Question about Canon Pixma MP500 All-In-One InkJet Printer
Paper won't load - Canon Pixma MP500 All-In-One InkJet Printer
4 Suggested Answers
SOURCE: PAPER WON"T LOAD
The problem is software rather than mechanical operation. Uninstall the printer driver from the Add/Remove section of the Control Panel. Pull out the USB port and replace it back. This will prompt you pc to install the driver of the newly found hardware. Reinstall the printer driver. Should your printer be observed to have the usual problem, replace both cartridges with a one. "Loading paper" problem feedback is the same prompt as what you get when cartridges are old or refilled with unauthentic ink.
Posted on Feb 18, 2009
  • 8 Answers
SOURCE: My printer won't align new
Sorry to know you're in trouble with your printer. Here are my suggestions: You have to buy a new genuine cartridge or you can refill ink. Be warned! Refilling ink or using a refilled ink cartridges will not work until the ink cartridge chip or ink monitor is disabled. For instructions on how to disable an ink cartridge chip, please visit [http://www.ehow.com/how_6201242_disable-ink-cartridge-chip.html]Now you can CURSE the manufacturer of your printer for making your life sucks by making it complicated the things that should be made SIMPLE and EASY. Printer or Cartridge, more or less, cost you the same. Don't you think the printer cartridges should be made simply refillable/usable unless they are broken, and we should be buying only the ink for the cartridges. It is SO ANNOYING, dude! Good luck.
Posted on May 07, 2011
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: Lexmark 5495. No paper jam.
    Here are some tips on how to use the feeder: - Use paper that is in good condition. - Fan the paper before loading into the feeder to avoid sticking together. - Make sure the paper don't buckle when loading into the feeder. - Avoid overloading.
    Posted on Aug 11, 2011
    Won't load paper
    Clean the paper feed with alcohol and a paper towel by rubbing and rotating the drum. Wait for it to dry completely then it should grab the paper. Also make sure paper is free from dust. Good luck!
    Jan 25, 2013 | Kodak EasyShare Photo Printer 500
    My verifone vx510 won't print
    Receipt Feeds,
    But Nothing Is
    Printed On It Not using thermal paper. Ensure thermal paper is being used. Thermal paper loaded upside down. Ensure thermal paper is being fed from underneath the roll, as it will only print on one side of the paper.
    Aug 05, 2012 | VeriFone (M19755014US1) Magnetic Card...
    Lexmark X4530 won't load paper to copy
    Leading cause of paper jams is debris / foreign objects that accidentally fell into the paper feed area. Please try this approach to fix the problem:
    1. Remove the sheets of paper from the feeder.
    2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
    3. If you're willing and physically able, you may also carefully turn the printer over. Any debris should just freely roll out from the feeder.
    4. If feeder is clear, place the printer on the table. Open the printer cover and remove the cartridges.
    5. Check the cartridge area for any obstructions in the paper path.
    6. Close the printer cover.
    7. Re-brick your printer by pulling out the power supply - the black box where the power cord is plugged into. Re-plug after 30 seconds.
    8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again to verify that the problem is fixed.
    Mar 16, 2012 | Lexmark Office Equipment & Supplies
    Lexmark 5495. No paper jam. Gears just spin. Won't grab paper. Paper properly in loading position.
    Aug 11, 2011 | Lexmark X5495 Printer
    I have a paper jam many pieces went through the printer and won't budge. I don't see a way to get to where the paper is stuck
    Unplug the printer from the power source to turn it off. Open the printer cover to access the cartridge area. If you see the paper jam, slowly and carefully pull the paper out of the printer. Avoid tearing the paper or avoid leaving torn pieces in the printer. This will cause future paper jams in the printer.
    When all is clear, re-plug the printer into the power source. Load some paper and try to print again.
    Jul 24, 2011 | Lexmark X2600 InkJet Printer
    I have a Lexmark x2600 printer and when I stated printing many pieces went through and then jammed and won't move in either direction, the paper is really jammed in and I don't see any way to get...
    Tips: Use only paper that is in good condition. Fan the paper before loading into the feeder to prevent sticking together. Use the specified media type and sizes for your model. Don't overload the feeder.
    My Epson 1290 (some years old) doesn't grab paper, especially good inkjet paper) properly. It passes straight through, prints on the roller, and/or I get messages saying the paper isn't loaded properly or...
    That could be from the rubber rollers not being able to grip the paper. They get polished or shiney over time with use and age. Then they slip or pull incorrectly and you get your problems. There are other things that can cause this but nothing worth fixing.
    Fixing the rubber rollers is easy. You need some ispropyl rubbing alcohol and a paper towel. Make sure it is isopropyl type as this won;t attack other parts. Simpley wet the paper towel and wipe down the rubber rollers. You will see the rubber go from a dull shine to dull flat rubber. This takes off the buildup on the rubber and lets it grip again. Eventually the rubber will age harden and this trick won;t work but this can give you years more service.
    Apr 20, 2010 | Epson Stylus Photo 1290 InkJet Printer
    PAPER WON"T LOAD
    Feb 03, 2009 | Canon PIXMA iP1600 Printer
    Canon Pixma MP500 All-In-One InkJet Printer Logo
    178 people viewed this question
    old marine
    old marine
