Question about Canon CLC 1150 Color Copier
File needed: Printer driver INF for EDOX CLC 1150_Canoncolor
Whenever we try to map to this printer now it says "The server for the 'EDOX CLC 1150_Canoncolor printer does not have the correct printer driver installed. If you want to search for the driver, click OK. Otherwise, click Cancel and contact your network administrator or original equipment manufacturer for the correct printer driver."
I am the network administrator and am assuming the driver has been corrupted because this used to work flawlessly until recently. However, I cannot locate a driver for the CLC 1150 anywhere in my internet searches. (Not sure who set it up originally...was some time ago) Can you suggest a source?
  • hoknik Jan 19, 2009
    I have CLC 1150 and 1180 connected through Edox print server - need to find drivers for Vista. Any help on this?
I believe the CLC1150 is a copier only, not a printer.
Posted on Apr 18, 2008
How to connect canon clc 1150 to my pc
just install the driver then use the usb cable to connect the same.
Sep 26, 2012 | Canon CLC 1150 Color Copier
I installed the printer and share it. It is only available to user who are on x64bit. user with 32 bit win xp cant access it and install/share it. I have tried to download and install x86 driver but...
This is the HP solution for the problem
HP LaserJet, Color LaserJet and LaserJet MFP Products - Print driver Client / Server Connections in a mixed 32-bit and 64-bit environment ISSUE: 32-bit clients are not able to connect to shared Universal Print drivers or discrete drivers on a 64-bit print server or vice-versa. These scenarios may involve Server 2003/Server 2008 64-bit print servers with Windows XP, Vista, 7 32-bit clients. It is also possible that the server editions could be 32-bit versions with 64-bit clients. SOLUTION:
  1. The administrator will need to download the 64-bit AND 32-bt version of the print driver from www.hp.com . If the server involved is a 64-bit version, the 64-bit version of the print driver will need to be installed and mapped to the printer via TCP/IP. Ensure that the print driver has been shared on the network by going to the print driver properties and enabling Share this printer within the Sharing tab. c02030528.gif
    Ensure that communication has been established and that a driver test page can be printed from the 64-bit server. Once functionality has been confirmed from the 64-bit server, proceed to the next step.
  2. Currently, 64-bit clients will be able to connect to the shared 64-bit print driver that has been installed on the 64-bit server as the architecture currently matches. However, if 32-bit clients wish to map to the shared 64-bit print driver on the 64-bit server, the 32-bit version of the same driver will need to be installed within the current 64-bit driver.
    This process can be done by navigating to the printer properties of the 64-bit driver on the 64-bit server, clicking the Sharing tab and clicking the Additional Drivers button. c02030529.gif
  3. Once the administrator clicks on the Additional Drivers button, the next screen will allow the administrator to load the 32-bit drivers by placing a checkmark in the x86 button and clicking the OK button. c02030530.gif
  4. Once the administrator clicks the OK button, a print driver window will pop-up asking for the 32-bit driver components. Again, the administrator will need to download, and extract the 32-bit version of the print driver on the 64-bit server. Once the window below comes up, the administrator will need to navigate to the 32-bit driver components and select the appropriate driver .inf file.
    For example, the UPD .inf file would be the first file in the list and be named hpcuXXXc.inf. c02030531.gif
    Once the appropriate .inf file is selected, the 32-bit driver components will be installed within the 64-bit driver on the 64-bit server. This can be verified as both x86 (32-Bit) and x64 (64-Bit) boxes will now be checked and show the status as installed by clicking the Additional Drivers button compared to the screenshot in Step 3 above.
  5. Now that 64-Bit and 32-Bit drivers have been loaded onto the 64-Bit server, 32-Bit and 64-Bit clients can now navigate to the shared print driver on the 64-Bit server, by manually navigating to the shared print driver on the 64-Bit server from the client machine. Typically the path is \\servername\sharedprintername.
  6. Once the client maps to the shared print driver, printing should work successfully.
    For problems or errors that continue to occur after completing the aforementioned process, ensure that the latest version of the print drivers are being used www.hp.com . If there are problems with older discrete drivers, it is recommended to use the latest version of the Universal Print Driver which can be found at www.hp.com/go/upd .
Mar 17, 2011 | HP Laserjet P4515x Printer
Vista cannot connect to xp printer
It sounds like your are using your Windows XP computer as the print server, and you are trying to connect your Windows Vista machine to the Windows XP print server. Your Vista machine is trying to download the XP drivers from the Windows XP computer to your Vista machine. This won't work. Windows XP and Vista print drivers are not compatible.
If the printer is truely networked (it has it's own IP address on the network, it has its own ethernet connection). Then instead of trying to map out to this shared printer, add new printer to the Vista machine using Vista drivers for the HP Deskjet 3940. The type of port you would need is a standard TCP/IP port. To get this address, print a settings page from the printer. Look for either a TCP/IP address or IP address on this print out. This is the port address you want to create and then connect to.
May 04, 2009 | HP Computers & Internet
Canon CLC 1150 ? Need to change laguage in English
hi you must have sst or service suppor tool to upgrade the firmware of your clc
Jan 10, 2009 | Canon CLC 1150 Color Copier
CLC 1150 dont work duplex in Win XP !!! Help (form Argentina)
I think someone selected the wrong model when installing the drivers. I would uninstall the printer from the XP machines, and reinstall the correct driver. You can google to find the driver.
Jun 14, 2008 | Canon CLC 1120 Color Copier
No valid INF file when trying to install Z640 to windows Millenium
The drivers are not designed for WinME.
The Lexmark driver for that model only supports Windows 2000, XP, Server 2003, and Vista.
Unfortunately, none of these drivers will work on WinME.
Mar 21, 2008 | Lexmark Z640 InkJet Printer
Canon CLC 1150 Color Copier Logo
373 people viewed this question
old marine
old marine
