Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
I left my refrigerator on during the winter months while I went to florida our heat had been turned off the freezer defrosted and all the food thawed out but beofre i returned it had all frozen again and the freezer seems fine any reason?
  • 4,793 Answers
As freezers are designed to operate from 10c to 35c,if the ambient temperature drops way below operating limits instead of freezing,the gas is actually warmer than outside and it will defrost rather than completely freeze solid.as soon as the lower limit (10c)is reached it will freeze again,unfortunately all the food is bad/unfit for humans/animals.although our local foxes love any food we put out.
Posted on May 05, 2010
Maytag 51105349JA refrigerator top freezer snowing up and won't stop running
Defrost thermostat, defrost timer or defrost heating element is bad. Because of that the evaporator is clogged with ice and the cold air cannot get to the fresh food section. Therefore the thermostat control doesn't get cold enough to turn off the compressor. On the other hand the temperature thermostat may be bad and stuck inn the on position causing the ref to operate continuously thereby defeating the defrost cycle. Uplug the ref and allow it to thaw completely. (24hours). Then while its quiet... turn the thermostat to OFF or 0 and then to the coldest setting and listen for a click sound. No click sound means bad thermostat. Later after thawing plug in refrigerator and observe function after 2 hours and check for cold air flow to the fresh food section. If the refrigerator appears to be okay... the problem is a defrost issue. Most typically a defrost thermostat is bad, but when behind the freezer panel is a good time to perform an ohm/ continuity check on the defrost heating element.
Feb 08, 2014 | Maytag Refrigerators
I have a viking Refrigerator Counter depth with bottom freezer. The condenstaion pan fills up and overflows every several months. Now the refrig. will not cool. I am not sure if they are related. Any...
i would defrost it first, while you are defrosting it clean the coils if it has them some fridges its incorporated into the outer skin of the fridge ,you want oil the fan in the freezer and make sure the (if it has ) coil fan is working.. wipe the inside down dry ,a fan helps speed things along during the defrost, cycles defrost can get screwed up if you have left the door open on the fridge,unscrew light bulbs and put them to the side(to see if this is part of the problem, instal them the next day.check switches to make sure they turn off ,door closed) or it is in high use in high humidity area,hot pans,food.. vikings are a kool product , but only do what there made to do. if you try to use this for food service (commercial) it's going to be a pain, viking makes ones for that app... hope this was of help..jay the electric motor repair guy in longwood florida
May 26, 2011 | Viking 36 in Designer Series Freestanding...
My fridge/freezer defrost itself last night and the freezing and frigde temperatures went low and my frozen food was all thawed
manually rotate your defrost timer maybe it stuck up and the contact was on the defrost heater. adjust your thermostat setting to coldness then observe unit.
Mar 05, 2011 | Refrigerators
My freezer is a frost free upright, there is a pool of frozen water on bottom shelf. The 2 glass shelves and back have a layer of frost. Some food is unthawed. I thought maybe door was left partially open,...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 31, 2010 | Refrigerators
Feezer COLD food compartment not cooling. It
the heat element or the thermostat IN YOUR FREEZER PART need to be check...they might went bad and when you defrost the unit it is working fine but only for period of time....:(
Dec 30, 2009 | Amana Easy Reach Plus ABL2037FESL...
Frig freezes the food and then thaws it out and then refreezes again
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 14, 2009 | Refrigerators
Freezer doesn't freeze in winter?
Domestic refrigerators nowadays are designed not to operate at temperatures less than 45 degrees. First, if it's 45 degrees in the house, people probably are not living there. 2nd, 45 degrees keeps food refrigerated. 3, if people are not living in a space, then they don't need to keep frozen food.
This is a result of the changes in refrigerants we've been going through since 1992.
If you want an outdoor freezer, buy one, and make sure it's designed to be used in a non conditioned space.
Jan 26, 2009 | Frigidaire FRS23KF7AB Side by Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
105 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
