost. If it is over 3 years old, it will be replaced at a reduced price.
Dec 02, 2008 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Bunn NHB Coffee Maker Logo
153 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
gbob59
evans_lloyd
Level 1 Expert
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
