Toshiba SD-V392 DVD Player/VCR Logo
Anonymous Posted on Mar 26, 2008
Incorrect Disc My kids were in my face and I put a DVD into the player on top of another DVD. I realized what I had done when I received the "Incorrect Disc" message. Now I can't get the DVDs out. Is there anything I can do??
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 27, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
315
Points
0
We removed the top disc by placing black electrical tape onto the top of the disc and gently pulling it out.
2004 Ford F150 rear entertainment system will not eject dvd, will play the dvd and will run when eject button pushed but will not eject the dvd any ideas on how to get the unit to eject the dvd?
The unit is connected by small set of gears that push tray /disc out. As tray comes out it either pushes disc out of slot or pops open door (depending on which style of face you have). If you have kids I would not be surprised if something is caught in between disc and face or jamming edge of door. (know this from own experience). The face of player can usually be carefully popped off by gently prying at corners. If you get face off you may be able to see if something is stuck in unit that does not belong, or see if a piece is broken loose near face. If unit has door that opens you can try using a slim but stiff piece of plastic and keep tension on door with plastic while hitting eject button. On some units there is a small hole on face that is manual release that ejects disc - even if no power. Usually takes a long straight push in hole (straightened paper clip or dental pick) and it manually pushes gear set to go out. So many of these units are different but most do have a manual release. Check owners manual to see if it shows a picture of face and possible release hole. Have had kids fight over changing a disc and pushed in on it while it was ejecting so it stripped gears, and had kid hang on ceiling mount unit that tore screen totally off. I feel your pain....
2helpful
I have a Toshiba DVD player SD K741. For the past few days, when I load the dvd, I receive a message on my TV screen "Incorrect Disc." What can I do to correct this?
incorrect disk error are common with the user putting in a disc that is not compatible with the player, in most cases it would have been a RW, that was written incorrectly. If this is not the case and it is a original disc you might want to purchase a cleaning dvd witch goes in and cleans the lens.
If that does not work then the unit's lens might be defective at this point.
1. Try other disc
2. try a cleaning disc
If those do not work then the issue is with the lens.
Thanks for your question please do not forget to leave a rating.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
DVD player won't read disc anymore
i had the same problem.
is the player done? or is there a fix?
Incorrect disc, err when disc is put in,
it is not recogonizing it
meaning you might have a blu-ray instead of a reg dvd
2answers
Incorrect disc message
You might try using rubbing alcohol and a q-tip on the lens to clean it.
2helpful
I am receiving a message on the dvd that says: bad disc DVD VCR-DV1040 Dr. Ross
Hello have you cleaned the laser with a laser cleaning disc ? otherwise take the top off and get a clean cotton bud and put a small amount of white spirits on it and clean the laser when you have done this use another clean cotton bud and wipe off any exess fluid if any.
Does it play anything eg cd's or is it always saying bad disc ?
1helpful
2answers
DVD player - ERR
error in any disk i put in!!!!!!!!!
3helpful
3answers
DVD recording or playing.
Where can you find the 1-2X DVD, I have only been able to find 1-4X and none of these work.
1helpful
8answers
Incorrect disc and bAd
I have the same problem, reads bad, won't play, took the top of a blow on it, alot, hoping dust would come off the lens, it did. Works now, also ran a disc cleaner in to after.
Have another dvd palyer, never had that problem, Philips.
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
