Graco Stylus Morocco Travel System Stroller Logo
A
Anonymous Posted on May 05, 2010
Stylus - Morocco Travel System Stroller: how do you fold stroller down to fit into car?...
How do you fold stroller down to fit into car?
lilbilz_daws
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 04, 2012
lilbilz_daws
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
242
Points
Please help me i really need your help on how to fold it down i am only 9 and i need to fold it down . i have this pram cause i have a dolly called sophie
Anonymous
Level 1:
New Friend:
Teacher:
An expert who has written 2 tips or uploaded 1 video tip.
  • Contributor 20 Answers
  • Posted on May 05, 2010
Anonymous
Contributor
Level 1:
New Friend:
Teacher:
Answers
20
Questions
0
Helped
6305
Points
33
Hi
Please visit www.buggypitstop.co.uk/ they will advice you in this matter,i refered a friend and she is quite pleased.
thanks
3 Related Answers
Anonymous
  • 105 Answers
  • Posted on May 18, 2009
SOURCE: fold and lock stroller
The handle twists after you press the red tab on handle, there should be a red little flap than is the way to hold collapsed. A bag???? buy a hockey duffel.
Anonymous
  • Posted on May 24, 2009
Hi! I have the same stroller as you do, the way to lock it once folded is, you should see a red plastic loopedy thing down by the front right side of the seat. This hooks onto that weird brown plastic nubb i'm sure you've seen on the right side of the handle.
Hope this helped!
Mattie
MTal
  • Posted on Dec 07, 2012
SOURCE: graco alano not folding? the push and twist handle not turning??
Took a while but finally figured it out. Original thinking was that the problem is in the handle twist and release mechanism. The problem actually lies in the collar where the unit locks into place. If the stroller is in the open position it can't be fixed unless it's folded up. To open stroller without the twist handle -- locate both black spring loaded collars where it locks into place (approx outside where the seat and seat back meet). Manually pull both the collars up the shaft. The spring is tight and it may take an extra set of hands to get the right leverage. Once the unit is in the folded position -- flip the stroller upside down and blast WD-40 into the hole where the spring pins are and work the black collar up and down. The twist mechanism on the handle will now work. My daughter claims it didn't even work that good when the stroller was brand new and we saved the time and trouble of shipping the entire stroller and seat system back to Georgia just to let the Graco people decide what to do. Bottom line is that this mechanism design stinks from the get go. Hope this helps.
Fold down
You can find product instructions for the Graco Cleo - and how to fold it - here: http://www.gracobaby.com/CustomerService/ProductInstructions/Pages/ByBrand.aspx?page=ProdInst&Subcategory=Lightweight%20Strollers&Model=G091158&CategoryName=Strollers
7helpful
2answers
Graco alano not folding? the push and twist handle not turning?? so the stroller does not collapse or fold. how can i get it to fold. wife needs to travel back and i am not sure airline would allow her if...
ANy adjustments to be made to make a 4 month baby sit in Graco trilogic car seat ?
The Graco Quattro Tour travel system is one of the most popular styles, thanks to the big basket, one-hand fold and nice parent tray. There are some downsides to this travel system, though. Most notably, the Quattro Tour stroller is big, whether folded or unfolded, and it's heavy to boot. Whether you choose the regular version or the Graco Quattro Tour Deluxe travel system, the included infant car seat will be a winner. Paying extra for the Deluxe buys you a higher weight range on the car seat, which means a longer useful time, but again, adds weight to the whole system.
Graco Quattro Tour Travel System FeaturesThe foundation of the Graco Quattro Tour travel system is the Quattro Tour stroller, a full-size model with an aluminum frame. It also has one-hand folding, a multi-position reclining seat (including fully reclined for infants), a drop-down basket that can be accessed even while the seat is reclined, and a sunshade that rotates to cover nearly any angle you need. The parent tray has two cupholders. The front tray also has a cupholder for baby, and it swings open for easier access with bigger toddlers. The regular version of the Graco Quattro Tour travel system comes with a Graco SnugRide infant car seat, which holds babies up to 22 lbs. and less than 29 inches. The Quattro Tour Deluxe travel system comes with a SnugRide 32, which holds babies up to 32 lbs. and 32 inches. The difference in car seats is the only real difference between the regular and deluxe versions of this travel system.
What I Like About the Graco Quattro Tour Travel SystemOf the infant car seats that come with travel systems today, both the Graco SnugRide and the SnugRide 32 are good choices. These car seats are fairly easy to use, and they install pretty easily in most vehicles. Some of Graco's less expensive travel systems include a SnugRide with a back-adjust harness, but the car seats included with the Quattro Tour travel systems are a front-adjust version, which is much easier to use properly. You can use both SnugRide seats without their bases, as well, which is a plus. The Quattro Tour stroller feels sturdy out of the box and has a respectable 50 lb. weight limit. The steering is OK for a stroller of its size and price - better than average for full-size travel system strollers.
