yes, but you have to change the typewheel
if you don't have the user manual, can get it from here
http://www.manualslib.com/manual/455216/Nakajima-Ae-740.html#manual
turn it off, move the carrier by hand it should move fairly freely if it doesn't look for debris on the bottom of the T/W, Also spray a little WD40 on the silver shaft that the carrier slides on.
Check for debris inside T/W, put some WD40 on the silver shaft that the carrier rides on. If these fail check the wiring harness about 1" from carrier you may find broken wires there.
It sounds like a keyboard problem, maybe a spill, if so lit it sit on its side for a couple of days it may dry and heal itself, otherwise you will need a tech.
Go to the Nakajima distributor website at www.nadist.com/
Find your typewriter model and you'll see the instruction manual available in pdf format. Good quality and it's free.
