Question about Comfort-Aire RADS-181 Air Conditioner
Im looking to purchase this model or the rac183 model i need to know the fla though to size breaker
  • 674 Answers
There should be a name plate on the unit that gives that info.
Posted on May 05, 2010
Ive looked and looked online,,,,can anyone send me a interior fuse box diagram,,the cover is gone on mine and im having a few issuesw Im trying to trace
http://www.bbbind.com/free_tsb.html Enter your vehicle info. year , make , model and engine size . Under system click on electrical distribution ,then under subsystem click on fuse panel . Click the search button .Then click the blue link . Good luck , hope you find what you need .
May 02, 2017 | Ford Cars & Trucks
What will be the pixel or size of tarpaulin when i used gimp?
I don't know if this will help and all and I had to search up what tarpaulin and a few things came up and I honestly dont know how big you wan't it but Im going to give it a try
1 pixel = 0.0008680556 feet
But if im wrong I would just search it up on google for converters, Im sorry im not much help even though I use gimp daily
Apr 02, 2015 | GIMP GNU Image Manipulation Program
I have to wire my Macon 025ZA swimingpool heat pump,it is 15 ft from electrical panel,which wire to use and breaker,do I need gfci or not,need to get 220V power,use neutral or not.Thank's
What size is the heat pump and how many amps does it draw on full load amps. There should be a label on the unit that states "FLA" and/or "LRA." That is important because it determines the size of the wire you need as well as the size of the conduit. You would use a gfci breaker and the neutral wire plus a ground.
This needs to be done correctly, because water and electricity do not mix well when people are near it. Let me know.
Aug 03, 2011 | Heating & Cooling
WHAT IS THE MAX AMP DRAW?
Max amp draw refers to the total amp draw of a unit , example : Compressor RLA 25 Amp, blower motor FLA 5 Amp, and condenser fan motor FLA is 1.5 amp , you add all three and get 31.5 Amps
which is your max amps, this is used in determining wire gauge and breaker size for unit.
This should help.
Jul 27, 2011 | Heating & Cooling
I was wondering if the stock Brembo wheels from other years or engine sizes would fit my 02 M620 Dark ie?
Yes im sure some would, but i cant tell you exactly which years, im guessing a few years either side of your model. First they must be the same size, eg, 17 inch, 19 inch, then you would just need to measure the width of the wheel hub and axle, mabey play around with the spacers, im sure it is possible, but best if you can look at and see the other wheels before purchasing them.
Jun 13, 2010 | 2002 Ducati Monster 620 i.e.
Have no weld or power output from a miller starfire 2e, will give very small spark on electrode, but nowhere near enough to do anything, any ideas? brushes are new, cleaned slip rings, checked diodes on...
did you check the breakers im talking about the ones on the unit either switch or push button you can only reset them so many times what happens is there like a set of points in an old chevy they start to get pitited bigger the pits the less power you get less amps are produced just because the reset dosent mean they are giving 100 % you can bypass one and see what happens to that drill you should be happy with the out come zaper fla
Apr 24, 2010 | Hammering
I have a cutler hammer switch box that takes care
Is the motor new or old? Is this a recent problem or has it always been that way? What is the motor used for? Does the motor start and stop a lot, or does it run continuous? Is it constantly under load? Is this residential or commercial use? Approx.how long is the circuit? What size wire and breaker are being used? Does it kick out when it starts or while it's running?
The FLA (Full Load Amps) for that motor is 22 x 1.25 = 28 amps. In GENERAL, a motor like that usually requires a minimum #10 (THHN or THWN) wire on a 30 amp breaker. However, NEC does permit up to a 70 amp breaker (250% of the FLA) if the 30 amp breaker is not sufficient for starting.
Remember that it's the built-in motor overloads that protect the wire. Best practice is to use the lowest size breaker possible for ground fault protection that will still allow the motor to start. A 40 amp breaker would be permissible.
On the other hand, if the circuit is very long, you need to increase the wire size to #8 or larger.
