Question about Remington R-9190 Electric Shaver
R-9190 Electric Shaver: The razor is used 20 seconds a day and used to go ...
The razor is used 20 seconds a day and used to go months between chargings and would eventually slow down indicating a charge would soon be needed. Now 4 years later it will not last 7 days (2 minutes useage) and will abruptly go from perfect performance to not starting at all - just overnight. is it the battery? I assume they can be changed. Or do we have something else going on? Plugging it in or recharging it seems to solve the problem of it not even attempting to start so I suspect it is not a switch problem.
  • Remington Master
  • 1,602 Answers
The problem is almost certainly the batteries. You can access the batteries by removing the screws on the back and taking off the back cover. You will find batteries at shaveroutlet.com. You will need two batteries. See link below
http://shaveroutlet.com/shaver-battery-pack-for-most-shavers-p-211.html
Posted on May 08, 2010
How Long Should My Shaver Battery Last?
It depends on the razor. If you have a non-rotary razor, go in diagonals, against the grain and in small circles. If you have a rotary, like a Norelco, larger circles and straight up/down. I find it hard to get all the hairs so, I also use a regular razor blade in the shower and just do my neck.
Aug 16, 2014 | Philips Norelco 8175XL Electric Shaver
Tip
How to use an electric shaver
If you are a using an electric shaver for the first time, I hope that this article will get you going. Proper techniques will ensure the best, closest shave possible. Maintaining the razor by properly cleaning and recharging it will also ensure that the razor works correctly and does not malfunction during use. Proper care and maintenance of the electric razor will also ensure that the razor will last for years to come. Consider this article as a shaving-best-practices template for your first electric shaver.<br /> <br /> Firstly, clean your face and dry it. Electric shavers do a better job when your face is clean. Turn the electric razor on and begin shaving against the direction of hair growth, moving the shaving head linearly and in circles. Circular motion Stretch the skin with your other hand to make the hair stand up straighter so the razor blades shave closer.<br /> <br /> After shaving, turn it off and rinse the cutting heads under warm water. You can also use jet clean system once a week to clean your shaver. Make sure that you charge it for the time specified in user manual. Overcharging may cause damage to the battery.
on Mar 03, 2011 | Health & Beauty
How do I get the razor to charge. It doesn't last more than 10 seconds. I've only had the razor for about 2 months
If the chafing light acts normal, and you still can't use it for a short time after charging, You should go back to the store. A battery should last at least one year. But if the razor was in the store for one or more years, without any charge, the battery can be bad already.
Please try charging a few times, but is the battery keeps running low in a few seconds or minutes, go back to the store with it.
Jun 25, 2014 | Remington MS2-390 Electric Shaver
What is an electric shaver?
Not like shaving razors, electric shavers work by shearing the whiskers, the hair enters the perforated metal heads of the shaver and is cut by the moving blade inside.
Feb 06, 2013 | Health & Beauty
Whats the symbol flashing on Philips HQ 9190 CC Smart Touch XL
This indicator signals that time has elapsed and it is due for a replacement of the shaver heads. You will find replacement heads for model HQ9190 at shaveroutlet.com. See link below.
http://shaveroutlet.com/norelco-philips-hq9-replacement-heads-p-252.html
Once you have installed the new heads, you will need to reset the indicator. You will find this information in your user manual. If you no longer have your user manual, you can view it using the link below
http://download.p4c.philips.com/files/9/9190xl/9190xl_dfu_aen.pdf
Apr 08, 2010 | Philips SmartTouch-XL HQ9190 CC Electric...
Shaver won't hold a charge, can battery be replaced?
Yes, you can replace the rechargeable batteries in your shaver with a few basic skills. If you can disasseble the shell case and have access to a soldering iron, you can remove the old faulty batteries and reinstall the replacement ones. Not only will you save a ton of money, but you'll have your trusty shaver running like new quickly!
Here's a link to Electric Shaver Service's battery page that has your battery listed (R-9000 series) for around $15.00 plus S&H.
http://www.electricshaverstore.com/search.asp?p=1&w=%5F&c=battery&t=s
I've done this on my own razor twice in the past 10-15 years and it's still less expensive than buying a new razor, since I really like the shave I get with mine.
Hope you find this Very Helpful and best regards!
Aug 16, 2009 | Remington R-9190 Electric Shaver
How do I open the Remington 9190 Electric Shaver to replace the battery?
Remove the Two ( 2 ) Phillips Head screws on the Back side of the
R 9190 shaver near the Electrical Plug .
Pry off the Gray Rubber cover that those two ( 2 ) now removed screws went thru.
Now remove the Two ( 2 ) exposed screws up near the " Trimmer Switch "
Note: If you Popped off the " Trimmer Switch " during your efforts - DON'T WORRY . It will simply pop back in place when you are finished with your repairs.
Jun 21, 2009 | Remington R-9190 Electric Shaver
How to open for battery replacement
Found this link that may help you out. Seems like they are made to be used then tossed out. What a waste. Anyway the battery replacement issue is a common problem... http://k0lee.com/2008/04/replacing-remington-and-norelco-shaver-batteries/
May 25, 2009 | Remington R-9190 Electric Shaver
Remington R-9190 Electric Shaver Logo
140 people viewed this question
Top Remington Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
SHARCNET-USA
SHARCNET-USA
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
