Question about Evga e-GeForce 6200 GeForce 6200, (256 MB) Graphic Card
Installation problems... I've tried going into my BIOS menu on start-up but my screen doesn't come on until my 'Windows Log In' screen comes up. Is there any way I can do this via command prompt or just with device manager? If now how can I get to BIOS?
  • 68 Answers
It's not possible through device manager or command prompt. Check your AGP slot whether it is clean or not. clean it with a soft brush as well as card's terminals. then notify me again
Posted on Mar 28, 2008
SOURCE:
During restore windows i found error "Windows could not complete the installation. To install windows this computer, restart the installation.
Reboot windows without any CD in drive and tap F8 key before windows screen appears. Select safe mode from the menu that appears and elect to do a system restore.
If this doesn't work you could try changing the boot order in the bios ensuring that your hard drive is first boot device. should get into bios when starting PC usually F2 or del key. remember to save changes in bios normally F10
Oct 13, 2012 | eMachines E730, Core i3-330M 2.13GHz,...
Dell latitude e4200 restarts with blue screen
Sounds like the image doesn't have the right drive controller driver included. Could be because the image was created on a different laptop or could be the drive controller is configured differently. You can confirm this from the STOP error code on the blue screen
Go into the BIOS setup (probably F2 at boot) and see if the controller mode is set to AHCI. If so, set it to compatibility or combined(?) and try again.
Either way, if you've installed an image for the wrong hardware, you probably should do a remedial install. Boot from your Windows XP disc and follow the prompts as if you were doing a clean install until you get to the license agreement. At the next screen, it should show you any existing Windows installs and give you a new option to repair. Let this go - it won't touch any user files, just replace all the Windows files with those from the CD. Have your system drivers and service packs handy to tidy up when it's done.
Apr 10, 2012 | Dell Latitude E4200 Notebook
Hi , my motherboard is k7n2 delta 2 platinum ms-6570e , i've had a problem to install windows xp , but finally i did it . Now i've got problem to install some programs like office , nero itp....
Hi, you can download the drivers manualy from here:
http://www.msi.com/product/mb/K7N2-Delta2-Platinum.html#/?div=Driver&os=XP%2032
The drivers or the bios file needs to be unziped before installation.
Install first the system and chipset drivers.
Try also to run windows update.
You will need the updates to install office and etc.
Try also to add more memory ( ram ) to your system.
Supports DDR200/266/333/400
Aug 24, 2011 | MSI K7N2 Delta2 Platinum Motherboard
I have acer 4741z, its having problem and already formatted hard drive, i tried to install win xp using installation cd, its running ok until the blue screen appear and struck there. How to install win xp,...
It is not a hardware issue. It is easy to install Windows 7 in your laptop but if you want to install Windows XP you have change the Hard Disk type to IDE. For that you have to change settings in your BIOS. After changing to IDE you can continue your installation normally as you done earlier...
thanks & regards
Anas K A
Jun 27, 2011 | Computers & Internet
Toshiba satellite a215-s4697 bios password shown when i start the laptop. please guide me how to disable the password from bios. if possible expalin through circuit
Easist way to disable he password is to, restart the Pc, as it is starting up hit F8 key repetitively until you get into the boot menu. Once in the boot menu, look for Start in Safe mode, Once you start the Pc is safe mode You should get to the log on screen, It should show 1 new user, Know as Admin- The password- If there is one will be, admin or admin doesn't work try signing in with out any password.Once logged in go to your control panel and the into User Acct and disable the Password! Hope this helps!
Best Wishes and Good Luck!
May 05, 2011 | Toshiba Satellite A215-S4697 Notebook PC
The voice and sound on my laptop is not working dell d10
Step 1 .Reset the default BIOS settings:
You can try resetting the sound default in the BIOS. Here's how:
1. Turn the laptop on. When the Windows logo first appears, press the F1 key or Dell key repeatedly until you see the BIOS setup screen appear.
2. Press the F5 key ( Setup defaults). In some other PCs depending on the manufacturer the BIOS at start-up will have one of the default options that have names such as - ‘Load Fail-Safe Defaults’ and ‘Load Optimised Defaults’.You will have to choose ‘Load Optimised Defaults’
3. Select Yes or OK, then press the Enter key on your keyboard.
4. Press the F10 key, then select Yes or OK to save the default settings. Press Enter.
5. Exit the BIOS and restart your system checking for sound.
( For most system's entering the BIOS will be the same but if it differs for your system, consult the operating manual for instructions on entering the BIOS.)
If this doesn’t work go to step 2
Step 2 . Configuring on-board sound in the BIOS:
The on-board sound setting in the BIOS should be Enabled. To enter the BIOS, turn on the laptop and when the first screen appears, press the F1 key /Dell key repeatedly until the BIOS Setup screen opens. Use the LEFT and RIGHT ARROW keys to select the Advanced tab. Press the DOWN ARROW key to select Onboard Audio Options and press ENTER. If Onboard Audio Options is not available, select I/O Device Configuration and press ENTER. If Audio Codec is listed, select it and press ENTER. Select either Enabled or Disabled depending on your configuration and press ENTER. Press the F10 key and then press ENTER to save and exit Start Windows and check for sound. If there is still no sound, continue to the next Step.
