Question about HP 530 Notebook PC
Im using hp 530 and when trying to re install xp
Im using hp 530 and when trying to re install xp it says set up did not find any any hard disk
    Guru:
  • 266 Answers
You need to change native SATA settings in bios. then you can install windows xp. The steps are below
  1. Turn off the computer.
  2. Press the power button and press f10 to open the BIOS Setup.
  3. Use the cursor to navigate the Configuration options to locate the Native-SATA setting.
    • If there is a SATA setting, select the Disable option, and then press F10 to save the change and restart the computer
Posted on May 05, 2010
HP 530 wont boot Windows 7 DVD
the 530 came with XP or vista,. never W7,
the HP support only supports those 2 OS, period.
F9 key boots to anything and DVD , the DVD-r is bad or the DVD drive is bad, why not boot to USB stick? if that works then the DVD is bad. (burned wrong or drive itself bad.see?
Tell us what media you are using? (WHO's from Where?)
tell us what you want to do:
1: run XP,Vista or W7, what?
if running XP or VISTA before, the F10 ( changed to F11 later)
F10 loads the OS fresh, off the working HDD, partition called the
HP recovery partition, this is how to get the 530 back as day one.
if you use a Microsoft media, it will be missing key HP drivers and will be missing all HP software. a fact.
again, where did you get your media.?
my guess, is you MADE it from DVD-R , right.?
using what ISO, from Microsoft or from HP?
using what method (I use Imgburn? free, and is best) ask how.
this PC is carbon dated at 2008, (1 more year of support left, hint)
be wise to download all the below so when HP deletes all this soon.
you have it.
or buy the HP media kit. and never need to ask for it again.
hp sells it. buy it. now. while still sold.
btw2, many DVD drives are bad, or need service or cleaning
and fail to read disks properly,for sure huge OS loads !
and when DVD does work , it takes 1/2 day to load windows
we use USB sticks today, that work all the time and run fast.
burn stick instead of the disk. and win.
we use RUFUS to burn the ISO to STICK. (ask, millions do)
then, F9 boot to the USB stuck called Udisk.
it boots fast and works. (at least installs fully)
if using MS, w7.iso, there is no guarantee it will work with all
drivers working on a 530.
you tell us...
the Microsoft w7 load will takes a license key ,
the bottom sticker on the 530 has COA sticker , for OEM XP or VISTA, (unstated by you)
only OEM Disks installs work with that sticker,
if you buy W7 , its called retail and can work if luckly , sans all HP software with it.
here is the official page. this works, every time.
but MS does not support it now, updates are dead. and more. at MS now. they ended it 3 years ago.. and Vista last month.
(yes, 1 patch was released for the In the news ciberattack)
https://support.hp.com/us-en/drivers/selfservice/hp-530-notebook-pc/3375953/model/3375995
May 16, 2017 | HP 530 Notebook
I want to re install xp but it says setup did not finf any harddi
It sounds to me like the reason your computer has crashed is because your hard drive has failed, or possibly that your boot sector is corrupted.
Try holding down the F8 key when you turn it on. A recovery screen should appear. A full factory reset will result in lost data. Just follow the instructions. If the screen doesn't appear, your hard drive is suspect.
May 05, 2010 | HP 530 Notebook PC
Hp 530 Notebook Recovery Disk errors, cannot start now. Error 1005 File:Windowssystem32winload.exe Status: 0xc00000f Info: The selected entry could not be loaded because the application is missing or...
If you trying to recover your pc from a recpvery partition on the hard drive, somewhere the recovery partions has had the file you need to process your request is missing. If you are using the disk that came with your system, you will need to perform a fresh install with formating your hard drive.
Aug 18, 2009 | HP 530 Notebook
Im trying to reinstal my drivers for notebook hp
Hello go here choose your OS and downoad the drivers that you need.
save it on your harddriver and double click on the downloaded file.
click next on the questions. thats all. restart computer after install of driver.
Jun 06, 2009 | HP 530 Notebook PC
Non-system disk or disk error
Your laptop isn't seeing your hard drive to boot up the system. You need to replace the hard drive.
May 29, 2009 | HP 530 Notebook
How to install windows xp sp2 on hp 530 laptop
Place cd into drive.Keep pressing enter until the computer reads the cd.Follow the directions on the screen. That is all their is too it. How did you get an HP without an operating system having been installed? thsi is a windows disk, correct? Not a reinstall disk?Should work the same either way.  If it gives yuo an error or doesn;t work please tell us what happened and we will direct you more. Thanks
http://h20000.www2.hp.com/bizsupport/TechSupport/Home.jsp?lang=en&cc=us&prodTypeId=321957&prodSeriesId=3375953&submit.y=2&submit.x=7〈=en&cc=us
Jan 19, 2009 | HP 530 Notebook
How to install windows xp on hp 530
xp could not recognized the sata hard disk during setup, u have to install stat drivers during installtion.
Nov 22, 2008 | HP Pavilion dv6000z Notebook
How to install xp on hp 530
You can try to change in bios show HD as ide native or something like that. If u install xp it gonna destroy your vista installation.
Jul 16, 2008 | Computers & Internet
Press F10 to enter BIOS setup...
find and disable the SATA native support
Now save and exit then when you reboot and attempt to install XP you will have no problem.
Download the drivers you need from here
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=3375995&prodTypeId=321957&prodSeriesId=3375953&swEnvOID=1093&taskId=135&swLang=8
Mar 11, 2008 | HP Pavilion dv6000z Notebook
HP 530 Notebook PC Logo
180 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
