Question about Sony KP-61V85 61" Rear Projection Television
Bad picture quality
I have a KP-61V85, the picture is not the same as when I bought it (get a wavy pattern, color is off)
Rather than going out and buying a new Big Screen I thought I would try to fix this one, I believe it is the lamps or lenses, How much does it cost to replace the lamps/lenses on these TV`s?
  • 2,326 Answers
You do not need to change the CRT's or lenses. The failure on this TV is the convergence ICs that became defective.
If you know how to solder, this should be an easy fix for you.
The IC markings are STK392-150 with locations IC1502, IC1506, mounted on a big heatsink(s).
If you want to change the complete assembly, you can check this link and ask them if they have the assembly where the STK392-150 ICs are mounted.
Good Luck.
Posted on Mar 26, 2008
Leakage in tuner
tuner may be bad, it is possible if rear inputs work to route signal to one of those inputs by using a box with the same type of connections the rear inputs have--bypass the tuner in the set with a box.
Dec 16, 2012 | Sony KP-61V85 61" Rear Projection...
How to change the brightes
A fairly old model is listed here(KP-61v85) this answer is based on that model number:
If the set has not been serviced for a long time with set unplugged remove rear cover and locate (hard to miss) the three large black lens at top of chassis--clean the lens with a lens cloth or a paper towel with glass cleaner sprayed on the towel.
If the lens are dusty/dirty they will diminish the brightness and clarity of the the picture---they are the light source for the picture in this set.
Apr 11, 2012 | Sony KP-61V85 61" Rear Projection...
I have a sony kp-61v85 color rear video projector and it has a red haze across the middle section of the screen like its out of focus. A tv repair man replaced 2 cv boxes and the picture got clearer and...
The tv have a problems is known as a convergence problems,it dead.The R,G,B colors lines mis alignment,have colors shadows or 3D pictures.The tv convergence board the 2 STK convergence ICS and some or all it resitors are dead.These parts on the tv convergence board,must be replaced to solved tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 12, 2010 | Sony KP-61V85 61" Rear Projection...
Picture is very red and slightly distorted
A very red picture is usually related to the Red CRT or red CRT drive board being defective. The convergence will only mess the alignment up and cause the picture to appear 3D it wont make the Picture take on alot of red tint.
Aug 28, 2009 | Sony KP-61V85 61" Rear Projection...
There are wavy colored lines an the screen all the
A problem like yours is NORMALLY NOT the TV set's's the Cable.
I'll bet you see thin lines moving across the entire picture...they are slanted like this >> \ \ \ \
That's generally caused by a bad ground on the antenna cable OR it can be the cable box's MODULATOR.
Try using your VIDEO OUTPUT off of your Cable box and see if the wavy lines are still present. If they are the Cable box needs swapped with a good unit.
You can also verify this problem by checking your TV with a DVD lines indicate the TV is fine.
If you have problems with the DVD player's picture, then you must have dried out filtering capacitors on the Video board IN the TV set...
And THAT is not an easy fix if you do see lines with your DVD player.
Mar 27, 2009 | Sony KP-51WS500 51" Rear Projection...
Wavy green lines when picture is black
Check out this site. These TV's are known for the CRT's going bad. This site shows how to make adjustments that could help extend the life of your set. Take a look at the first picture, if the lines look like the ones in the picture this site "should" help. The picture shows a problem with the red but don't worry about the color, look at the lines. I hope this helps.
Mar 22, 2009 | Sony KP-57HW40 57" Rear Projection...
2 separate colors on screen
sounds like your convergence IC's have finally gone bad.. they seem to last 5 years on average.. have a look here:
Dec 19, 2008 | Sony KP-53V75 53" Rear Projection...
I have a Sony KP-61v85 projection set that wyou help meon't turn on
4 blinks is error code in KP-61V85 and shows problem as follows...
IC1509(V out) is broken.
Q1505(V Pulse Buffer) is broken.
If you have no experience, don't put your hands in TV because TV has high voltage inside and electric shock risk involve.
Oct 12, 2008 | Sony KP-61V85 61" Rear Projection...
Herringbone pattern
Herringbone (and other patterns) can be caused my many faults, the obvious one the tech was looking for was a tuner/interference fault.
Another common cause is a faulty power supply.
Difficult to say without having the TV on the bench.
I'm a bit suspect about the $400 - $500 repair cost though.
Perhaps try another tech?
I doubt it's a DIY repair though.
Let's know how you get on.
Jan 20, 2008 | Sony KP-61V85 61" Rear Projection...
Sony KP-61V85 61" Rear Projection Television Logo
153 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
