Question about Fahrenheat Electric Convector Baseboard Heater, 3'
Fahrenheat F25408 Electric Baseboard Heater noise
Two 8' heaters newly installed are making a humming noise each time the heat comes on. How do I eliminate the noise?
  • 1 more comment
  • Anonymous Jan 10, 2009
    I have same problem, its Saturday and no one is available from company to call or ask questions and no web site. I bought this at home depot and plan to return it right away. POS. This was advertised as "Quiet installation" the old one I took one was noiseless. This is a piece of garbage, home deopt should be ashamed to sell it.
  • turansky Mar 24, 2009
    I installed a 8 ft baseboard heater 3/23/2009 and it was humming whgenever it went on all night? I have more to install and may just take them all back to Home Depot if there is no solution.
  • whenwebuild Apr 02, 2009
    I have both a 30" and a 96" Fahrenheat standard electric baseboard heater. They
    are wired to the same dedicated 208/240V circuit with 12-2 copper wire using unit mounted thermostats connecting the load side to the red wires on the
    thermostats as per the manufacturer's instructions. They both seem to work fine,
    except that the 96" unit makes a noticeable humming sound when operating and the
    30" unit does not. How do I get rid of the hum?
How to wire this unit
Posted on May 31, 2008
    New Friend:
Check model and voltage of heater to be sure your heater voltage is compatible to the voltage supplied.
Posted on Oct 26, 2009
SOURCE:
Heater makes noise humming sound is this normal i replaced 3 8ftrs they make the humming sound the smaller 6ftrs and3 ftrs dont make a sound ?????
This is perfectly normal. This is caused by the heating elements sagging over time. In my years of doing this I have seen this many times before. If yours is new then it may just be a mount loose. Turn it off and check the mounts on in inside of the unit. UNPLUG IT FIRST!!!
Jan 26, 2011 | Fahrenheat Electric Convector Baseboard...
I have two 8ft baseboards and they make a slight humming noise. Is this normal?
the humming noise is normal. parts of the element and fins are vibrating in its holder(s) - the electric when flowing through the coil sets up a small magnetic field.
Dec 22, 2010 | Fahrenheat (F2548) Electric Baseboard...
IS A HYDRONIC ELECTRIC BASEBOARD MORE EFFICENT THEN THE STANDARD ELECTRIC BASEBOARD HEATER
I have some confusion about what you are asking......
There is no such thing as "Hydronic Electric Baseboards"......
I am assuming you are referring to the oil filled baseboard heaters. If so....
The same amount of btu's required to heat a space remain the same whether the elements heat a liquid to warm the air or whether they heat the air directly, the same amount of wattage will be consumed. So, their is no more or less efficiency between the two.
If you are referring to "Hydronic Baseboard Heaters" (these baseboards are fed from a boiler with a pump) Then....I will assume that it is a gas boiler. In which case, the gas boiler would be more cost efficient to operate. If it is an electric the same rule applies as above......the cost is the same.
Oct 04, 2009 | Fahrenheat FBE15002 Baseboard Heater
Electric baseboard heater hums while running
is a 60 cycle hum, resonating with the power. check screws that mount it nothing to really worry about
Dec 31, 2008 | Fahrenheat Built-In Baseboard Thermostat...
Fahrenheat baseboard heater
no this is normal for this type of heater during its run time,I hope this makes you feek a little better!
Oct 24, 2008 | Fahrenheat Built-In Baseboard Thermostat...
You need a meter, it will be hard without this! If you have 220v in the wall, then think of it like this; each wire is 120v. Test to each other, you get 220v. The thermostat is a double pole, you said. So think of it like this, its an adjustable temperature controlled switch that lets electricity through at the temp. you set it at. If you have 120v from one wire connected to one end of the element, and the other 120v connected to the other end of the element, then it will work. DO NOT CONNECT THE 120V TOGETHER. IT MUST GO THROUGH THE ELEMENT FIRST. The thermostat should be between the power from the wall and the element, to control the temperature.
Jan 05, 2008 | Fahrenheat FBE15002 Baseboard Heater
Smell
the heat may be affecting the unit's paint. normally the oil used in manufacturing burns off the first time the unit is used. maybe the proximity of the element to the case is too close.
Dec 19, 2007 | Fahrenheat Electric Convector Baseboard...
How do I wire up my fahrenheat F25408 baseboar heater?
Baseboard heaters are easy to hitch up. You can have a wall mounted thermostat or an integral thermostat. The diagram I have is for the integral thermostat. Follow the diagram and it should work.
Nov 28, 2007 | Fahrenheat Electric Convector Baseboard...
Fahrenheat Electric Convector Baseboard Heater, 3' Logo
2,199 people viewed this question
Top Fahrenheat Heating & Cooling Experts
Paul Carew
Thomas F. Schneider
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
