Question about Ximeta NDU10-80 80 GB Hard Drive
I had the NDU10-80 with the single click...
I'm sure i could start up from dvd but not sure what that would help since the computer it'self is fine. The drive appears as unformatted in my disk utility window and is attached via USB 2.0. I tried attaching it via ethernet at the router but since it's not formatted the ndas utility is not recognizing it.
    Genius:
  • 3,587 Answers
Ndas? what's that?
Posted on Mar 26, 2008
Have Logitech small speakers for computer. They are turned on and the volume is increased, but no sound. Any easy correction ? Thanks.
click start control panel administrive tools computer management device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
you might need to select stereo speakers
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there also if you have the right ones selected
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Aug 20, 2011 | Logitech Audio Players & Recorders
I have a stand alone teac CD burner and everytime i try and copy a CD it says soures drive not ready.
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
hope this helps
Aug 16, 2011 | Teac CD Copy Station CS-Single 12...
Acer dvd writer not read
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
also
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
Aug 01, 2011 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
I have octo edge samsung dvd writer.. it reads dvd's fine no problem.. but it burns dvd or cd. it stops burning between 10% to 15%. and shows input/output error.. then the DVD gets wasted.. Is There a...
make sure that the dvd rw is getting enough power test all leads that are attached to the dvd rw including electrical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
you might have to physically unplug the leads for this cdrw/dvd rom then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you will have options to update driver,roll back driver,or
if your computer came with a motherboard disc the drivers could be on it
your drivers may have been corrupted or you might have a virus run your antivrus program
hope this helps
Jun 18, 2011 | Samsung (TSH492BLACK) CD-RW/DVD-ROM Combo...
We have no sound cuming from the dvd
click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
May 31, 2011 | Samsung Televison & Video
Hello, I have a Sony DVD RW DW 28A That is rejecting any CD I put in. The DVD is working fine. Can you please help?
You can try with regedit
If your DVD drive is working fine, then it might be an issue within the OS itself
try these steps
  1. Click Start
    , type regedit in the Start Search box, and then click regedit in the Programs list.
    If you are prompted for an administrator password or confirmation, type your password, or click Continue.
  2. Locate, and then click the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
  3. In the right pane, right-click UpperFilters, and then click Delete.
  4. Click Yes to confirm the removal of the UpperFilters registry entry.
  5. In the right pane, right-click LowerFilters, and then click Delete.
  6. Click Yes to confirm the removal of the LowerFilters registry entry.
  7. Exit Registry Editor, and then restart the computer.
Aug 31, 2010 | Sony DW-Q28A (DW28Q) DVD±RW Dual...
Layout files not included in final formatting of dvd
#1
Insert your ( memory card , flash disk , cellphone , .... ) into your computer.
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
Nov 13, 2008 | Apple DVD Studio Pro 4 for Mac
DVD Drive isn't detected.
Yes this issue would be resolved with a simple step which i have provided below.
Click Start, click Run, type regedit and then click OK. Registry Editor starts.
In Registry Editor, expand My Computer, and then expand and open
HKEY_LOCAL_MACHINE>SYSTEM>CurrentControlSet>Control>Class
Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}
In the right pane (topic area), right click UpperFilter and delete the entry, also right click Lower Filter and delete the entry.
Close the Registry Editor and Restart the computer.
I am sure that this will work for you.
Please do rate the solution.
All The Best
Sammy
Oct 26, 2008 | Lenovo 3000 Y410 Notebook
My dvd burner disappear
Try this.
  1. Click Start, then Run, then enter REGEDIT to open the Registry Editor
  2. Navigate to the HKEY_LOCAL_MACHINE/SYSTEM/CurrentControlSet/Control/Class entry
  3. Under the Class entry, double click on {4D36E965-E325-11CE-BFC1-08002BE10318}
  4. In the right-hand pane, click ONCE to select the UpperFilters entry
  5. Make sure the UpperFilters entry is highlighted, press Delete, then Yes.
  6. In the right-hand pane, click ONCE to select the LowerFilters entry
  7. Make sure the LowerFilters entry is highlighted, press Delete, then Yes.
  8. Close the Registry Editor by clicking File, Exit.
  9. Reboot.
Mar 28, 2008 | Samsung (DSSM522452OEM) CD-RW Burner
Cd/dvd error
Go to device manager, find the optical drive, check properties for irregularities, then uninstall the device, reboot and let the system re-install it.
Also, do you have the dvd de-coder installed, as well as the right media for the drive?
Good luck
Oct 10, 2007 | HP Pavilion dv6000z Notebook
Ximeta NDU10-80 80 GB Hard Drive Logo
91 people viewed this question
Top Ximeta Computers & Internet Experts
John Bowen
Harry
Harry
Level 1 Expert
Dick Monti
Dick Monti
Are you a Ximeta Computer and Internet Expert? Answer questions, earn points and help others
