Question about Audiovox Jensen NAV-102 Car GPS Receiver
NAV102 and VM9312 unit doesnt have the NAV option under source :(, i plug it in then turn my unit on under ipod it says connecting...then connected, but nothing, memory sticks in (preloaded maps etc) :( any one with solution?
How do I get GPS & bluetooth stufff to go with this system ?
You need the Jenson BTM15 (bluetooth module) and the Jensen NAV105 (gps) in order to have navigation and bluetooth connectivity thru this head unit.
http://www.mobile.jensen.com/accessories/?sku=NAV102
http://mobile.jensen.com/bluetoothcarkits/?sku=BTM15
These units sell for around $50 (btm15) and $200 (nav102) on amazon.com
Jan 28, 2011 | Jensen Vm9214 Car Video Player
Jensen nav102 with licence key issue
I had the same problem and a very hard time finding any help on it on the web.
The NAV102 is made by Horizion Navigation (www.horizionnav.com)
(866) 286-2831
support@horizonnav.com
I just emailed their tech support and got an answer very quickly (7mins.) from a Support Tech named Todd Carey. He said the software was out of date and directed me to:
http://www.horizonnav.com/downloads.php?index=36
He also asked me for my Device ID - This ID is given on the screen after an invalid code is entered. Mine started with AVX20090304...
(believe that is the manufacture date? after the letters?) With this Device ID he was able to give me the proper activation code.
I haven't actually tried the new software, but wanted to put this out there for anyone else that was having trouble finding info on the NAV102.
Jul 03, 2009 | Jensen Car Audio & Video
My ipod doesnt turn on is appear an ipod image but like death
here are some steps you can try to resolve this issue if you still have the ipod.
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
If you have a computer I would suggest restoring it using itunes. here is the directions on how to do that as well just in case you haven't had to do it before.
How to restore iPod (ARTICLE NUMBER HT1339) Ensure that you have an active Internet connection as new versions of iTunes and iPod Software may need to be downloaded to your computer. Download and install the latest version of iTunes if you do not already have it installed. Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod. After a few moments, your iPod will appear in the Source panel in iTunes. Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software. The 4 possible restore options are: Restore Option 1: Restore - Restores with same iPod Software version already on iPod. Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available. Restore Option 3: Use Newest Version - Restores with the latest iPod Software available. Restore Option 4: Restore and Update - Restores with the latest iPod Software available. If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring. Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models). Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models). During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage. Note: The progress bar may be difficult to see since the backlight on the iPod display may be off. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
Feb 20, 2009 | Apple iPod MP3 Player
Ipod video problems
I have the Jensen head unit. I found out a while ago that the 6th Gen Ipod Classic does not send video through the multi-pin connection. Only out of the headphone/A/V out. This is the reason it does not work via the JLink cable into the Jensen VM9312
Jan 03, 2009 | Jensen's VM9312 Car DVD Player
30 gig iPod after plugged up to computer completely stopped working
you said its not responding to the reset trick nor turn on or charge, plug ipod to pc via usb plug. go to my computer find the ipod it shoudl show up as a hard drive. if it is there click on it and copy the ipod software to the pc (non music). now format the ipod (you was going to erase it any way) once formatted copy the ipod software from pc, back to ipod. this should make feel and act as new again. download and updated version of itunes and put your music onto ipod. feel free to rate this suggestion
May 11, 2008 | Apple iPod MA446LL/A MP3 Player
Flashes do not disconnect while plugged up to computer
You can try to reset :
http://support.apple.com/kb/TS1382?viewlocale=en_US
http://support.apple.com/kb/HT1320?viewlocale=en_US
If you still have the problem you can try restore :
Note: Because Restore erases all of the songs and files on iPod, make sure to back up any files you've saved on the iPod disk. All of your songs, videos, podcasts, audiobooks, and games can be loaded back to your iPod provided that you have them stored in your iTunes Library.
How to restore your iPod:
For Windows:
1. Make sure you've reinstalled the latest version of iTunes.
2. Open iTunes, and then connect your iPod to your computer.
3. After a few moments, it will appear in the source list in iTunes. If the iPod's display doesn't show "Connected" or "Do not disconnect" you may need to put the iPod into disk mode to proceed.
4. Select your iPod in the source list and you will see information about it appear in the Summary tab of the main iTunes windows.
5. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download of the latest iPod Software.
Restore Option 3: Use Newest Version - Restores with the latest iPod Software on your computer.
Restore Option 4: Restore and Update - Restores with the latest iPod Software on your computer.
6. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started.
When this stage is completed, iTunes will instruct you to leave iPod connected to your computer to complete restore.
7. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage.
8. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
For Mac:
5. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download of the latest iPod Software. The 4 possible restore options are:
Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod, even though a newer version is available.
Restore Option 3: Use Newest Version - Restores with latest iPod Software version on your computer.
Restore Option 4: Restore and Update - Restores with latest iPod Software version on your computer.
6. A message will appear prompting you to enter an administrator's name and password.
7. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will instruct you to leave iPod connected to your computer to complete restore.
8. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage.
9. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
Or
Try to reinstall
To update and reinstall your iPod software, first download the latest version of iTunes.
http://www.apple.com/itunes/download/
Next, open the new version of iTunes and connect your iPod to your computer.
Select your iPod in the source list and click "Check for Update" under the Summary tab. iTunes will check to see if your iPod needs to be updated and perform the update for you.
Good Luck.
Live, Love, Laugh.
APPLE IPOD VIDEO 30 GB WHITE
For Windows:
For Mac:
Or
Try to reinstall
Good Luck.
Live, Love, Laugh.
May 05, 2008 | Apple iPod MA446LL/A MP3 Player
Ipod Video
This will never work, the new ipods will only work with apple products. I've had numerous headaches with this and after many phonecalls to manufacturers I discovered that the new ipods will only play video if they see an apple authentication chip embedded inside the video cable. Sorry.
Mar 31, 2008 | Jensen's VM9312 Car DVD Player
Ipod connection
As far as iPod connections - they will work with a regular iPod and an iPod Nano. You have two options depending on how much you want to spend and how much convenience you want.
Option 1 - Use a Pioneer CD-IB100 adapter. This will plug into the docking port on the bottom of the IPod, charge it, offer control and song information on the head unit. You need to use this one and not the newer CD-I200 cable because your head unit is not compatible with the newer piece.
Option 2 - Use a Pioneer CD-RB10 adapter and a 3.5mm to RCA cable that will plug into the headphone jack of the iPod. You will only get audio input to the head unit but this option is somewhat cheaper.
As far as the clock settings - hold the 'source' button to shut the unit off(key still has to be on). Push the 'function' button until options appear - you can switch between options by repeatedly pushing the 'function' button and adjust settings by using the up/down/left/right arrows.
Dec 29, 2007 | Pioneer DEH-P6800MP CD Player
Audiovox Jensen NAV-102 Car GPS Receiver Logo
69 people viewed this question
Top Audiovox GPS Experts
Are you an Audiovox GPS Expert? Answer questions, earn points and help others
