Question about Mtd 22" Yard Machine Push Mower
22" Yard Machine Push Mower: The pull is won't pull and it seems that the engin...
The pull is won't pull and it seems that the engine is locked. What can I do to fix it?
    Top Expert:
  • Mtd Master
  • 12,744 Answers
Check under deck and make sure blade not bent or something bending it-if good try to move blade back and forth if stuck solid than at pull cover look for any screws or bolts loose in area jamming movement if good internal failure possible valve/crank or piston damage
Posted on May 05, 2010
Tecumseh 4.5 hp engine won't start
First thing to check on a Tecumseh; pull the half inch bowl nut (main jet) out of the bottom of the carburetor. Give it a good cleaning with carb cleaner then pay special attention to the teeny tiny hole that is right at the very top of the threads. It's so small you can hardly see it and if it clogs, your mower won't start. Best of luck to you.
Oct 29, 2011 | Mtd 22" Yard Machine Push Mower
I borrowed my Brothers Tecumseh Yard Machine Push Mower to mow my lawn but the pull cord wont pull. Is there a saftey or something i dont know about ?
There is a little bar up by the handle that you have to pull back toward the handle, this is the dead man lever. When released it will stop the mower by grounding out the ignition coil and braking the engine.
If this is not the problem, then let me know.
I hope this helps.
Aug 09, 2011 | Mtd 22" Yard Machine Push Mower
How much oil goes in a 22'' inch MTD yard machine push mower
Most normal push mowers require 20 ounces of engine oil. I recommend that you use only SAE 30 oil and try to use synthetic.
May 01, 2011 | Mtd 22" Yard Machine Push Mower
I have a Yard Machine Lawn mower by MTD it has a briggs and stratton engine. The pull cord pulls, to easily I might add, but will not start the lawn mower. It doesn't seem to engage the motor. What might...
If you think the rope pulls too easily the engine may not have enough compression. Consider doing a compression test or a leak-down test on the cylinder.
Oct 23, 2010 | Mtd 22" Yard Machine Push Mower
MTD Yard Machines 22'' mower, pull cord won't extend
From what you describe it sounds like the line may be tangled, remove the rewind housing in order to inspect the line up close.
Jun 03, 2010 | Mtd 22" Yard Machine Push Mower
Oil coming from line from engine feeding into air
More than likely your air filter is clogged and needs replacing. If that is the situation the carb needs air and is pulling suction on the crankcase breather tube siphoning up oil instead of just burning the vapors. If it was a busted ring the oil would be coming out the exhaust and burning blue smoke.
May 01, 2010 | Mtd 22" Yard Machine Push Mower
Carbaeurator problems - 22" Yard Man push mower
That is the intake tube. You have to remove the rewind starter housing and the armature (what the sparkplug wire is hooked to) and unscrew it. IfI knew the engine model and type numbers, I could tell you the part number for the tube. They are located around the spark plug and stamped into the cover. Model-Type-Code.
Jun 18, 2009 | Mtd 22" Yard Machine Push Mower
Pullstring pulled back...HARD..to engine
You have a partly sheared flywheel key that is making engine out of time replace flywheel key
May 06, 2009 | Mtd 22" Yard Machine Push Mower
What kind of engine oil does an MTD 22" Yard Machine take?
All engine makers use 30 weight oil in their engines except for kohler...they use 10W30.
May 02, 2009 | Mtd 22" Yard Machine Push Mower
Replace pull rope
Yes, take the shroud off that the recoil is riveted to
Apr 15, 2009 | Mtd 22" Yard Machine Push Mower
Mtd 22" Yard Machine Push Mower Logo
117 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
