Question about AO Smith SQ1152 Pool Pump Motor
SQ1152 Pool Pump Motor: orientation of switch...
Orientation of switch
  • Rich May 11, 2010
    could you give a bit more detail please?. what switch are you reffering to ? how are yuou wishing to install it?
  • Rich May 12, 2010
    Could you please explain what you mean by switch orientation. Thanks
    Problem Solver:
  • 19 Answers
Rotary or stationary?
Posted on May 18, 2010
How can I get the screen to rotate over to the correct position?
You might have your Orientation Lock on. If you are using iOS 7 or 8, swipe up from the bottom and disable Orientation Lock (http://cdn.osxdaily.com/wp-content/uploads/2013/10/stop-screen-rotation-orientation-lock-ios-7.jpg)
Alternately, the switch on the side of your iPad might be set to Lock Rotation, so go to Settings > General and see if Use Side Switch To: is set to Lock Rotation. This would mean that whenever the switch above the volume controls is down, the orientation is locked.
Sep 30, 2014 | Apple iPad Tablets & eReaders
How do I unlock orientation? No screen.
To unlock the screen orientation on iPads, you can normally use the side switch (over the iPad volume button), unless you has set this side switch to control the Mute On/Off.
If the side switch controls the Mute On/Off, you can change it in
1) Tap Settings > General.
2) Under Use Side Switch To, select Lock Rotation instead of Mute.
Jul 24, 2014 | Apple iPad Tablets & eReaders
I want to change papar orientation from landscape to portrait. I changed it in paper tray but paper orientation in printing does not changed. plz guide.
Dude, changing paper orientation on paper tray is just one step, while you must change paper setting on printer driver too. In some machines, you should change paper switch position too :)
Sep 30, 2013 | Toshiba EStudio 223 Copiers
Change drive orientation
what orientation are we talking about? CDROM and DVD Drives work sideways and horizontally, notice the plastic holders when you open your drive door, the cd/dvd won't drop to the floor...
No action is required on your part, everything will work as normal?
Any question? let me know.
Jan 18, 2013 | Dell Precision T3500 Computer Workstation...
Canon ir3045n - when printing the paper orientation has switched to landscape. How do we change it back to portrait?
Hello Donna,
To change the orientation of the printer from landscape to portrait follow these simple steps;
- open any document and go to print from the file menu
- when the printers settings window opens click 'properties'
- In the next up coming windows you can see menus like 'main, page setup, effects' profiles
maintenance etc.
- click 'page setup'
- There you can see 'page size' and 'orientation'
- change the 'orientation' from landscape to portrait
- click ok and print
Done : )
please rate if this solution was helpful for you, thanks you!
Jun 23, 2011 | Office Equipment & Supplies
What is the iphone lock symbol with circle arrow around it?
Orientation lock. This means that the screen will not switch between portrait and landscape mode when you rotate the phone.
To enable/disable orientation lock:
  1. Double-press the home key
  2. Slide the icon bar to the right
  3. Press the (lock)/(circle arrow) logo to toggle the lock mode
Mar 30, 2011 | Apple iPhone Smartphone
Ever since I downloaded Apple's latest iPad update my orientation lock has become a mute lock and I can't stop my orientation from moving. Any ideas?
In order to use orientation lock with the new update:
  1. Double-click the iPad's home button, bringing up the multitasking menu with all programs you are currently running.
  2. Swipe your finger to the left while in the multitasking area.
  3. The orientation lock is now controlled through a software feature rather than the physical mute button.
  4. Tap the orientation lock icon (circular arrow furthest to the left) to engage it.
  5. In this menu you can also quickly change brightness settings and music controls.
A new feature rumored in iOS 4.3 (the next iOS iteration) will allow for the iPad's user to set whether the physical button controls orientation, or act as a mute switch.
Feb 20, 2011 | Apple iPad (16 GB) WiFi Tablet PC
The machine keeps changing the orientation when you place the papers to be copied on the glass. how can you pick the one you want?
enter additional function(*); on screen, select copy settings>auto orientation> off>ok.
switch off the machine and re start.
place original according to the orientation of paper in paper tray and make copies.
Feb 08, 2011 | Canon ImageRUNNER 3235 Black and White...
Volumne no longer working for all apps on the IPAD 3G. Tried the force quit, soft reset and the rest under Settings and still not working.
In the latest software update, the orientation lock switch was changed into a mute switch. Do you have it on mute? This could well be the problem! Try flicking it and see if you can adjust the volume then.
You can still lock the orientation in the latest software by double-tapping the home button, flicking right and tapping the lock button. In future versions of iOS, you will be able to choose what the switch does to suit your preference.
Hope that helped!
Dec 23, 2010 | Apple iPad (16 GB) WiFi Tablet PC
Orientating my Screen after I switch into tablet mode.
You can press the Orientation Button located in the right bottom corner of screen. It is marked with two arrows following each other in a circle.
Moreover, you can set as default the screen orientation you desire in Tablet Properties.
Also, remove the battery for 10 seconds and reinsert. This will enable auto orienting of screen.
Jan 13, 2009 | HP Pavilion tx2500z Notebook
AO Smith SQ1152 Pool Pump Motor Logo
123 people viewed this question
Top AO Smith Plumbing Experts
David Baisa
Lawrence Oravetz
Gil Shultz
Are you an AO Smith Plumbing Expert? Answer questions, earn points and help others
