How to remove service menu from phillips tv 32PW 9617/79
    Sergeant:
  • 418 Answers
Turn off TV via a remote control.
Posted on May 06, 2010
I can't access my main menu for my Phillips TV
The TV might have set to Hotel mode. To get it out from this mode, you have to enter its service alignment mode [SAM]. Check this link to get more details about it. It is too much to type in here, al the procedure. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Timeslide option.
Jul 03, 2013 | Televison & Video
Tip
Service menu codes phillips magnavox
I provide this information for those that are qualified and trained to do TV repair work. Entering or making changes in service mode by untrained persons can cause significant and permanent damage to your television. If you are not qualified to service your television, please DO NOT ENTER these service menu codes
# Press {0} {6} {2} {5} {9} {7} {INFO+} on the remote.
or
# Press {0} {6} {2} {5} {9} {7} {STATUS} on the remote.
or
# Press {0} {6} {2} {5} {9} {7} {MENU} on the remote.
# Turn the TV off to exit the Service Menu
* Press {0} {6} {2} {5} {9} {6} {INFO+} on the remote.
or
* Press {0} {6} {2} {5} {9} {6} {STATUS} on the remote.
or
* Press {0} {6} {2} {5} {9} {6} {MENU} on the remote.
* Turn the TV off to exit the Service Menu.
* Press {0} {6} {1} {5} {9} {6} {MENU} on the remote.
or
* Press {0} {6} {1} {5} {9} {7} {MENU} on the remote.
* Turn the TV Off to exit the Service Menu.
* Press {1} {6} {2} {5} {9} {6} {MENU} on the remote.
or
* Press {1} {6} {2} {5} {9} {6} {STATUS} on the remote.
* With the TV off:
Models 15MF605T/17, 20MF605T/17, 15MF500T/37:
To Factory Mode:
Step 1 : Select the source "PC" and then turn off LCD-TV.
Step 2 : [Push "power " button and then push the "VOL- " and "VOL+" buttons at the same time immediately and hold it] about five seconds then release all buttons.
Press "menu"button and bring up factory mode indication
on Apr 29, 2015 | Magnavox Televison & Video
How to replace lamp
1. Turn the tv off and unplug it. 2. carefully access the back of the tv. 3. when facing the back of the tv on the lower left hand side there is a cover held on by two phillips screws remove this cover. 4. After cover is removed you can see the lamp which is also held in by two phillips screws, these screws only loosen and do not completely remove from the lamp. 5. after loosening the screws there is a handle in the center of the lamp, take the lamp by the handle and remove it from the tv. 6. reverse this process to install lamp.
I hope this helps you. After you replace your lamp make sure you reset the hours for your lamp. Press tv menu, select the setup menu, and then select the lamp reminder option to reset hours to zero.
Nov 17, 2010 | Mitsubishi WD-62528 62 in. LCD Television
I need service code # Thanks, Phillips Audio Video Services 843-488-2240
With TV off Press and Hold CH- and Vol- at same time wait untill TV turns ON release on you should then be in Service Menu.
Sep 24, 2010 | Zenith R56W36 56" Rear Projection...
After Power outage - picture is larger than screen
This TV also should have similar facility like 19" Tv. Try the menu, it may be in different name or classification. I do not suspect circuit fault. If you can access service menu code you can try. Better take assistance from service center. If you access service menu, do not for get to note down the values in each and every step.
Apr 30, 2010 | Philips 19PR19 19" TV
Phillips plasma tv. Settings menu pops up all the
Philips.com should have a software upgrade for your TV to fix the problem. This is a common problem with Philips TVs and they have made upgrade software to address the problem.
Go to the Philips web site and all the procedures for download to your TV will be there. The only thing you will need to this is a USB memory stick. Download should be FREE.
Aug 03, 2009 | Philips 42PF9630A 42 in. Plasma Television
Headphones?
are you using the correct jack plug into your tv, sounds like they are not compatible and not cutting out the sound on the tv
Feb 16, 2009 | Philips 26PW6341 26" TV
Can't find menu on hotel tv
YOU WILL NEED THE SPECIAL REMOTE TO DO THIS. AND I THINK SOME OF THEM HAVE ABILITY IN SERVICE MENU TO TURN OFF HOTEL MODE. OR YOU CAN TRY USING ANY PHILLIPS/MAGNAVOX REMOTE WITH THE STATUS BUTTON AND TRY THIS.
PRESS MENU-9-6-5-2-STATUS AND YOU SHOULD BE IN THE SERVICE MODE TURN OFF THE HOTEL MODE
Jan 03, 2009 | Mitsubishi CS-35707 35" TV
Menu keeps showing on my TV
Your tv needs a software upgrade. This is usually done by a qulified service technician.
Nov 26, 2008 | Philips 50FD9955 50 in. HDTV-Ready Plasma...
42" phillips plasma
Hi There, Let's try to isolate the problem. Remove the battery from the remote control. With the battery removed from the remote control, let me know if the menu still appears. Thanks, Mike
Nov 04, 2008 | Philips 42PFL5603D 42 in. LCD HDTV
Televison & Video Logo
107 people viewed this question
Top Televison & Video Experts
Electro Med Services...
