Question about Belkin (F5D5231-4) Router
(F5D5231-4) Router: my belkin wireless having problem onnecting to the...
My belkin wireless having problem onnecting to the modem even though there is nothing wrong with the modem.what should i do now?
  • 2,263 Answers
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Posted on May 05, 2010
I can't get my Belkin G Wireless router to work with my Clear WiMax modem even after keying in the security key..is this router compatible with this modem?
Any router should work with any modem. Make sure you are running an ethernet cable from the WAN/Uplink port of the router to the modem, or in some cases it will be a USB cable. Also you can test your internet connection by plugging a computer directly into the modem.
Apr 04, 2012 | Belkin Computers & Internet
How do I hook up a router, I have wireless internet already
If you have wireless internet already, then go to Belkin's website. Most electronic devices nowadays have manuals in PDF format on their websites. Different router manufacturers usually has a different setup protocol for their devices.
Feb 28, 2011 | Belkin Basic Wireless Router
I have CenturyLink. I cannot get the Belkin router to work. What to do?
IF THE MODEM GIVEN BY CENTURY LINK is 660 Series then the IP Address of the Modem and Router Will be the same
So before starting the troubleshooting ... Disconnect the centurylink Modem from the Belkin
Step 1 : Connect One of your computer to the belkin ( to any one of the 4 grey ports ) with an ethernet (CAT 5 ) Cable
Step 2 : Open internet explorer
Step 3 : On the address bar type http://192.168.2.1 and press enter
Step 4 : If you are at the belkin Router Setup utility ..
Step 5 : On the Left under LAN Setup click LAN Settings
Step 6 : Leave the Password blank and click submit
Step 7 : Change the IP Address to 192.168.3.1
Step 8 : Click apply changes
Step 9 : Connect the Modem - Router ( to the yellow slot )
Step 10 : Check the color of the light in the Router
Step 11 : If it is solid green .. Check if you have internet
SETTING UP A WIRELESS NETWORK
Even though The router comes with a Pre-Set Wireless network many people wont like to use it
if you like to setup a connection
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Regards
TOM
Dec 26, 2010 | Belkin Wireless Surf Router (F7D2301)
Belkin Wireless router problem?
Hello
Sounds like you took all the right steps.In add and remove programs at the control panel,remove your wireless card drivers and anything related to it.
Be sure to write down your wep security key from your router first.
Then remove the card,reboot,put the card back in,then reinstall the drivers.
If this does not work the wireless card may be bad.
Hope this helps.
Apr 14, 2010 | Belkin Computers & Internet
Trying a add another desk top to an existing Belkin wireless G router at home. Right now there's a desk top and laptop working off this router.Try several times and still can't connect to internet.
Make sure the Belkin wireless is the only device directly connecting to your internet service provider's router/modem. Usually that port is labelled "WAN" or even "Internet". The Belkin should have extra ports/jacks for WIRED connections, right? You then connect the PC into the other remaining ports/jacks on the Belkin (if they're wired) or just use the wireless for the laptop if the laptop has wireless. After getting the wireless going, though, you should lock it down by using WPA encryption key if possible.
Feb 24, 2010 | Belkin (F5D7230-4) Router (587009)
Usb network adapter will not maintain connection even though I have good singal strength, 2 computers, 2 different adapters, same problem
Seems like you need to sync your modem and router. Disconnect the power to the modem and router. Then, first connect the modem and wait till all the lights are lit. then re-power your router. Restart your computers and you should be all set. Good luck
Aug 17, 2009 | Belkin (F5D7010) 802.11a, 802.11g/b...
Surfboard Cablemodem not communicating with Belkin Wireless Routr
If the modem is actually passing out DHCP, then you have to connect the modem to the router 4 port lan side and not the wan port. Give the router a static ip like 192.168.1.2 and you can talk to it and configure the wireless features.
Feb 17, 2009 | Arris SURFboard SBG900 Wireless Router...
Belkin n router with cox cable modem. just installed a wireless g belkin usb network adapter. when i go to set it up there is limited or no connectivity even though the signal is all lit up like a...
Double check the wireless settings of your belkin router, its should match with the wireelss settings of the computer most important is the wireless security key called a WEP or a WPA key...if you're not sure about that access the router setup page and there you can check all the wireless settings of the router..
Hope that helps..........
Aug 27, 2008 | Belkin Computers & Internet
Cannot finish installation (Belkin F5D8633-4 wireless modem router N mimo)
ok, obvious questions first:
Do you have a different modem from TALKTALK? can you connect to the internet through that?
if so, you may not have to set a username and password for the belkin router: just connect the belkin router's internet port to the talktalk modem and let the talktalk modem handle the automatic connection.
do you know what protocol the talktalk ISP uses?  it's probably PPPOE; make certain that your belkin router is set to the correct protocol.  if you just hook it up to the talktalk modem though, you probably won't have to specificy a protocol at all.
Mar 29, 2008 | Computers & Internet
Belkin (F5D5231-4) Router Logo
132 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
