Question about Digi Konig tal Free-To-Air Satellite Receiver DTV Receiver
Konig DVB-T Scart 11 Digibox. Loss of Picture.
I inadvertantly changed LCN mode to off and immediately lost picture.Now can not get back into menu to change back to orignal setting.Picture is constantly snowy.How do I progress?
No instruction to set up the freeview box digihome dvb 915 can you help
Set up should be quite straightforward assuming you have all the bits.
You will need
  1. a standard co-axial aerial lead from your TV antenna to the female socket on the Freeview Box
  2. A scart to scart lead to connect the Freeview box (tv out socket) to the television.
If you wish to connect a video recorder or other equipment you may also need a second coaxial lead (male to female) for the RF through socket to connect to the aerial in socket on the video recorder.
If your TV does not have a scart socket you can connect the scart lead to the scart socket on a video recorder and then use the normal method of watching videos to view the Freeview TV pictures (here you may need to press the PAUSE button on your video recorder to prevent it going back into standby-mode after a few minutes).
Simply connect the box to your TV, turn on the power and the auto channel-scan will immediately detect and install all available channels.
If the Freeview box has been previously used in a different location / with a different TV transmitter you may need to re-tune it. Press the menu button on the remote control, scroll through the menu to set-up. Follow on screen prompts.
Feb 09, 2011 | Televison & Video
PICTURE GOES OFF AFTER A FEW SECONDS. SOUND OF TV
have youtryehave you tried going to menu options and turning off the power save you might try changing the scart cable any interferance will cause the tv to turn of. my little boy often knocks the scart lead on my set an the tv turns itself off when he does this ,. hope this helps good luck
Dec 11, 2010 | LG 42LG30 42 in. LCD HDTV
I used to be able to change picture mode (dynamic fixed) (standard) etc.. but now stuck on standard. I have lost the picture mode option and can't get it back to the brighter richer (dynamic fixed mode). ...
Go in the tv menu,right at bat u in the Picture mode go down the menu to reset push it.The Tuner board will reset it self.It will be set on the Dynantic fixed mode.And the AV mode button on the remote should able to changes back and fourth again Dynamic fix mode,Dynamic mode,Standard mode,User mode,Game mode.Not able to changes by pushing the remote button AV mode to changes,than ur Tuner board have problems,not working properly.
Jun 09, 2010 | Sharp AQUOS LC-52XS1U-S LCD TV
Lost picture
Sounds like you might be in "Air" mode and you want to change to "cable" mode. You are going to need to access the menu settings on the tv and change the cable input.
May 27, 2009 | Televison & Video
Lost everything visual, just audio.
Just enter the appropriate Menu-Setting (without a picture you´ve to do this "blind") - Press "Setup" - 1x key down (=video menu) - 1x key right (switch to sub menus) - 2x key down(=video format) - press select - key up (=interlaced) and press select again - finished!
May 05, 2009 | Televison & Video
Samsung le40a lcd - picture quality
Hi - I have some suggestions. The following factors effect picture quality:
1. Source (because LCD TVs have much higher picture quality than traditional CRT "Tube" TVs, the worse your source material, the worse it looks on a LCD TV).
DVD and Sky/Digital TV should look excellent on this TV when connected with a good quality Scart lead (nothing too expensive, but a Oxygen Free Copper Gold lead may help) directly into one of the TV's Scart inputs (avoid using "switching" boxes for multiple equipment).
Also, bear in mind that this is a HUGE screen (40 inches I think) and will REALLY show up bad source material.
The best advice I can give is, if you have HD-ready equipment use HDMI connections for everything (ideally with an HD-uplscaling DVD player which will "improve" the quality of standard DVDs on the TV - I recommend models by Philips) and check that you are in "Movie" or "Cinema" mode on the TV.
Make sure that all of your equipment, like your Sky digibox, is set to 16:9 mode (not 4:3) aswell to preserve the true widescreen aspect ratio.
Hope that helps!
Dec 31, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Philips digibox
I tried another digibox and got BW only. So it had to be the JCV TV. I rooted around and found that my s-video setting had changed. I don't know how, because it's an obscure menu item. I changed it back and all is well.
Andrew
Sep 30, 2008 | Televison & Video
Jvc lt40ds7bj
What model of DVD player do you have? The RF cable jacks on dvd players are only for switching the RF. All players always use AV input/output or Component input/output, the later is the best.
May 12, 2008 | Televison & Video
DVB not working on panasonic TX26 LXD52. Can't change channel nor access any menu's, guide etc when in DVB mode. Analogue tuner and av functions working fine. Remote works fine in analogue mode with...
Check the arial cable - not just the connections. Problem noted was due to an inferior cable that was not up to the job. It also ran alongside a central heating radiotor and pipes - not a good combination apparantly!
Apr 30, 2008 | Panasonic Televison & Video
Digi Konig tal Free-To-Air Satellite Receiver DTV Receiver Logo
309 people viewed this question
Top Digi Televison & Video Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Digi Televison and Video Expert? Answer questions, earn points and help others
