Question about Canon imageRUNNER 5000 Copier
ImageRUNNER 5000 Copier: how to set a password for ir 5000...
How to set a password for ir 5000
  • 1,219 Answers
under User mode ( round button with * ), choose ID management. The rest is yust the reading from panel.
Pls. rate
Posted on May 10, 2010
I need photo coppier "
I would recomend You the two second hend refurbished iR 3300 Copier ( B&W ) or Ricoh AF 1045/2045 and color clc 3200 for color, for the beginning and if you want later take stronger 50ppm i.e. IR advance 6055 for B&W and IR ADVANCE C2030L.
Hope that helps!
Jul 27, 2011 | Canon imageRUNNER 5000 Copier
Canon ir 5000 erorr E 000004 - 0000 How to fix it ?
in this order press additional functions, 2 and 8 simultaneously, additional functions. This takes you into service mode. Then press copier, function, clear, error, then ok. turn machine off with the side power switch and back on.
May 24, 2011 | Canon imageRUNNER 5000 Copier
ImageRUNNER 5000 Copier: I own a Ir 5000 and i just started getting "tire t...
Try to clean corona wires, pick up, feed and separation rollers, check drum cleaning blade and fixing assy.If the tracks are white, check also the toner unit
May 17, 2010 | Canon imageRUNNER 5000 Copier
The IR 5000 does not have a port to connect to the LAN
You will need to add Print Option to the machine first, then upgrade to network firmware on the hard drive of the copier.
Jul 16, 2009 | Canon imageRUNNER 5000 Copier
I have no manual and I need to figure out how to scan on this machine. Canon Imagerunner 50001.
Download the network scangear from the canon web site.
Install the scangear on all the computers you want to scan to.
On the scangear tool there is a discover icon,click that icon and wait till the ir 5000 is picked up by the network.Select the machine in the scangear tool.Now you will be able to scan to mirosoft word and exel like you normally do with a scanner.
If the scangear tool was unable to discover the machine,the network settings of the IR must be checked.
Hope this help.
Mar 09, 2009 | Canon imageRUNNER 5000 Copier
Canon 500IR - Error Code E000602 0004
Is your copier a IR-5000 or a IR-550? It dose not really matter - the code means that the hard drive in the copier is not "Booting Up" correctly. Are you a service tech? If so, you can try to reseat the boot rom and clean the contacts with rubbing alcohol. After you turn the copier Off and then back On after you reinstall the boot rom. You can also try to do a HD chk in service mode. You will most likely have to replace the "HD" and have it "Flashed" to your copier configuration. Good Luck....
Feb 17, 2009 | Canon imageRUNNER 5000 Copier
Hello can you really help me solve the error code that i getting on my IR 5000 the code is E000012-0000
That error means that you have a problem with the drum motor. Check the it's connectors. Or maybe something keeping the motor from running, like an uptwisted blade with drum.
Dec 25, 2008 | Canon imageRUNNER 5000 Copier
Ir 5000
saya bisa bantu, tapi lokasi kerja mas dimana????
Dec 12, 2008 | Canon imageRUNNER 5000 Copier
Canon imageRUNNER 5000 Copier Logo
538 people viewed this question
old marine
old marine
