Whirlpool catalyst washing machine won't start, but lights up
After putting clothes, soap, etc in the washer and pushing normal for normal load then hitting start the digital board and lights light up but the water does not start nor the washer. Every now and then if you unplug it and try again it will start normally, but only when it wants to. When it does run it runs fine. It's just trying to guess when it wants to start. Any ideas?
Thanks.
  • wildcow67 Mar 30, 2008
    Checked all grounding wires, all were tight.
  • Anonymous Mar 27, 2014
    thin stops nothing happens
  • 8,617 Answers
Sounds like the ground wire needs to be tightend
Posted on Mar 26, 2008
SOURCE:
Downy goes first than soap
I fill the washer with water first
Then open the lid put in the soap
3/4 cap full,then then 2/3 cap downy
(Both together-bleach as well- if a white load)
I add only to clear water after it fills
Then allow the water to mix the soap
Then add the cloths a few at a time
NEVER put the cloths in & add soap
on them with no water or use the silly
places on the top they say to add stuff
You only add soap etc to plain water &
no cloths & mix first,then cloths go in
Common Sense as to what is taking place
The part about the softener was just silly
It is in the water mixed with soap etc & all goes out
at one time
It is a one step deal
Water,Soap,Downy,then Cloths your done
Nov 04, 2014 | Samsung WF337AA Front Load Washer
How do I clean my front load washer. the clothes are starting to smell musky
Try a small amount of soda crystals put it in the soap draw about half the amount you would normally use of regular soap powder and put it on the hottest wash it will break down any gunk or loose limescale which could be causing the smell.
Thank you
Jul 03, 2010 | LG WM-2277HW Front Load Washer
Put clothes in washer HOTPOINT modelWML730 started
TURN MACHINE ON TO FINISH CYCLE THEN RE WASH WITH SOAP ETCH,DOOR WILL NOT OPEN MID CYCLE SAFTY LATCH,YOU CAN TURN PROGRAM TO FINAL SPIN TO EMPTY MACHINE AND FINISH PROGRAM THEN DOOR WILL OPEN
Jan 06, 2010 | Washing Machines
Sud message on whirlpool duet front load washer also after washing clothes i notice a mildew smell on the clothes.
You areusing too much soap. Run a rinse cycle and use less soap next time. As for the mildew leave your door cracked open after you are done using the machine.
Dec 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have a quite normal front load whirlpool washing machine and the feeling when I clean my clothes is that the smell is that fresh smell anymore, does not smell like softener or any soap but a horrible...
Oh angel!
a rose by any other name!
If your clothes smell worse after washing then the machine is full of gunge from all the previous washes. One of the worst things that puts a gluggy deposit inside machines is of all things Softener!
You could try putting a generous two cups of Sugar Soap Concentrate into your machine and filling it with warm water. Then let it stand for 24 hrs, Then start the wash cycle.
This may clear the gunge. If not the only sure remedy is a strip down and degunk and that will cost you a few dollars.
Oct 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Calypso stops at 26 minutes and throws ob code
first you need to clean your washer
run the washer with no clothes; add 1 cup vinegar, that will cut the soap residue from the hoses do this on hot wash hot rinse
then when you wash your next load of clothes; fill the tub about 1/4 full, add the soap, turn the agitator to disolve the soap, then add the clothes
this problem happens also if you are using too much soap or a heavy duty soap such as Tide.
May 20, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Green whites?
This often is called "lint" but is really a "whiting" left by un-dissolved soap and can be seen at it's worst on dark colored clothes. This is made worse in a colder climate where the cold water entering the washer is much colder than normal. Things that can effect the quality of the finished washed products.
Too much soap: ( we have a test for this further down the page ) If you follow the manufactures instructions on the box, then chances are you ARE using too much soap. They like to sell you their product, I find cutting usage in 1/2 of what the box says will still wash good and also cut your chances of getting "whiting" on your clothes.
Over loading the washer: Even if the agitator is suppose to go back and forth, the clothes are not. If you can hold the lid button on your washer so you can watch the clothes wash, they should 'roll" in the basket and not go back and forth like the agitator. The clothes will go down the side of the agitator, across the bottom of the basket, up the side of the basket and across the top of the water in a rolling motion. Overloading is not just too many clothes but also too little water for the size of the load is another way of having a overloaded wash load.
Water temp is important: Use a thermometer to test the temp of the incoming water in your washer. Hot water should be close to 140 degrees F. Warm water fill should be 100 degrees F. Cold water is approx 60-80 degrees F. What happens in a cold climate location is the cold water temp drops as the outside temps drops, once the water temp gets below 60 degrees F, it can no longer dissolve the soap properly and will most definitely leave "whiting" on the clothes!! Do not use a cold wash, wash your clothes in as warm as poss.  water as they can take. If you have delicates you want to wash in cold, start washer out with warm water as you are putting in the soap and fabric softener and clothes, then switch to cold to let it finish filling up, this will give you a warmer wash but not as cold as straight cold water. I find most washes can be done in a warm wash / cold rinse just fine. If you need ( and probably will ) to adjust your warm water fill, turn on the hot water tap fully, turn off the cold water tap. Let the water start to fill on a warm wash setting. Then slowly turn on the cold tap adding the cold water to the hot water making a warm fill....use a thermometer to set water temp and leave the taps stay when you get about 100 degree F water fill. I adjust my own washer usually twice a year, one on summer time and once in the dead of winter.
Test for too much soap or soap retention: Put in a load of towels or dark clothing that has been bad for the "whiting" problem. These items are bad for holding soap and getting what is called -soap retention-
Wash the load in the warmest poss. water, DO NOT add any soap. Let the washer fill with water and wash for approx. 5 minutes, lift the lid and observe what is on the top of the water. If you see soap and bubbles on top of the water, your clothes have soap retention, this soap came out of your clothes. Let the load finish with out adding any soap and wash all clothes effected with this "whiting" residue. Once all the soap is washed out of the fabric and you start to add some to each load, use about 1/2 of what the box says. Liquid soap has less problems with "whiting" than the powder does, but I find powder soap is better at getting my own personal clothes cleaner.
Mar 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Leaves soap residue
theres a new product just hit hte market www.affresh.com try this stuff speciffically designed for the frontloaders and endorsed by whirlpool, makers of your machine
Apr 01, 2008 | Kenmore Oasis HE 27062 Top Load Washer
Order in clothes
Put a half a cup of vinegar into wash load, with soap. It removes the smells.
Jan 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Crosley CAWC529JQ1 top load washer LEAVES LINT ON CLOTHING
try washing on a shorter time as this washer may have too good of wash action and the lint is fabric coming off your clothing
add more soap powder and do not buy the cheapest soap as the soap is important in the washing cycle of your machine
towels that are not too soiled brobably need 6 minutes at most on wash
if this machine has a delicate wash cycle use that for tee shirts etc
water pressure is important in rinse cycles
do you have high pressure and water only trickles in check water inlets on back of machine where the hoses screw on
good luck
Nov 27, 2007 | Crosley CAWC529JQ Top Load Washer
Washing Machines Logo
190 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
