Question about Reebok Exercise & Fitness
The back roler is making a very loud vibrating
Reebok TR2 Treadmll - The back roller is making a very loud vibrating noise
    President:
  • Reebok Master
  • 832 Answers
Best way to check the roller to see if the bearings have failed is using a long shafted flat tip screw driver and place it on the end on the adjusting bolt. Then put your ear on the handle and listen, if the sound has amplified then the roller is defective and needs replacing. If not then check the front roller the same way because sound travels thru the frame and the problem maybe originating their. Call Icon Fitness to order part their is 1-800-999-3756.
Posted on May 05, 2010
Testimonial: "thank you very much. I took it to pieces and fixed myself"
Why does my gas dryer make a loud vibration noise?
Hey friend, I appreciate your post!
I understand that your Electrolux gas dryer is making a loud vibration noise and is also loud while tumbling. There are several components in your dryer that could be causing this noise. Based off what you are describing it might be an issue with your suspension rollers, motor, or pulley. Since it could be any of these underlying issues I would suggest getting a technician out to diagnosis and repair your dryer. Hope this is helpful. - Matt
Jul 21, 2014 | Electrolux Dryers
Instruction manual required
http://userguides.50webs.com/reebok_tr2_manual.html Reebok Tr2 Manual
Feb 17, 2014 | Reebok TR2 PremierRun Treadmill
Reebok premier run tr2
1) can be some easy matter:see the video and make the final decision
Jun 06, 2013 | Reebok Exercise & Fitness
Reebok tr2 incline wont work, back of machine starts to rise when you prees the incline up button
1) lube the motor elevation, shaft +gear and adjust the POTentiometer a little
2) see the diagram attached,
3) Run the software calibration for troubleshooting,
4)test the relais for open or faulty coil,and clean the contacts very well
God bless you1_22_2013_5_10_05_pm.gif1_22_2013_5_10_34_pm.jpg1_22_2013_5_11_02_pm.png
Jan 22, 2013 | Treadmill Doctor Reebok S 9.80 Treadmill...
Reebok Treamill TR2
Dear Sir:
You need LUBE the machine according with instruction manual for maintenance. if you do not have download free www.fitness.manualsonline.com or www.iconservice.com
The friction is enough by lack of lube, shut down the machine for protecting the electronic system.
Test the main motor ,drive belt,
After that RUN the software calibration for diagnose, troubleshooting and fix it.
sincerely. God bless you
Apr 26, 2012 | Reebok Exercise & Fitness
Loud vibrating noise. Sounds like its coming from
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
Apr 18, 2010 | Dryers
Loud rumbling noise with slight vibration
Normally the noise you hear is caused by the drum rollers having flat spots on them or needing lubricant.
If this is what is wrong It will make a kind of thumping noise.
When they need lubricant they will normally make a squealing noise also. You would lube the shaft and bearing area of the roller, using a good machine oil...something like "3 in One" oil.
Sep 26, 2009 | GE DBXR463ED Electric Dryer
Exercise & Fitness Logo
412 people viewed this question
Top Reebok Exercise & Fitness Experts
Electro Med Services...
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
