Question about SmartDisk FireLite 40 GB Hard Drive
FireLite 40 GB Hard Drive: The usb port where you insert the cable on the har...
The usb port where you insert the cable on the hard drive came loose and fell into the hard drive. This wan not due to any wear and tear drops or mis use of the product. I attempted to connect the usb and the connector fell into the device. I have a lot of precious files on this hard drive and need to know if this can be fixed or if their is a cable that can go into the ext port on the hard drive that i can access on my computer
  • 416 Answers
1. the only way to know what breally has gone wrong is to open the enclosure & check. if the Ports has broken off fromm the PCB borad inside then ( if you are technically savvy) you can resolder it back. ( the disk has to be removed first) if not you have two option.
1. take a device to a repair shop.
2. buy a new enclosure & swap the disk
Posted on May 06, 2010
Need driver for SmartDisk FireLite 40 GB Hard Drive
I found drivers at this URL: http://www.xpdrivers.com/usb/smartdisk/_3_2585.cfm
You should go there and be able to find what you need for the 64-bit Vista OS.
Good luck,
-a.
May 26, 2012 | SmartDisk FireLite 40 GB Hard Drive
My external firelite model #USBFLB40, stop work today, i tried in other laptoop, and its work but after i disconnect, i want to used it again, and dosent work, ether my lap, nether the other lap... ...
1. It may be due to the electronics in the USB case.
You can purchase a new case and install the hard drive and connect to the USB port to your laptop/PC.
If the drive is not seen after this then the drive itself may be damaged.
If you disconnected the USB drive without "safely removing it in Windows it may have damaged the hard drive controller.
Mar 18, 2011 | SmartDisk FireLite 40 GB Hard Drive
My computer (Vista) does not recognize my Firelite 40 GB when plugged into the USB port.
try connecting to different usb port. if issue persist check if HDD it self has any issue. same can be checked by connecting it to any other computer.
Apr 12, 2010 | SmartDisk FireLite 40 GB Hard Drive
SmartDisk FireLite XPress 120 GB USB External Hard
Hola!!!
I have this external drive and the truth is that it is very good. But I have a s e doubt that the digital display does not turn me, and I do not know if it is broken or is it because only you connect the USB cable and did not put the current transformer 5Volts. I need someone to help me and tell me what has to be repudiation. Thank you very much!
My Email: @ gmail.com rodolfo.gomez1990
Mar 24, 2010 | SmartDisk FireLite® XPress 120 GB USB 2.0...
My 40gb smardisk firelite usb connector has broken loose. I have files that i would like to have. There is another ext switch next to usb what is that and is that another way to get my files what type...
The other connector on the USB Firelite is for external power if needed. You will need to buy another 2.5" hard drive enclosure and pull the drive from the firelite and put it in the new one to get the files. Before you buy a new one open the firelite and take the drive with you to verify if it is an ide or sata drive. This will determine the type of enclosure you need. You could also take it to a local computer store and have them back the data up to dvd, but this can get expensive. You can typically get a new 2.5" ide enclosure for under twenty dollars.
Jan 22, 2010 | SmartDisk FireLite 80 GB Hard Drive
USB Device Not Recognized...
try to the laptop firewire port, if works. I didnt find any support for youfirelite drive
Dec 29, 2009 | SmartDisk FireLite 40 GB Hard Drive
I plug my usb external hard drive into my laptop but it does not read. How can I fix it?
Have you tried changing which USB port it's hooked into. If not is there any cd (Drivers/Software) for your external / that it came with?
If not you might have to search for unrecognized hard ware. This will help with that: http://www.techmantras.com/content/finding-drivers-unrecognized-hardware-windows-system
Dec 23, 2009 | SmartDisk FireLite 40 GB Hard Drive
THE SMARTDISK 80 GB MODELUSBFLB80-C WILL NOT WORK WITH USB.THERE WASN'T A 5 VDC POWER ADAPTER. wHAT IS THE SPECS FOR THE 5 VDC APAPTER
Make sure you are connecting it to a usb 2.0 port. Usb 2.0 will supply the 5v power the device needs. also use the cable that came with the drive. some drives plug into 2 usb ports.
Nov 30, 2009 | SmartDisk FireLite 80 GB Hard Drive
Verbatim usb 160 external hard drive.
That model doesn't have an external power supply port.
May 26, 2008 | Verbatim 160GB USB FireLite: The "drive...
SmartDisk FireLite 40 GB Hard Drive Logo
120 people viewed this question
Top SmartDisk Computers & Internet Experts
Sunday Ojelabi
Sunday Ojelabi
 Ian Kayhan
Ian Kayhan
Are you a SmartDisk Computer and Internet Expert? Answer questions, earn points and help others