The one-hand fold on the Quattro Tour stroller works well. You just have to twist the middle of the handle and let gravity help the stroller fold itself. Since you have to deliberately twist the handle, though, there's not much chance of the stroller collapsing accidentally as there would be if you just needed to push a button or lever.
The basket on the Quattro Tour stroller is big enough to fit a large purse or diaper bag. It also has a nifty drop-down feature so you can get into the basket even if the stroller seat is fully reclined (a common problem on full-size strollers).
The canopy is good-sized and rotates around to cover almost any position needed. It's easy to put the seat into the fully upright position, and I like that it reclines all the way, in case you don't want to use the infant car seat in the stroller all the time.
What I Don't Like About The Graco Quattro Tour Travel SystemThe Quattro Tour stroller is heavy. At more than 26 lbs., you may get pretty tired, literally, of lifting this stroller in and out of your trunk after a few weeks. It's not small in terms of dimensions, either. When the stroller is open, it's just over 24 inches wide, which doesn't leave a lot of clearance for narrower doorways. Some parents complain that the wheels, which stick out a bit from the frame, are easily caught on things in stores or in other tight spaces. When the Quattro Tour stroller is folded, it's smaller, but not by a lot. It measures nearly a foot and a half thick and about two feet by three feet, which means it will pretty well fill the trunk of the smallest cars. Though the steering is better than most full-size, lower-priced travel system strollers, it's still not great. Once you've added a heavy toddler (or a bigger infant plus the infant car seat and a diaper bag), the steering can be a bit balky.
While the folding mechanism is sleek, unfolding the stroller is awkward. Similarly, while the seat is easy to move up, it's harder to recline.
The biggest problem with the Graco Quattro Tour stroller is durability. While this model seems to have a better track record than many of Graco's travel system strollers, there are still plenty of parents who complain that their Quattro Tour stroller is creaking and wobbly after a year or so of constant use. This is probably not a stroller that will last through multiple children, and you likely will not recoup much money by reselling it later on.
Should You Buy A Graco Quattro Tour Travel System?The Graco Quattro Tour travel system is not a bad choice if you're set on a travel system already. Many of its downsides won't be answered by choosing another brand or even another of Graco's travel systems. If you have realistic expectations about a travel system in general, you may be very happy with the Graco Quattro Tour. The infant car seat is the most important part of the travel system, and you can't go wrong with the front-adjust SnugRide or the SnugRide 32. You should try out the car seat in your vehicle before you buy the travel system, if at all possible, just to be sure it's a good fit. If the car seat doesn't fit your vehicle, that would be one reason to choose a different travel system.
In the whole of the stroller world, the Quattro Tour stroller wouldn't be one of my first choices since it's heavy, bulky whether folded or unfolded, and doesn't have a great track record for durability. However, as far as travel system strollers go, those things are to be expected. The Quattro Tour stroller is above average on a few convenience features, though, so combined with the decent car seat, it's among the better ready-made travel systems available.
Plastic black piece close to back wheel broken. Is it a problem?
Hiya, Call their customer services on this number. They are very helpful. If it the bit that holds the basket up it is only £9.00. Hope this helps..0844 412 1212.
Attaching baby carrier to rear seat of Graco duo stroller.
It should latch onto the tray/bar and then there should be two red clips on the stroller that you click/lock onto the foot area of the seat.
Fold and lock stroller
2helpful
Packing Stokke Travel Bag with the Chassis - bassinet
Hope I can help you out with this...for me it was quite easy once you get the hang of how to fold the stroller system at the smallest possible fold. You have to have the seat at the lowest position, next you fold the front wheels inward so that it is flat against the stroller, then fold the handle all the down toward the stroller frame so that it is flat. NOW you have the stroller at the smallest fold. Remove the SEAT from the Stroller frame and place it on top of the stroller (FYI - the adjustable foot plate should still be attached to the SEAT and it fits directly ontop of the 2 metal pieces that protrude from the stroller that you normally instert the seat into)
NOW it will fit inside the Stokke Travel Bag.
1helpful
2answers
Hope this helped!
Mattie
2helpful
2answers
Graco Quattro Tour Duo Stroller won't fold up
I called customer service at Graco and explained the problem, asked for a fix. The rep said the part is not replaceable and told me to send the stroller back to them for 'evaluation and/or replacement'.  They will pay to FedEx it back to them this week. So that is where it stands.
Thank you very much for your site and offering a chance to put the problem out there.
Top Graco Baby Gear Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jay Finke
Jay Finke
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