Step 3 . Reload the current sound driver
To do this, follow these steps
1.Click Start, type Device Manager in the Start Search box, and then press ENTER.
2.In the Device Manager dialog box, expand Sound, video, and game controllers.
3.Locate the audio device that was included with the computer.
4.Right-click the device, and then click Properties.
5.Click the Driver tab.
6.Click Uninstall.
7.Make sure that the Delete the Driver Software for this device check box is cleared, and then click OK.
8.In the Device Manager dialog box, click the Action menu, and then click Scan for hardware changes.
You should see a message that a hardware device is being installed. Additionally, the uninstalled audio device is now present in Device Manager.
9.Close the Device Manager dialog box, and then determine whether you can hear sound.
If that doesnt work and you have an installation CD, the audio drivers should be on the disk.
If you don’t have the CD go to your computer manufactures web page to search for updated sound driver software. Read the instructions on the download pages carefully
before installing.
If there are no updated sound drivers available, use Microsoft's Windows Update feature. Connect to the Internet and try the following items until Windows Update opens:
1.Click Start, and then click Windows Update (if it is listed).
2.Click Start, click Settings, and then click Windows Update (if it is listed).
3.Click Start, click All Programs, and then click Windows Update (if it is listed).
4.Go to Microsoft's Web site and click Windows Update from the Downloads menu.
Check if the sound works now….if it still doesn’t work then most likely the sound card might be faulty.
Feb 20, 2010 | Shuttle D10 - SFF - no CPU - RAM 0 MB - no...
RS482-M754 Warning!! Now System is in safe mode. Please re-setting CPU frequency in CMOS setup.
Shut down and start up the computer. As it's coming up immediately start pressing whatever is your setup key...could be F2..Delete...F10...whatever it is it should tell you on the screen as it's coming up..if not..just start pressing all of them until you get into the BIOS menu...if you see the Windows symbol come up you missed it...shut down again and try again...once you get into the BIOS menu...find where it talks about resetting your BIOS to factory Defaults...Select that and then exit and save...you should be good to go now. Were you trying to overclock your computer?
ASpecialty4You.com
Dec 20, 2009 | EliteGroup RS482-M754 Motherboard
The notebook tries to boot upon power up but simply shows the Windows XP screen scrolling by and does nothing else . .
The windows on your computer is cleary corrupt and no longer able to start up.
one way to solve the problem is to Use the restore discs or windows installation cd or dvd to install windows into the computer or perform a repair installation if a windows already exists on the computer and the setup can find it.
how to perform a repair installation
insert your Windows XP Setup CD, and restart your computer.
1.When the Press any key to boot from CD message is displayed on your screen, press a key to start your computer from the Windows XP CD.
if not then the computer is not set to start up from a cd, you can either enter the setup / bios to change that setting OR right when you power up the computer look at the screen it will say what button to press in order to enter boot menu or bios, it will very likely be button F12 or similar, it should say on the screen when you power on.
if it doesn't, then you need to go into the bios and change the boot order so that the computer starts from the CD first.
after that you should be able to start from the cd and install the OS (Operating system, eg.Windows)
here's some info on how to work the bios: http://www.whitecanyon.com/how-to-change-boot-order.php
Repeat step 1 when you have changed the boot order.
2.Press ENTER when you see the message To setup Windows XP now, and then press ENTER displayed on the Welcome to Setup screen.
3.Do not choose the option to press R to use the Recovery Console.
4.In the Windows XP Licensing Agreement, press F8 to agree to the license agreement.
5.Make sure that your current installation of Windows XP is selected in the box, and then press R to repair Windows XP.
6.Follow the instructions on the screen to complete Setup.
7.Ones windows is working you will need the drivers for your computer, they are at the makers website, for hp and compaq. www.hp.com for acer http://support.acer-euro.com/drivers/downloads.html for all other brands go to google and write Brand drivers. Should get you to the right place. Dell is most likely www.dell.com and so on.
let me know if you have any questions or if you need anything else.
Thanks,
Ekse
Jun 08, 2009 | Computers & Internet
Acer 1360 black screen cant get start menu
If you are getting a Blue screen repeatedly and you can't start up to windows in any custom setting ( from f8 start up menu ) one way to solve the problem is to Use the restore disc or windows installation cd or dvd to install windows into the computer or perform a repair installation if a windows already exists on the computer and the setup can find it.
this is for xp, but its similar on 2000 and on vista.
May 18, 2009 | Acer Aspire 1360 Notebook
Evga e-GeForce 6200 GeForce 6200, (256 MB) Graphic Card Logo
60 people viewed this question
Top Evga Computers & Internet Experts
Ekse
Thomas F. Schneider
Edward Easley
Edward Easley
Are you an Evga Computer and Internet Expert? Answer questions, earn points and help others
