Question about Linksys Wireless-N WRT150N Router
Wireless-N WRT150N Router: typed in 192.168.1.1 in address bar and it ask for...
Typed in 192.168.1.1 in address bar and it ask for user name and password..but i dont know what it is...is there an overide or something?
  • 212 Answers
The default login is admin for both user and password. If it has been changed and you don't know it, you can do a hard reset which will wipe everything and return it to factory settings. This would mean you would have to but all your settings back in, including ISP passwords etc.
Posted on May 05, 2010
Where do i find the password on the wireless router?
Its very easy and very simple.
follow these steps to get your router Wireless password.
Fist find out Default Gateway of your computer
Click start>>run then type CMD in run box>>>Hit Enter>>it will show you a black dos window>>type there ipconfig>>>now look for your default gateway IP Address.
It could be 192.168.0.1 or 192.168.1.1 or somthing else.
Type your Default IP address Into your Browser Address bar >>Press Enter>>it will ask you for user name and password to Access router page>>User name could be Admin and password could be password
OR
it could be Admin and Admin and if it sill not accept it then You can also call your Internet Service Provider to know what is your user name and password for router.
Once it accepted the user name and password you will the Router Page open.
Now you look for Wireless option and click on it there you can see your Wireless Security Password.
If you still have any difficulties to know your router Wireless Password then My best Recommendation would that You can get help from you internet Service provider and they will definitely let you know that What is your Router Wireless Password.
Cheers!
Aug 04, 2011 | 2wire (1000-400108-001) Router
Programa Para instalar un router
I only speak english.
You want a program for installing your router. You do not need one. The software that linksys provides is more trouble than it is worth.
In your browser's address field, type 192.168.1.1
User name : admin
Pass : admin
You can configure the router now.
May 07, 2011 | Linksys WRT150N Wireless N Router -...
In my browser address bar i typed 192.168.1.1. when prompted i left user name blank and typed in the default password to my router 'admin'. I cannot get access to change my security pin from the...
You need to factory reset the router by holding down the little button on the back of the router (use a paper clip to push it). After doing so it will reset the password to the default which is admin.
May 06, 2011 | Linksys WRT54G2 Wireless Router
I have to router plugged up right but its still not working wireless, what should i do?
Use an Ethernet cable to connect the network-port on your computer to one of the 'LAN' ports on the router.
Then, access the web-server "inside" the router, and login to the router, and run the "Wireless Networking Setup Wizard", to configure the wireless adapter:
* set an SSID -- your "network-name"
* set an encryption-level -- use 'WPA' or 'WPA2'
* set a password
Then, use the SSID/password on your wireless device(s).
Mar 28, 2011 | Belkin N150 (F6D4050) 802.11g/b Wireless...
How to hook up the Linksys Wireless-N WRT150N Router to DSL?
Connect the dsl modem to port on the router that says Internet
connect 1 pc to any available port on the router(1,2,3,4).
Open your browser and type 192.168.1.1 in the address bar
It will prompt for a username/password window. leave username blank,password admin. Press enter
Normally if you have dsl, you need to set the internet connection type to pppoe and put in your username and password that your ISP provided you. then save the settings.
Oct 04, 2010 | Linksys Wireless-N WRT150N Router
I NEED TO KNOW HOW TO SECURE MY LYNKSIS WRT150N
To secure your router wireless signal Your Wireless signal may already be secured by the manufacturer and often the wireless code is printed on a label stuck to the router itself
IF not already set here is how you secure the wireless Connect your PC to the router with a cable to one of the LAN connections - Now you need to Log into the setup of the router - to do that open a web browser, use Internet explorer (some routers setup pages do not work correctly with other browsers) In the browser address bar - enter the Router’s default IP address, 192.168.1.1, in the Address field. Press the Enter key. A screen will appear asking you for your User name and Password. Leave the User Name field blank. Enter admin in the Password field. Then click the OK button.
Now you can goto the wireless section or secruity section and set the type of encyption to WEP, WPA, WPA-PSK etc and then make up your own password.
On the PC Double click on the wireless connection in the system tray (bottom right hand side of screen) and then connect manually to your wireless signal - you will be asked for the password you set in the router.
Now you are connected.
Apr 13, 2010 | Linksys Wireless-N WRT150N Router
I need reset user and password of WRT300N wireless
Access router properties through your browser (Refer manual) and access U/N and P/W, simply change / exit / done.
Dec 24, 2009 | Linksys WRT300N Wireless Router
Lost codes
On the back of your router there is a reset button, hold it down for 3o seconds or so, this will reset the router back to factory settings, the default user name and password would be admin, note that sometimes with the belkin you only need the user name and not the password. Usually you need admin/admin though.
The default IP address to access the router when its reset is 192.168.2.1
Hope that helps
Aug 25, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
Security
Hi!
You may follow this article to secure your wireless network.
Before following the article, open your browser first and type in 192.168.1.1 on your address bar and hit Enter. You will then be asked for a username and password. Default login (no username) for your router is admin. If it doesn't work, use the password you've used when you've ran the router setup CD.
Just reply if you have any questions.
Jul 06, 2008 | Linksys Wireless-N WRT150N Router
Linksys Wireless-N WRT150N Router Logo
164 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
