Question about Kenmore 79012 / 79014 / 79019 Gas Kitchen Range
79012 / 79014 / 79019 Gas Kitchen Range: The propane converson seems to be done right, howe...
The propane converson seems to be done right however when we turn on the oven orange flames comr up throught the slits on the side. What can we do ?
    President:
  • 949 Answers
It sounds like during the conversion process a step or two may have been missed.
The gas orifice for the main oven burner is most likely to large (was not converted to LP), or the air shutter on the burner was not adjusted. I would not use the oven with the flames that way.
There should be instructions with the installation instructions on how to convert the oven, basically on most oven burners the orifice is screwed down (tightened) until the flame is the right size, then the air shutter on the burner is adjusted for a blue flame.
Let me know if you have questions
Posted on May 05, 2010
How to change from natural gas to propane
Hi Rodney.
the main change from natural gas to propane is that propane has a bit higher energy content than natural gas, so you may heat things a bit faster. The particulars will depend on your specific make and model of range, but, for instance, with my KitchenAid gas range, the primary difference was getting a slightly different connection orifice made to give proper propane flow and pressure. The install kit may also have listings for necessary delivery pressure ranges from you propane source. If the range is built in, it might be a bit of a pain to get at the gas connections, and it's best done by a professional who will know the proper fittings, seals, and pressure tests to do to make sure you aren't leaking gas all over your kitchen.
That said, it's likely not a particularly big deal.
Good Luck!
D
Nov 24, 2015 | Kitchen Ranges
Change from propane to natural gas
In Australia ANY gas conversion MUST be done by a qualified gas fitter. May be enquire to one of these.
Apr 02, 2012 | GE JGSP23 Gas Kitchen Range
I have a ge Profile propane range.at times I get a smell of propane near the range.we checked the connections at the back of the stove & they seem to be fine.the smell seems to be stronger at times as...
Open up the range top and check the piping connections right up to each burner. Use soapy water and a small brush to do this safely. Chances are you have a leak. J.
Jul 05, 2010 | Maytag MGR5770 Gas Kitchen Range
HOW TO CONVERT IT TO GAS PROPANE?
Your propane supplier can re-jet your stove to accomodate propane. Give them a call ... they will probably do it for little or no charge.
Jul 06, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Gas cooker
Probably. Speak with your propane supplier about what will need to be done with your stove.
May 03, 2010 | Belling DB2 Dual Fuel (Electric and Gas)...
Maytag Range Model MGR5870 how to convert to propane
set the regulator to propane and change the orfices to the blk ones. copper is for nat gas / black for propane .. thanks hope this helped .mm
Dec 22, 2009 | Maytag MGS5870 Gas Kitchen Range
Can I replace the natural gas jets with propane jets?
Hello. Yes. This is commonly done. You will need the conversion kit suited to your brand and model. Contact your propane provider as most times, they have these kits in stock.
Nov 20, 2009 | Amana AGDS902 Gas Kitchen Range
Top burners are propane. we are used to propane heating really fast. this stove seems really slow. 5minutes to boil litre of water. burners are having hard time lighting.
If it is new fromt the factory, you many have the natural gas (methane) jets in the burners. You will need to check your bag of parts to find the propane parts (LP parts). LP jets allow a different fuel/air mixture to burn at the right heat. Check the owner's manual for details how to make the change.
Please rate me - Good luck.
Nov 20, 2009 | Frigidaire PLCS389DC Dual Fuel (Electric...
CHANGED ORFICE FITTING ASSEMBLY ,NOW FLAME IS YELLOW AND SMELLS.
hi!!! It seems that you have poor gas combustion..It your are changing it too propane make sure you installed them correctly and that the orfice are the right ones for that machine..If yes remember propane gas does smell and flame is yellow..Good luck..
Jan 03, 2009 | Jenn-Air PRD3630 Dual Fuel (Electric and...
Kenmore 79012 / 79014 / 79019 Gas Kitchen Range Logo
485 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
