Question about Mitsubishi CK-35308 35" TV
Power up the set will click when turned on then sounds like a different relay will click but the TV is still in the on mode.When i then shut the set off for a couple of minutes the sound of the tube coming on can be hear when i press the power button but then goes back off.
  • Mitsubishi Master
  • 12,061 Answers
This is a classic switchmode power supply, shutting down to avoid a fire, explosion, or both. This set had developed a problem, that is so severe that the set must be shut down, This set should be removed from the Power, and in my professional recommendation, you should get a "Quote" for repair, from, an Akai, Approved Service Center, this point is very important for a good result, Always contact, their local, "Head Office" Now, when you get the information you want, then you can decide as to repair of replacement. The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have parts on hand, also sometimes, there has been a service bulletin in issued and the repair may be subsided or even free.
Posted on May 05, 2010
Samsung TV shutting off by itself and relays clicking
If you don't know what you're doing, don't open it up to fix it!
There are HAZARDOUS voltages on the power supply board EVEN WITH THE TV UNPLUGGED!!! The capacitors can hold a charge for several weeks!
Clicking noise can be coming from bad capacitors on the power supply board.
It's usually easier to just replace the power supply board.
Sep 09, 2016 | Samsung UN55B8500 TV
Tv no turning on straight away
The clicking is the relay the set uses--likely bad filter caps in power supply and here is what to look for:
Dec 03, 2012 | Televison & Video
Philips Magnavox 32MT3305 keeps shutting off with relay clicking. The green power light stays on but the picture and sound go out right after the orange status bar goes away. If the channel up or down...
the relay is the safety protective device..sometimes a defective component or something. maybe an overloaded power supply might caused this problem..so before any thing could gets worst..the relay will shut the unit..
Jul 18, 2011 | Philips 32MT3305 TV
RCA F36648 36' TV will not power on, makes a clicking sound when I try to power on
This set has a number of problem detection circuits and safety shutoffs. The clinking you are heearing is the power relay turning on then off as a problem is detected and hte set shuts down. This is normal expected behavior when the set has a problem. The most common cause of this is a defective horizontal output transistor that has failed. Expect a parts cost in the $30 range for this repair.
Dan
Aug 26, 2010 | RCA F36648 36" TV
Samsung tv turn on problem
check here: http://www.earthinfo.org/samsung-tv-makes-a-strange-clicking-sound/ [worked for me]
Aug 23, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
TV will not turn on
Hi, make & model ? clicking is tv`s relay turning set on but set shuts down because power supply has a dead short in it, you will need a tv tech to fix this one, gl,
Jun 08, 2009 | Televison & Video
Power light comes on,clicks before picture comes on then shuts of
Yes, it is either that or the "Startup Circuit" is faulty usually it is the associated relay. Thats the clicking sound you hear. When you turn on the TV, the relay is activated along with a timing transistor, the Relay has to make contact within a certain time frame. If the contact is not made during that time frame, the TV shuts down. This is a safety feature in all TV's. If you can get a schematic it will show you where the relay is or, after you unplug the TV and wait 15 minutes, you can take a look inside at the main circuit board, sometimes they mark the area with either "START UP" or "SHUT DOWN" and there you should see a relay.
But a new one usually has to be soldered in.
Mar 26, 2009 | Televison & Video
Lg ru52sz51d will not turn on intermittantly
Check fan if bad set will not turn on ,it will try to come on.Bad Fan.
Nov 12, 2008 | LG RU-52SZ51D 52" Rear Projection...
42PF7320A/37
Hi again,
Did you try connecting the TV into a different power outlet?
Jun 07, 2008 | Televison & Video
TV won't turn on, red lights blinks twice.
The blinks can tell you the problem , is it 4 blinks that could be 3 different ics IC1509 Q1505 or IC502
Aug 06, 2007 | Sony KV-32FS13 TV
Televison & Video Logo
76 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
