Question about Zanussi FLA1001W Front Load Washer
CLUNKING NOISE WHEN SPINNING SAME SOUND WHEN TURNING MANUALLY
  • 269 Answers
Have you tried turning the drum with belt removed to see if sound is from drum or motor.If you cant get at belt easy thru. top ( make sure power is off) then you will have to split the casing which will give you a great view of all the moving parts to see if any loose parts.It may be that the bearings have gone so badly that it is clunking as it turns.Normal bearing failure noise is a rumbling.
Remove 2 screws at rear underside of top lid and remove.On top middle either side by springs remove the 4 screws holding back panel,down below at rear there is normally 2 or 3 screws on corners of panel,now go to side of panel bottom middle by seam and remove round white plastic covers put small screwdriver in hole and pull out there is a screw behind each (8mm small socket).Now by water inlet valves prise out white plastic housing with valves still inside now put screw driver in spli on side panel either side and work it back you will have to hold down drain hose to clear panel,once off you can inspect for any damage or loose parts,check drum pulley is not loose or worn,check motor also concrete balance weights one on back top of drum casing and one at front around door seal,sometimes these come loose.To refit casing it is a reverse of removal.
Hopefully this will be helpful.
Good Luck.
Posted on May 06, 2010
Loud grinding/clunking noise when driving, lessens when I press the brake
Loud Noise Unknown Origin - Ask the GM Technician - GM-Trucks.com
www.gm-trucks.com > ... > Ask the GM Technician
Jun 30, 2006 - 7 posts - ‎3 authors
I get a loud clunking, grinding noise while turning to the right only, and ... I moved the passenger side tire to the rear driver side just in case it ...
can bad wheel bearing/hub cause loud clunking noises?
www.jeepsunlimited.com/.../showthread.php?...loud-clunking-noises
Nov 12, 2009 - 14 posts - ‎6 authors
driving home, i noticed some metal clunking sounds coming from the front driversside. at ... hmmmm....if it's grinding, then probably a bearing.
Front Clunking sound when driving straight. - TDIClub Forums
forums.tdiclub.com > ... > VW MKIII-A3/B4 TDIs
Dec 21, 2011 - I have a sporadic clunking noise from the drivers side front end. '98 jetta ... If I try to coast it gets really louder and more pronounced. ... whirring orgrinding could be several things: wheel bearing, brake pads due to a caliper ...
Quick Guide to Diagnosing Differential & Driveline Noises ...
Dec 26, 2015 | Cars & Trucks
Why is there a clunking noise only when turning hard left, e.g., when parking or making a U-turn?
sounds like your cv joint needs replacing on that single side if you are hearing a grinding# How are your anti roll bar bushes and drop links? It may be a combination of things rather than just the one. Clunking and grinding do not necessarily go together but might be a symptom of a single issue.
Maybe Fixya should set up a sound file facility so that we can listen to such sounds too!!
Jul 04, 2015 | 2005 Ford F-150
Loud clunking noise
check engine mountings and front ddie shafts
Dec 30, 2013 | Cars & Trucks
What could cause clunking sound on front left os car when turning into a dip?
Check the ball joints,drive shaft first for uneven and excessive wears.
Jul 22, 2012 | 2000 Lexus LX470
Sounds like a clunking noise, like the sound you hear when you have a flat tire, Tire isnt flat. turning right on the wheel lessons the sound but stays the same turning left. noise seems to be getting...
its a wheel bearing. .will need to be inspected to determine the correct one. Also tires could also do this if the steel seperated internally. Rotate the suspected tire to see if it follows the tire.
Apr 03, 2010 | 1990 Toyota Pickup
Clunking front hubs
usually the noise in the front end is the u-joints or cv joints out towards the tires.
May 21, 2009 | 1997 Dodge Ram 1500 Club Cab
2.2 95 cavalier front clunking noise when turning
Check your CV joints and then your struts.
Apr 27, 2009 | 1995 Chevrolet Cavalier
When turning steering wheel - either way, clunking sound.
Sounds like you have a bad CV joint, this will make a clunking or clicking noise like you described only when turning, and varies with vehicle speed.
Have it repaired before it breaks and leaves you stranded, or damages anything else.
Apr 02, 2009 | 2002 Cadillac Deville
Zanussi FLA1001W Front Load Washer Logo
162 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
