Supra 5.1 Channel DVD Player SD75CR10 How to decode the region code so itt can be use for all kinds of cd dvd ?
SOURCE: UNLOCK REGION CODE FOR PHILIPS DVP3140 DVD PLAYER
thank you for help
Posted on Mar 08, 2008
Perfect!!!
Posted on Sep 01, 2008
SOURCE: Unlocking Code Required to make the Sony DVP-PQ2 DVD PLAYER MULTI-REGION.
sony dvp-fx811 - multiregion codes wanted
Posted on Dec 21, 2008
SOURCE: Samsung P480 dvd player- To Play all region dvds
how can I play *.mp4 files in samsung dvd player model no P480?
Posted on May 17, 2009
SOURCE: multi region code for philips hts 3090 dvd player
With your set on and without disc in the tray:
1. Press PLAY from your remote control
2. Press the following button sequence: 1590 2379 390
3. Press PLAY again
This will release the region verification in your home theater (region free). However, some DVDs (multiregion in particular) will not play, since they require region detection from the player unit.
I've done this to my 3090 and been using it like this for 3 years.
Posted on May 27, 2009
I bought my dvd player from Malaysia but I am using it in Middle East where I am currently residing. Initially, we are able to play all dvds (which we bought original) but suddenly, it kept popping a...
Are you using WMP or any third party players to play the dvds ?
I suggest you to check if the DVD region code is set to one (US) or not. If not, change it to one.
The region can only be changed five times, before its set permanently.
How do I change my DVD region?
DVD movies are encoded for different world regions, and your DVD-ROM drive must be configured for the appropriate region in order to play the DVD.
If you have DVD-decoder software installed on your computer, you can usually change the DVD region setting in the DVD decoder program. Follow the instructions in the program's Help file for changing the DVD region setting.
If you have a software or a hardware DVD decoder installed on your computer, you can use Device Manager to change the DVD region setting in your DVD-ROM configuration:
1. Click Start, right-click My Computer, and then click Properties.
2. On the Hardware tab, click Device Manager.
3. In the list of devices, double-click DVD/CD-ROM drives, right-click the DVD drive for which you want to change region settings, and then click Properties.
4. On the DVD Region tab, make the desired changes.
You must be logged on as an administrator or be a member of the Administrators group in order to change the DVD region.
Note that the DVD region for most DVD-ROMs can only be changed up to five times, and the number of changes still available is located on the DVD Region tab. If the tab shows that you can only change the setting one more time (Changes remaining = 1), you won't be able to play DVDs that use a DVD region that is different from your last selection. If you run out of opportunities to change the setting (Changes remaining = 0), contact your DVD-ROM's manufacturer to reset this value.
Also install DVD decoder as an issue with codec or DVD decoder could even cause the issue with DVD region code.
http://www.microsoft.com/windows/windowsmedia/player/plugins.aspx (Also applies to Windows 7)
Mar 26, 2011 | Vacuums
My samsung bd-c7500 dont play other dvd region than 3..i would like to unlock the dvd region to multi-region..how can i do that?
hi,
try the following
As I live in Kazakhstan my BD-C7500 is locked to DVD region 5. Just use the codes at the end of this tutorial for your own DVD region.
1. Ensure that there is no disk in the tray.
2. Switch the player on.
3. Wait until the main menu page appears and the player stops doing anything.
4. Press the REPEAT button - just above the TV channel selector at the bottom right of the controller - and enter 5 6 7 3 2 on the number pad.
5. The region code "3" should appear at the top left corner of the screen.
6. Quickly enter a "9" to make the player region free. (Just try pressing 9 on the remote controller until you see 9 appear in the upper left corner of your TV screen.)
7. Open and close the disc tray. Power down and power up again.
13. Play a foreign DVD to verify the change.
For people from other parts of the world, all region codes are as follows
1 - 2 9 3 3 4
2 - 5 7 5 3 8
3 - 5 6 7 3 2
4 - 7 6 8 8 4
5 - 5 3 8 1 4
ok
Jan 12, 2011 | Samsung BluRay Disc Player BDC7500 BluRay...
DVD-RAW does not read DVD. It is unable to find a DVD. Is it DVD problem or player problem?
I think I've just answered this question :-
It won't be a driver problem, DVD drives are generic, it will be either the drive has a problem, the dvd has a problem or your media player has a problem
1) Drive issue - does it player other dvd's - if yes, your drive is ok, if now you have a drive problem, try using a CD lens cleaner or a blast of canned air to clean the lens.
2) Disk issue, if just one disk doesn't play, then its a disk issue or data issue. Assuming the disk is clean and not scratched. Does the Disk have the correct country coding for your region. If not then you have to change the region setting on your DVD player
RMB My computer - Manage - Device manager - Optical drive - Properties - Regional settings.
Bear in mind most DVD player will only allow about 5 changes.
3) Media player, your current media player may not have the correct codecs to decodes the video files on this disk. Go to filehippo.com download and install VLC media player. This will play about anything and its free.
Nov 27, 2010 | Sony CRX320EE CD-RW/DVD-ROM Combo Drive
My driver is not working with DVD.it is unable to read DVD .
DVD player won't play DVD
Try downloading a DVD player such as uberdownloads. If the player still doesn't work, then look for an mpeg 2 decoder on the website for your video card manufacturer. If you are using windows XP check the region code on your DVD player that matches the region code on the DVD. This is done by selecting my computer, moving the mouse to your dvd player, pressing the right mouse button, selecting properties, and look for the region code. For the US use region 1.
Apr 08, 2009 | Gateway (5500778) Internal 32x CD-ROM...
Sony DVP-FX810 Portable DVD Player, region code 4 to mutiregion code.
1. Switch on the player
2; open the CD compartment
3. Enter the following code (using the remote): 2812
4. Highlight the region
5. Change to 9 (for Multi-region) using the 'Enter' button
6. Hit 'Clear' to exit
check with different region DVD
Sep 24, 2008 | Sony DVP-FX810 Portable DVD Player
DVD region is locked
There is no regional code setting for the DVD drives in laptops. This is all handled by the codec or DVD decoding software. You will need different decoding software or software that covers all the regions. I use Power DVD and have had no problems with some DVD's from France and Germany that a Friend of mine likes to watch. Ran into the region problem with home DVD players for his movies. Unfortunately, I'm only fluent in English, so I don't find them as interesting as he does. Try a different decoder, it should work. You should be able to find decoders or codecs at download.com
Aug 07, 2008 | Computers & Internet
DvD Player on PC
try and install decoder from updates of windows media player,and search for windows xp decoder ,and update ur windows
Mar 15, 2008 | Computers & Internet
Philips PET702/75
try this:
Press setup on the remote
Use the arrows to navigate to Prefreneces (pref)
type 9 6 5 3
Select Region code (press down arrow to set to 0, open for all codes)
Press setup again to exit
Feb 02, 2008 | Philips PET724 Portable DVD Player
What is a region code 2 dvd player
Most of the DVDs available in India mostly use Region 2, Region 4 and Region 5 codes, all together in one DVD.
Education on region dvd codes:
http://en.wikipedia.org/wiki/DVD_region_code
If you want something on the cheaper side try a Philips DVP5982 Multi-Region DVD Player.
hope that helps!
Jan 31, 2008 | Televison & Video
Televison & Video Logo
112 people viewed this question
Top Televison & Video Experts
