Question about HP Pavilion 510c PC Desktop
Pavilion 510c PC Desktop: it wont boot ...it will come on but it will then g...
It wont boot ...it will come on but it will then give me an error message
  • 2 more comments
  • SmashinIsFun May 11, 2010
    What exactly is the error?
  • Guru Saini
    Guru Saini May 11, 2010
    there are many error messages.. whts the error message ur getting.. troubleshooting depends on the type of error u have
  • Awadhoot Jog May 11, 2010
    what is the error message IF it is "MLTDR not found" youwill need to reinstall windows there are many error message plese clarify yours
  • Guru Saini
    whts the error message.. we can proceed further after that
    Scholar:
  • 62 Answers
Hi if u get an error message after u log on to the desk top then u need to go to start ?run ?type msconfig? (do a clean boot )this is how u do? go to the startup tab click on disable all ? click on apply ?go the the services tab then check the box that says hide all microsoft services?then click on disable all ?u might get a message that access is denied dont worry click on ok and then close the page.It will prompt u to restart the computer ,restart it and then check u should not get the error message .Then u need to go to the same screen by typing in msconfig and then u need to find the program that is causing the error to come up .First enable all the startup items restart the computer and then check for the error if it does not then uncheck alleast 4 programs restart the computer and then check if u get the error or not so this way you will have to find that particular program that is causing the error to pop up and once u have found it just uncheck that particular program .
all the best
Posted on May 06, 2010
I have a HP d5100t wont boot
You will need to give a bit more information..
does it come on but display nothing on the screen ??
does it show things on the screen but windows wont load ??
is it not coming on at all ??
There are a lot of things that can cause this and I'll need more information o help you.
Dec 29, 2012 | HP Pavilion Elite d5100t ATX PC PC...
I bought a new HP Pavilion a4313w-b Desktop PC. Plugged all connections in and green light is on and put the CD in and it won't install. Can you give me step by step instructions?
Operative system wont boot?
You need to set your bios to your primary boot device is that cd/dvd rom .
You can also do that by pressing F12 on your keyboard and selecting your CD/DVD drive.
Apr 16, 2010 | Compaq Pavilion ZT3280US Notebook
Chkdsk runs for 24 hours and never finishes. How can I fix my hard drive? My computer is running very slow. I use System Mechanic Professional to check my computer and it wants to perform a chkdsk the next...
The time that the 4th level takes is completely dependent upon the SIZE of the disk. That level is a datacheck. Each block of the drive is checked. If you have a 300GB drive, that will take some time as each block is read/written/read a number of times.
Is there a specific issue you are trying to address or is this a preventitive measure?
Dan
Apr 15, 2010 | HP Pavilion 510c PC Desktop
All i get is operating system not found
You have a problem here--sounds like you have a bad hard drive.
Your Windows installation could have gone bad. If so, you can repair it by booting from a Windows disk.
I believe your hard drive is working or you would get a "no boot device" error.
So--boot from an installation disk, choose "r" when asked.
If you are given the opportunity to choose a Windows installation, choose yours (probably #1), hit enter after it asks for a password, then type chkdsk /p and see if it will fix your problem.
Feb 01, 2010 | HP Pavilion 510c PC Desktop
Forgot password need to reset jumper pins
just remove ur battere cmos and then replug it,,,,u can easy remove all password and reset configuration into default setting
Jan 15, 2010 | HP Pavilion 510c PC Desktop
None of the Microsoft suggestions correct error #0x80072F8F and allow me to get updates
search for updates manually. especially for installer 3.1 install it and restart your computer. Check Services and make sure windows automatic update service is set to automatic and started. Check time and Date and download the latest version of internet explorer from microsoft site. Install it and it will automatically update many root certificates for your windows. Set the security setting of internet explorer to default level and finally try to use update application of windows. It should work.
Sep 07, 2009 | HP Pavilion 510c PC Desktop
Black screen error boot manager missing
sometime system restore wont work other solution might be to pop in your Xp or Vista cd assuming thats what you have.... and shut the Computer off and back on at start up during the first screen usually press F8 a couple times and select Option A and try the first option it gives you after that and continue down that list if it don't work then a reformat is the solution usually...
Jul 26, 2009 | HP Pavilion Media Center m8425f 2.66GHz...
My hp 510c desktop won't power on. the led on the
Hi, you need a new power unit, cheap and easy to fit, the blinking is likely to be the lan connection which is not powered from your pc
Jun 26, 2009 | HP Pavilion 510c PC Desktop
Hp pavilion 533x wont boot up
Hello!
REinstall the windows operating system, don't forget to install the driver after installing the OS>
melnavz
Mar 06, 2008 | HP Pavilion 533w (P9859AR#ABA) PC Desktop
HP Pavilion 510c  PC Desktop Logo
139 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
