Question about Lexmark W820 Laser Printer
Thank you for your post. I'm getting FAN ERROR all the time on my W820. Any clues? Andy
  • Lexmark
    Lexmark May 11, 2010
    Usually, this problem needs service. But try this. Unplug printer from power source for at least one minute. Plug the power again. Make sure the printer is plugged in straight to the power outlet, bypassing any power strips or extensions. Check error. If problem persists, I suggest you contact your local Authorized Service Provider(ASP) or contact Lexmark Technical Support for further assistance.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • Lexmark Expert
  • 217 Answers
Main fan is defective, replace it by a new one.
Posted on May 07, 2010
How to reset a 915 fan error lexmark w820
You will need to replace the failed fan before you can clear the error. Part Number 12G4005.
Sep 01, 2014 | Office Equipment & Supplies
Toshiba 42TL515U -fan has stopped working
Check the fan. If found OK, check its voltage regulator circuit.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 26, 2014 | Toshiba 42TL515U 42 in. 3D TV
Lexmark w820--915 fan service error - intermittent!
This error occurrs after having *** with the printer. Please refrain from this activity
Oct 01, 2009 | Lexmark W820 Laser Printer
Lexmark W820 jamming at fuser? I have replaced the fuser and the pickup rollers in tray 1 and 2, the paper diverter in the output assembly because sometimes the paper would get caught in the teeth after...
Check to make sure that sensor is plugged in good at the sensor end and the logic board end. The printer uses that sensor to tell it that the paper has exited the fuser correctly, if it does not get a signal within a certain time frame it will give a paper jam error and stop printing. The sensor itself may be broken or the little plastic piece that you can see that is called a flag may be jammed so that it does not move to show paper movement. How far does the flag stick out? It should be about 1/8 inch out in the paper path, if less than that the flag is broken off and will need to be replaced. I hope this helps. If you need more info let me know. If this solves your issue than please rate my solution.
Thanks,
Buddy
Corporate Computer
Jun 17, 2009 | Lexmark W820 Laser Printer
Brother MFC 5840CN "Unable to Clean" Message
I have the same problem, and it just started today, how do I fix this problem?
Sep 02, 2008 | Brother MFC-5840CN All-In-One InkJet...
Color Printer fan error
The SMPS Fan Error is caused by slow or no rotation of the SMPS Fan. The firmware solution from Samsung disables monitoring so if the fan stops the printer will keep working. Thankfully, it's not physically hard to fix this issue though and can be done by removing 9 screws and using a little oil.
I've actually posted a step by step guide to fix this here.
Mar 25, 2008 | Samsung CLP-600N Laser Printer
Cpu fan error
POST troubleshooting steps. If a fan has failed (especially the heat sink fan for the CPU)
Good Luck, Please dont for get to Vote.Thank you.
Dec 16, 2007 | HP Pavilion dv1000 Notebook
Freezer doesn't work
Hi Andy you may have a bad (open) fan motor after unpluging the freezer check the motor see if you can turn it easly then unplug the motor and check it with an Ohm Meter. You should have continuity thru the motor.. let me know what you find out... krazytech
Aug 27, 2007 | Samsung RS2630SH Side by Side Refrigerator
Lexmark W820 Laser Printer Logo
210 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