If this is an old motor that didn't have this problem before with your current setup, then you may need a new motor, and increasing the breaker size is not usually the solution, at least not without a qualified electrician actually seeing and evaluating the situation first.
Dec 16, 2009 | Cutler Hammer Electrical Supplies
Sometimes compressor breaker is tripping. Breaker is 88A and compresssor FLA is 95A. Is this correct and if it is what could be the reason for tripping. Checked the wire connections, comressor windings and...
Breaker is to small , if the full load amps of the unit is 95 amps , to correctly size the breaker to code multiply the full load amps by 175% minimum and 225% maximum. A 200 amp breaker is the size breaker that I would recomend for this application.
Aug 03, 2009 | Heating & Cooling
Breaker trips on roof top RV A/C
check your breaker is it hot to the touch?
check the wire tightness at the breaker?
remove the circuit breaker and inspect the terminals on the breaker and in the panel and the breaker itself for signs of overheating and discoloration due to the fact
check the connections at the unit itself
check that you have proper voltage to your unit
find the nameplate and look for FLA full load amp draw
is the breaker properly sized for the unit and is the wire size correct for the breaker?
(Check nameplate on unit)
buy a clamp on amp meter and see if it is under or over the nameplate rating when unit is running
take great care when you venture into electric,if you arent comfortable find someone who is.
you may have a weak breaker if all the above pass?
Replace it
Jul 05, 2009 | Dometic Rooftop RV Air Conditioner
Need info about circa1950's Rockwell/Delta 8" jointer
I can't help you with the knives, but I can help you with the motor - you need to find the plate on the motor with its specs. If it has a horsepower rating, just replace with the same horsepower. If it doesn't show a horsepower rating, I need the amperage (FLA), and the voltage, I can determine it from that. Please get back to me with both the horsepower rating and the voltage and FLA if you can, and tell me what voltage you are going to hook up to.
Mar 16, 2009 | Masonry Tools
Open Questions:
vulcan bonaire comfort control External natural gas electronic ignition 2004. ISSUE: Fan blowing only cool air continuously. Forced to kill power to stop it. model is one of the following. MB514E,20E or 30E. Going by mech drawing parts list. i can confirm what type of sensors i have cleaned with very fine sandpaper. flame sensor PN 5441603SP and IGNITER ELECTRODE PN 5441602SP The fault code i see is described as the following. There are x4 LED's. Sequence Left to Right. LEGEND: 1 Flame Sensor 2 Pressure switch 3 OverTemp 4 Diag. R Red G Green S Solid Colour B Blinking LED Behaviour. In order 2RS & 4GS Until i hear ignition. 2RS & 3RB Duration: split second 2RB,3RS & 4GB Duration: split second 3RS & 4GB Duration: Until it has completed blinking x4 times. 3RS Duration 4 seconds Repeat last two mentioned behaviour. in my own opinion, as a safety feature, the unit thinks that it has overheated or is about to. so kills the gas and force feeding cool air to heating components to save it from frying. Does this mean i have fault 04 if so does this mean i may have a faulty igniter or flame sensor or maybe a faulty as described in the mech drawing SWITCH OVER TEMPERATURE 120 degrees celsius. Am i correct here? Is this the over temperature cut out switch? if no one can really pinpoint which part requires replacement, can you at least, in sequence advise which parts to purchase? so then ill just try my luck. i wonder how to properly test if flame sensor, igniter, over temp etc is faulty with a multimeter. do i just perform a continuity test. I wonder what other parts can i test related to this fault im getting.
Jul 22, 2018 | Vulcan Heating & Cooling
See all Comfort-Aire RADS-181 Air Conditioner Questions
Comfort-Aire RADS-181 Air Conditioner Logo
112 people viewed this question
Top Comfort-Aire Heating & Cooling Experts
Cesar Quant
Cesar Quant
Tim Whalen
Are you a Comfort-Aire Heating and Cooling Expert? Answer questions, earn points and help others
