Question about Epson Expression 1680 Professional Flatbed Scanner
Expression 1680 Professional Flatbed Scanner: Transparency adaptor stuck in open position. The h...
Transparency adaptor stuck in open position. The hinge is absolutely frozen. taping the small white plastic switch near the hinge didn't do a thing. What to do now?
Had the same problem. By lid I assume you mean transparency unit. To fix, it is necessary to remove the transparency unit from the scanner. Then IN A CLEAN AREA! with the glass side up unscrew the 6?screws that hold the top unit together. There will be a hinge assembly inside. You must remove it, clean it, and re grease it thoroughly. I used lithium grease from an aerosol can. Has not given me problem since. the whole process took about a half hour. just make sure you are gentle, and keep everything clean.
Posted on Dec 11, 2010
Had this same problem, the two screws (not the first six screws) that hold the top part of the scanner (lid? transparency unit?) to back of the hinge had worn through the plastic and there was no more leverage. We are getting rid of it. Time for an update anyway.
Posted on Dec 14, 2012
During preview and scan unit will freeze up and I have to restart the computer
try to just let it chill maybe its to hot wait about 10 minutes then try again
Apr 22, 2010 | Epson Expression 1680 Professional Flatbed...
Fuzzy scanned image from Epson Expression 10000XL scanner
Make sure that the item being scanned is lying flat against the scanner's glass. If the scanned image is still fuzzy after adjusting the object, clean the scanner glass with a lint-free cloth and some vinegar or ammonia-free window cleaner.
Hope this helps you. Please If this solutions solves you problem, please do not forget to rate my solution. If not, then please comment back so I can help some more
Apr 10, 2010 | Epson Scanner Expression 10000xl Pro A3+...
Lid will not close and is very difficult to put down
Feb 18, 2010 | Epson Expression 1680 Professional Flatbed...
SORRY MAY BE A BLONDE QUESTION
well now there's something i've never tried.... i would suppose you can but they will likely turn out like... well negatives
Robert
Feb 17, 2009 | Epson Expression 1680 Flatbed Scanner
Door/Hinge is very tight, have to push down hard when scanning
Remove the transparency unit from the scanner. Then carefully remove the six screws holding the hinge. Use WD 40 to lubricate hinge.
Jan 13, 2009 | Epson Expression 1680 Professional Flatbed...
Lines through negative scans
Clean the glass surface with Iso propyl alcohol (Industrial grade is enough). Dont use any solvent. Just for immediate usage, you can use your aftershave and clean. Clen with a soft cloth.
S. Mohan, Chennai. India
Nov 28, 2008 | Epson Expression 1680 Professional Flatbed...
Funky look to images
Hi folks. I am the originator and have the solution to the problem. I feel a little stupid because I overlooked using a plastic insert/guide which is placed on the scanner, fitting on notches. It lets the scanner know to use the transparency device and provides a notch for film holder placement. It has been so long time since I used film ever since digital photography took over, I overlooked using this plastic insert. With it placed, I can scan film fine. Thanks
Sep 30, 2008 | Epson Expression 1640XL Flatbed Scanner
Communication with scanner
You could take it apart and see if you can lubricate the shaft the the scanner sits on with some vasoline. If that doesn't it could be that the stepper motor that controls the scanner is going bad in it.
Jul 18, 2008 | Epson Expression 1680 Professional Flatbed...
Transparency adaptor won't close
Remove the transparency adaptor from the scanner bed (unscrew the two smaller screws, then slide back and off) and then remove the glass (and plastic frame) of the transparency adapter (there are six screws).
By the hinge there is a small white plastic switch. Usually the transparency adaptor hits this when it's closed, letting your computer know that it is ready to scan. What I did, as bcvideo did, was take duct tape and firmly taped the switch to the side of the transparency adaptor, using several small strips of tape.
The scanner works well now. You may need/want to put something on top of the scanner if it does not fully close.
Apr 08, 2008 | Epson Expression 1680 Professional Flatbed...
Epson Expression 1680 Professional Flatbed Scanner Logo
465 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
