Fan control does not work and no air being blown out.
I replaced the fan blower controller but the blower still does not work.
Does this mean the expensive route of a new fan moter? c5 auto aircon 2003
  • 674 Answers
Is this a window unit? Is there a capacitor for the fan motor? If there is and you haven't replaced it, that might be the problem.
Posted on May 05, 2010
Why is fan control stuck on 4?
A mechanical fan/blower control that's stuck on 4 is a worn/faulty switch. The blower motor fuse could be blown or the blower motor is dead. A electronic fan/blower control that's stuck on 4 with no blower could be a blown fuse in your fuse box, the blower motor is dead or the climate control reading itself could be sending a false reading or the unit tself iis faulty.
Sep 18, 2015 | Subaru Impreza Cars & Trucks
Suzuki x4 2009 fan does not spin but when I turn air on it blows cold air.
Not sure which fan you mean. Engine cooling fan is different from heat/air blower fan.
Feb 04, 2015 | Suzuki Cars & Trucks
Why does my mercedes c180 '98' only blow air through air vents when i drive the fan does not work? How do I locate problem?
Check the blower circuit breaker, the blower control fuse, the blower relay, and the blower itself. If the blower does not work on any speed, you will likely find that the control fuse has blown.
May 13, 2014 | 1998 Mercedes-Benz C-Class
Air does not blow
The car normally blows air through the blower however the controls and settings of the speed of the blower are controlled by the blower motor resistor. The resistor controls the speed of the blower fan. If your blower still works on the highest setting then the blower itself is still in working order. If you are not getting any air at all, even on the highest setting, then chances are the blower has gone bad, blown fuse or open wire. If this does not help please give us more information to work with.
Aug 12, 2012 | 2002 Buick Century
My bmw 318 is blower fan not working
Blown Fuse
  • Usually the first thing to inspect when the blower fan stops working is the fuses to see if any are blown. Locate the 10A cluster fuse or the 25A HVAC fuse in your car manual, and examine them to determine if they need replacing. The car owner's manual will tell you where to find the fuses that are connected to the heat and/or air conditioning. On the interior fuse panel of the car, a 30 amp fuse is labeled "Heater" or "HVAC."
Bad Blower MotorIf the fan only works on setting number 3 or 4, or just on the highest setting, it is most likely that your blower motor is failing and is about to die. Use a voltmeter to test the amount of voltage at the blower motor connector with your ignition on and AC running. If it reads 12V, the motor needs replacing.Automatic Climate Control SystemAnother thing that causes the blower fan to malfunction is the Automatic Climate Control System (ACCS). If the ACCS's settings are off, it may cause the fan to stop working. If it is the climate control on the car, typically it is a bad thermostat or electrical circuit that is the culprit.
hope this helps, James Booth
May 17, 2011 | 1996 BMW 318
Fan is not working even i use air condition or heater no air coming out and i don't know which one to replace?
First check the fuse for the heater/ac fan. If the fuse is OK, you probably need a new blower motor. If the fuse is blown, replace it. If it blows again, you could have short in the heat/ac control computer, or the blower motor may still be bad. In this vehicle, the blower motor is probably less expensive to replace than the controller, and you can test the blower once it is disconnected by applying battery voltage to it (observe correct polarity). If it does not move when jumped directly to the battery, it is almost certainly bad.
Dec 20, 2009 | 2003 Acura 3.2TL
Why does my blower motor for my 97 silverado does not work?
Check for a blown fuse,
Check for faulty blower motor speed control resistor pack - (usually located in the air flow in the blower ducting),
Check the blower motor is ok; ensure it runs if power directly applied to it.
Check blower motor fan control switch is ok.
Oct 07, 2009 | 1999 Chevrolet Silverado 1500
1998 durango blower not working blower not working for air or heater
Check the blower motor fuse to see if it is blown,and look for a blower motor relay,and check it to see if it is good.Then if you must,run a hot wire from a 12 volt power source to see if the blower will run,if not .or if it runs slow ,replace it.If the fan runs good,look at the blower control switch to be bad,replace it.
Aug 21, 2009 | 1998 Dodge Durango
A/c fans wont blow
If the fuse is blown for the blower then there is a short, that is not an answer, go to the blower and check to see that the blower motor connector has 12 volts to it when the blower is set to high speed on control, if it does then u need a new blower motor, if it doesn't then the control switch is defective or the blower motor speed control resistor is defective.
May 13, 2009 | 2000 Mercedes-Benz S-Class
98 honda accord A/c panel lights went off. Now only blower works.
you are going to need to replace the climate control panel...
Apr 05, 2009 | 1998 Honda Accord
Heating & Cooling Logo
88 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
