Question about P3 International IonizAir P4620 Air Purifier
IonizAir P4620 Air Purifier: R1 is fried. What do I replace it with?...
R1 is a 5 ohm resister. 1/2 watt was used. If it fried go to a higher power rating. It limits the current to the high voltage transformer.
Posted on May 09, 2010
I cleaned purifier plate and filters and purifier still won't workon my fresh air machine
The air purifier filters which need to be washed lose their efficiency very fast and need replacement every few months . I think its time you switched to a better air purifier like this with superior filters which last longer and can be cleaned using a vacuum cleaner Premium Air Purifiers with e2f technology
Oct 22, 2014 | Air Purifiers
I have a Eqoquest fresh air air purifier, I had a flood and water was inside unit, insurance company wants to know cost to repair or if needs to be replaced, where do i go to get it deemed...
The simplest way is to do a Google Search for you make and model air purifier. You'll be able to see what they sell for now. I can tell you this though, if that unit was under water, it can't be repaired. It's been contaminated.
Feb 11, 2011 | Ecoquest Fresh Air Air Purifier
My ionic breeze quadra air purifier keeps turning on and off. I have cleaned the fins, what else can i do?
Hi.
The filter will probably need replacement. Ionic breeze purifier are not being manufactured anymore because of heath concerns. Parts are also not distributed anymore.
I suggest replacing the ionic purifier with a different air purifier.
Please read the article below:
Ionic Breeze Health Concerns
Regards.
Ginko.
Sep 08, 2010 | Sharper Image Professional Plus Ionic...
IS THIS PURIFIER REALLY WORKING IS IT a hepa or carbon filter?
Most particles in the air are neutral in charge. Meaning they have the same amount of negatively charged electrons, and positively charged protons. A common type of air purifier uses what is called corona discharge air purifier. These type of air purifier create molecules called ions. When particles pass through these air purifiers electric current makes these particle either positively charged or negatively charged. Once these "ionized" particles from the air makes contact with objects that are opposite of thier charged, they stick to them instead of lingering in the air, or they may clump with other particle untill they are too heavy and fall to the ground. Filter types air purifier are not so good since they require periodic filter replacement. These type of air purifier are usually part of the air conditioning system. The purifier picture I see are the ones i just mentioned, and they are not filter types.
Nov 25, 2009 | Sharper Image Professional Plus Ionic...
Ionic breeze gp just stopped working
Hi.
I don't know if you are still trying to repair the air purifier.
About your Ionic breeze purifier, I wanted to report that they are not being manufactured anymore because of heath concerns. New model built from 2008 use a completely different technology. Parts are also not distributed anymore, and the new Sharper Image does not provide any support for the old model.
Regards.
Ginko.
Sep 28, 2009 | Sharper Image Ionic Breeze GP SI730 Air...
Ionizeair "check" red light is still on after cleaning
these things are junk. you could also be doing more harm than good to yourself and the indoor air quality in your home with the amount of ozone these appliances omit into the air. throw it away
Aug 19, 2009 | P3 International IonizAir P4620 Air...
Install Plate Displayed
Call toll free 1-877-710-0057 and they will gladly help you.
Jun 03, 2009 | Ecoquest Fresh Air Air Purifier
Ionizair Model: P4620 Problem
The blades come out of the top and can be cleaned gently with detergent for dishes and a soft bristled tooth brush.
Nov 26, 2007 | IonizAir (AR3397) Air Purifier
Replacing uv lamp in Ecoquest air purifier
Hi FCfogl, Here's you answer. Go to the URl below for detailed instructions with pictures. http://www.airpurifierrepair.com/PageInfo.aspx?page=ReplaceUV Hope this helps
Sep 25, 2007 | Ecoquest Fresh Air Air Purifier
Wire not connected
There was a problem with some older Fresh Air units where the wires would corrode and break off. Your problem sounds like this happend to your machine. It is not difficult to fix. If you still need to have this fixed, contact me and I will tell you how you may still be able to get this repaired for free under the factory warranty. I can be reached at theashleygroup@ecoquestintl.com
I hope that this helps.
Sincerely,
Vita-man
Aug 17, 2007 | Ecoquest Fresh Air Living Air Purifier
Air Purifiers Logo
153 people viewed this question
Top P3 International Air Purifiers Experts
Are you a P3 International Air Purifier Expert? Answer questions, earn points and help others
