Question about Maytag 24 in. MDB9150A Built-in Dishwasher
Electronics problem with Maytag Dishwasher
I've posted a couple of times. I have a 7 year old Maytag Jetclean Dishwasher (MDB9150 AWQ). Recently, it was not emptying properly. I cleaned out the hose under the sink, pressed "drain/off" and it emptied properly into a bucket. I then re-hooked the hose, and tried to run a light cycle ( to freshen it up). All it does when I press a cycle button is blink "clean" and "heated dry" simultaneously. The only button that stops the blinking is the "drain/off" button. I tried switching off the circuit breaker to hopefully reset it, but that didn't work either. Can you help?
  • micromaster
    micromaster Mar 26, 2008
  • 142 Answers
The outlet pump may have become clogged, try removing and cleaning it.
Posted on Jan 27, 2009
SOURCE:
Have a maytag dishwasher MDB6600 AWQ -latch/handle broke - bought replacement but not sure how to install - can you help
Just did this myself .Need the right star screw driver to remove 11 screws holding the door inner liner
then you can access the handle latch assembly. You pull off the 2 wire connectors to the switchs that are part of the assembly. Slip connectors onto new assembly.Position the handle part thru the door and re attach inner liner. 2 of the inner liner top screws also hold the assembly in place.Unfortunely , this didn't solve my problem of the dishwasher not turning on.
Jan 06, 2011 | Maytag 24 in. MDB6600A Jetclean II...
How to secure a Maytag dishwasher to undercounter?
There are a couple of tabs sticking out at the top... you take small screws and run them through the tabs and into the countertop...
heatman101
Aug 27, 2010 | Maytag 24 in. MDB6600A Jetclean II...
Maytag jetqueen door leak
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
dfg
Jul 06, 2010 | Maytag MDB9600A Jetclean II Built-in...
Control panel lights blinking
I have the same dishwasher with the same problem, try pushing the delay/resume button, then the drain/off button. When the lights go off start your wash cycle.
Sep 17, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Hear the motor running, no water in dishwasher
I thought I would fix this myself - but hubby took a look, wiggled a few wires and said 'there's your problem'. The water valve would not open because a connecting wire was loose. It was the kitten after all - I'd better pop that panel back on.
Feb 07, 2009 | Maytag MDB9600A Jetclean II Built-in...
Maytag Jetclean problem
Hi!!! 10 years is alot for a dishwasher..You could have a plugged drain pump.Check your drain pump.All make sure that the water inside your dish water is hot inside it should read over 100 plus..Good luck..
Jan 03, 2009 | Maytag MDB9600A Jetclean II Built-in...
I can't get my dishwasher to start
try pressing normal wash, then heat dry normal wash then heat dry normal wash then heat dry. do it 3 times
Jan 27, 2007 | Maytag MDB9600A Jetclean II Built-in...
Maytag 24 in. MDB9150A Built-in Dishwasher Logo
682 people viewed this question
Top Maytag Dishwashers Experts
Mike
Marvin
Marvin
Vitally Alcher
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
