I lost my site the name change for linksys and I
I lost my site the name change for linksys and I'm not able to connect to internet wireless.
  • Computers & ... Master
  • 2,263 Answers
You will need to check the wireless settings of the router.
If your network is secured then make sure that you are typing the correct network key.
also make sure that the DHCP server is enabled on the router.
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Posted on May 05, 2010
How can I get the router IP of my Linksys 2.4GHz broadband router?
The Linksys G router gives you both wired and wireless connections over a broadband Internet connect to create a local area network. The Linksys router is compatible with wireless G and B devices, through the 2.4-GHz wireless band. The wireless speed is at 54 megabytes per second and you can get 100 megabytes per second with a wired connection. You have to set up the wireless configuration on the Linksys before using it on your network.
Plug the router's power cable into an electrical outlet. Attach an Ethernet cable into the Internet port on the back of the router. Connect the other end into your broadband modem. Connect your computer to the Linksys G using another Ethernet cable. This Ethernet cable can go into any of the wired router ports. Open your Internet browser. Type "192.168.1.1" in the address bar and hit "Enter." This is your router's IP address and the home of its Web configuration page. Click "Wireless." Click "Manual." Alter your SSID, also known as your network name. You can change this name to any value that you want. You can also change the wireless channel if you are in an area with many wireless connections that may interfere. Click "Save Changes." Click "Wireless Security." Choose an encryption method to encrypt your wireless transmissions. WPA or WPA2 are common security protocols you can use in wireless networks. Input a network key, also known as the network password. Click "Save Changes."
Setting Up WPA Wireless Security on a Linksys Wireless Router http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&vw=1&articleid=3696 Wireless G-Broadband Router support http://homesupport.cisco.com/en-us/wireless/lbc/WRT54G b> b> Changing the Wireless Network's Name (SSID) on a Linksys Router http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&vw=1&articleid=4037
Mar 27, 2013 | Linksys Wireless-G Broadband Router
How do the cables connect? Which cable goes where?
Step 1:
Connect the broadband modem to the router's WAN or Internet port.
Step 2:
Connect the computer to any available numbered port (1, 2, 3 or 4).
NOTE: In this example, we'll connect the computer to port number 3.
NOTE: It is advisable to connect the computer to one of the Ethernet (1, 2, 3 or 4) ports when setting up the router for the first time. If you have successfully configured the router using a wireless computer, unplug the Ethernet cable which connects the computer to the router for you to have wireless Internet connection. For instructions on how to connect the wireless computer to go online using the Linksys router, click here.
Step 3:
Make sure the power adapter is plugged in to an available power outlet.
3678-005.png Step 4:
Check if the corresponding LEDs on the router are lit. For instructions, click here.
Related Articles:
Accessing the Router's Web-Based Setup Page
Setting-Up WPA Wireless Security on a Linksys Router
Setting-Up a Router with DSL Internet Service
Downloading at Linksys by Cisco Support Site
Nov 12, 2010 | Linksys Wireless-G WRT54G Router
My Linksys router went off, and when I tried to reset it, it reverted to the general linksys name on the wireless networks but I still can*t connect to the internet wirelessly, only if I use a direct cable...
If you have power and you can connect via Ethernet cord no the router is ok.
You will need to set the wireless settings correctly in the router setup page.
instruction set here:
1.Log into router. Using either 192.168.0.1 to 192.168.1.1 in a browser window that is ( internet Explorer or Firefox)
2. Verify wireless router name( on the computer) >>> ( on/off) ( router status window)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address. This set up in the "security tab" in the router. using 192.168.0.1 or 192.168.1.1 to access through a browser.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
8. check for firmware update at the manufacturers site for your model router
Oct 11, 2010 | Linksys Wireless-G WRT54G Router
How do I change the name of my wireless connection? I have the Linksys WRT54G and right now it says Linksys. I want to change it so that I can tell which connection is mine. Thanks.
All Linksys routers have a web interface to them. You should be able to go to http://192.168.1.1 or something similar (see your manual) in Internet Explorer.
Once you’re in your administrator panel you can setup the name of your wireless network, and I would recommend that you flip on some type of security as well so, your neighbors/coworkers don't get to play on your connection!
Hope this helps!
Jul 07, 2009 | Linksys Wireless-G WRT54G Router
Linksys wireless G router not working when connected to dsl modem
hey there, can u acces the gateway of the router
192.168.1.1 than enter ur login & password
than reset the router to fabric setting when done go back in the router and configure it as u like to have it
Jan 04, 2009 | Siemens SpeedStream Modem (4100) (SS4100)
I've forgotten my password
DOH! Sorry to hear that! Unless you can remember it, you'll need to reset your router to the factory defaults, which will unlock your password. Your router should have a tiny button on it you'd typically use a ball point pen to depress, which resets it to factory defaults.
Some routers, like linksys, don't have an actual user name so be sure you're leaving that blank. If it is a linksys, the default username is blank, and the password is admin. You'll want to change that quickly and I recommend writing your password in sharpie under your router if you're the forgetful type.
Dec 18, 2008 | Linksys Wireless-G Broadband Router
Linksey wireless-g usb adapter and router
lose internet connection from my second computer that is linked to main computer (main computer has internet connection). Tried to click repair and it said couldn't be repaired contact internet provider?
Nov 01, 2007 | Linksys Wireless-G WAP54G 802.11g/b...
Lost Password to router
Hold the reset button on the router for 30 second, do not let go of it after the diag LED turns off, continue holding it until 30 seconds have passed. After you?ve done this, the router will revert to factory defaults, all of your settings will be lost. By default the default Password for the router is admin, and there is no User Name.
Feb 16, 2006 | Linksys EtherFast Cable/DSL and Voice...
1. Right-click on the icon in your taskbar that represents your wireless Internet connection.
2. Select "Open Network and Sharing Center." 3. Click "Manage Wireless Networks."
4. Click the icon that represents the wireless Internet connection you are trying to recover the password for. Select "Properties" from the toolbar.
5. Select the "Security" tab. check the "Show Characters" box to display the password for that particular wireless Internet connection.
Get instant Linksys router support at http://www.vtechsquad.com/linksys-router-support/ to fix Linksys router problem.
Feb 16, 2006 | Linksys BEFSR11 Router
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
