Question about Sharp AR-M550N Copier
Sharp copy/printer to staple Crystal Reports
I have a Sharp AR-M550N and I'm trying to print reports from Crystal Reports. It is my understanding that this machine has the ability to print and staple these reports, however I can not figure out how to make the staple happen... Is it a setting on the printer? Or something we need to code into our Crystal Reports?
  • Anonymous Mar 31, 2014
    I go into printer preferences, select "staple" under "finish," or I even set up a staple preference. The minute I close out of that screen, the setting is gone and I print minus staples. Yes, we have a machine that staples. Yes, there are staples in it. No one else has trouble.
This should be an option in your print driver make sure when you set up the print driver you added the accessories ie. a finisher
Posted on Jul 17, 2008
6ya staff
SOURCE:
Sharp ar m550n error codesError code F2How can i fix it ?Help me plz , Thank
press and hold start key to show you sub code and send for me but i think you toner cartrige shode chenge
Dec 18, 2013 | Office Equipment & Supplies
We have a Sharp M550N copier. I know we can scan documents to email. Can we scan color documents from this machine?
It is a monochrome(black and white) copier. Generally, any monochrome machine only copies,scans, faxes, or prints in black and white only.
May 02, 2011 | Sharp AR-M550N Copier
CAN U TELL ME THE STAPLES THAT I USE FOR AN AR550N COPIER PLEASE
The finisher uses a SF-SC11 and the saddle stich uses AR-F12
Aug 31, 2010 | Sharp AR-M550N Copier
Barcodes not scanning
Very possible you have a bad printhead. If you have a bad dot in your print area, it can cause barcodes to not scan. Look to see if you have a blank vertical line running down your label.
Dec 31, 2008 | Epson TM T90 Printer
Printing on my copier
Try copying and printing internal reports to check for quality. If those are fine, the problem is computer or network related. If those reports also come out bad, you have a hardware problem. Start by checking the toner supply. It may be out even though you have no message.
Jun 13, 2008 | Sharp Office Equipment & Supplies
Can't get Fax Confirmation page to print
What model brand name something!!!!!!
Nov 12, 2007 | Sharp AR-F152 Fax
AR-M455 Printing Blank Pages
hi im jules_09.try checking the transfer roller or the drum charge roller or charge wire both of this unit are responsible for blank copy.either there id a current leak on those parts or your drum and transfer power pack is deffective.is the opc drum not expose to light morethan 8minutes?just check the transfer unit then the drum charge wire or roller
Nov 05, 2007 | Sharp AR-M455N Copier
LaserJet1020 Crystal Reports on Forefront Accounting
I found this document setting up Crystal Reports for your printer. I hope this helps. http://support.businessobjects.com/communityCS/TechnicalPapers/cr_printer_driver_options.pdf
Jul 03, 2007 | HP LaserJet 1000 Printer
Sharp AR-M550N Copier Logo
512 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
k24674
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
