Question about LG WM-2277HW Front Load Washer
Drum doesn't turn
Drum wiggles a little when turned on and turns by hand freely
  • LG Master
  • 8,404 Answers
Your belt is broken or the tensioner pulley may have mal-functioned.
Posted on May 05, 2010
  • dcarpo Sep 15, 2010
    I don't believe there is a belt driven motor on this model. Is there?
Why doesn't drum turn when the start button is pushed?
try turning the drum by hand while on dry cycle> just tape shut or hold door switch in by hand then have someone turn the drum? see if it starts? if so ur motor windings may be bad ad not pushing enough power to run machine, also check the thermal fuse and other thermostats as u may have shorted them somehow? lastly check the belt and tensioner as the motor switch may have switched off if there was a problem with the belt
Jun 03, 2014 | Samsung Dryers
Baril ne tourne pas
What kind of dryer is this? I assume that this is a front-loading belt-driven drum dryer. What happens if you turn the drum by hand? If it turns freely, it could be that you have a broken belt. If there is some resistence to turning the drum, is it possible to turn the drum while trying to start the dryer (this may require pushing the interlock button and the start button at the same time you turn the drum)? If the dryer starts to work with a little push, the problem is most likely a capacitor on the motor. Otherwise your motor may be work out - worn brushes or bearings.
Apr 07, 2014 | Dryers
Drum doesn't turn..Motor sounds fine and dryer sends heat. Drum turns freely when moved by hand.
replace the belt and idler pulley as a set sold at any Sears store
Aug 14, 2011 | Dryers
I have a brand new front loader and the drum is not turning during the cycle....it turns freely if I do it by hand
If you hear the motor running and the console doesn't put out an error code during the cycle, it sounds like your drive belt may have come off the motor / drum pulley. You should be able to access it by removing the back panel. Be careful- and unplug the machine first.
Good luck.
May 14, 2011 | Bosch Washing Machines
My dryer wont start. When i turn the button to start it, it hums but wont run.
something is jamming the drum of the dryer from turning... remove the casing and take a closer look. There may also have been something recently dried which may have come out and jammed the dryer drum. Try hand turning the dryer drum to see... it should freely revolve at least a little bit
Good luck with it
Ck
Feb 13, 2011 | GE DVL223EBWW Electric Dryer
My Bosch washing machine has a drum that no longer turns. When the cycle reaches a point where the drum has to turn, I hear a series of clicks and the spin does not work at all. I took the back off and the...
Check you can move the drum freely by hand. 1. if its free - then check belt. 2. if it wines - check motor. 3. if does not move - you need to check for obstruction. hope this helps ....
Jan 07, 2011 | Bosch WFMC 3200 Front Load Washer
Put new belt on dryer but it wont turn and i can smell burning and the drum wont turn
sounds like the belt may be bound somewhere, I would take it back apart and see if I can turn everything by hand. If everything turns freely then I would reinsert drum, hook belt up and see it I could turn the drum with my hands, it will turn but not to freely. Hope this helped tim
Sep 19, 2010 | Dryers
LG WM-2277HW Front Load Washer Logo
76 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
