Question about Motorola Mobility RAZR V3
My inside screen!
My phone seems to have been ran over. The back of it is all dented in and has little gashes and punctures in it. However that is not the problem im concerened about. On the outside screen everything works just fine. It has my picture and time just like it normally did. But the inside screen is completely white and wont turn on. I can still make calls, go to anything on my menu, anything that I know from memory of what I could do before. The problem is that I cant see anything im doing. Since the screen is completely white, I have to guess from memory for what im doing. If you know the awnser to my problem please help me!
    Brigadier General:
  • 7,752 Answers
You can take the phone and have the mobile LCD screen replaced.
Posted on Mar 30, 2008
SOURCE:
Water leaking out front
Take the front door cover off use a Phillip screwdriver, screws are around the edge on the inside. Be careful the SS is pretty thin and you don't want to bend or dent it. What I found was a little rubber hose that connected to the top of the plastic air duct work and ran down back into the tub. This hose was restricted causing water to back up and then leak down the duct work on to the floor. Solution is to remove the hose from the plastic duct work,blow the hose out to remove the obstruction and reattach the hose.
Dec 10, 2011 | LG LDS4821ST Stainless Steel 24 in....
Fridge section doesnt work at all. lights and door alrm do. just wont get cold
some circuit problem in sensor, clean your ref first throughly inside and back. after that use it see what happen. be sure that the evaporator aluminum tube wire is not damage or punctured dent that may cause's a small hole led to leak the refrigerant.
Feb 02, 2011 | Whirlpool ER6AHKXPQ Top Freezer...
Driver side door inside panel
look behind handle for screw under a little plastic plate, same in side grip where you close door, maybe 1 more behind relector on door if equipped with one, then pull door slowly away, you will hear pops when doing this, it is ok. they are plastic screw kida things but they shouldnt break. if they fall out, you will need them to put door back on
Jun 25, 2009 | 1996 Oldsmobile Achieva
My lg voyager got ran over and you can barely see either screen
Assuming everything else still works, you can buy a replacement LCD screen on eBay for around $50 and install it yourself. The LCD screen comes with the front and inside screen.
Mar 31, 2009 | LG VOYAGER VX10000 Cellular Phone
Dent in Freezer
about the best that is going to hold in that moisture is jbweld then when it drys paint it white with touch up paint
Dec 30, 2008 | GE GSS20IEP Side by Side Refrigerator
Knife puncture inside my dishwasher on the top right.
You could clean the area very well, dry very well and use a waterproof caulk made for bathroom/showers (from kmart, walmart, etc) and carefully squirt and smooth (per directions) into the gap. Let dry per directions on caulk. This should last a while, but should be checked everynow and then to see if it's loose.
Nov 10, 2007 | Kenmore Elite 45986 Front Load Washer
Small dent on lens cover
Put a sticker over it or a little stripe or somthing. The cover looks like its connected on the inside of the front case. Contact sony maybe they will send you a little slony logo sticker? you know how their logo is little dots? maybe you can find one on e-bay or somthing. Stickers cover everything :P
Dec 11, 2005 | Sony DSC-T7 Digital Camera
Motorola Mobility RAZR V3 Logo
75 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
