Question about GE GSL25JFPBS Side by Side Refrigerator
Kenmore refrigerator - water line
I have purchassed a new Kenmore refrigerator. I used the old water line from the old refrigerator and I hooked the plastic tube from the back as instructed. It seems that there is not enough water pressure and this is coming very slow from the dispenser. I just found inside the refrigerator a big plastic tube that is attached to the inside, but I do not know if this is linked to the water line or it is just plastic tube provided by the store. There is no mention of it in the manual and i am wondering if this tube affects the pressure or I need to call a technician to change the water line.
Thanks,
  • 117 Answers
Just like my kenmore
Thats normal with some ref
Posted on May 11, 2008
SOURCE:
Hi my Kenmore side by side refrigerator is hooked up to the "Hot" water line, by the previous home owners. I want to switch to the cold water line. Not sure how.. and what I need to do this. Thank you
This is normally done with what is called a saddle valve. They are available at hardware stores, plumbing shops and places like Lowes, Home Depot, etc. However these are used on metal pipe.
If you have plastic pipe you will have to use a different method.
Check these videos.
. how to install water tap for icemaker YouTube
Sep 11, 2014 | Refrigerators
I just bought a used kenmore elite side by side refrigerator and hooked up the water line to the back of the fridge. My question is where does the long water line the goes to the fridge and comes back...
Where you hook the house water line is to the water inlet valve which is a one in two out solonoid controlled valve. One side goes to the water dispenser in the door and the other hooks to the ice maker connection.
So I suspect the long water line you are talking about has had the lines switched at the valve and needs reversed. The long line probably goes up the back of the unit and connects to the ice maker. The one for the water dispenser should hook to the water chiller resevoir and then to the water dispenser.
Sep 14, 2011 | Kenmore Side by Side Refrigerator
HOOK UP OF ICE MAKER TO THE WATER LINE
What you have in the back is a 1/4 tube which will feed cold water to the icemaker.
go to any hardware store and ask for an icemaker supply line kit. It will consist of a tapping valve, about ten feet of 1/4 inch tubing and a straight connector.
it will also contain step by step instructions.
You will have to determine what cold water line to tap into that is accessable. Perhaps the kitchen sink cold water supply if it is on the same wall as the refrigerator. Many times the line is run up from the basement.
enjoy your new icemaker.
May 21, 2009 | Kenmore 57029 Side by Side Refrigerator
Kenmore refrigerator Model No. 106.56839600 water dispenser
Hi
The water is kept cool in reservoir in the fridg. Remove the inlet tube push for water check pressure better worse? Work your way back to valve
good luck
Apr 12, 2017 | Kenmore 21.7 cu. ft. Side-by-Side...
Kenmore elite refrigerator water dispensor not working
If you just got this unit, did you purchase it new? Or if it's uner a year old then you should call sera for service under the war. Also, when you first start the unit water has to go through the water tank and it takes 3 - 5 mins before the water starts to work when first hooked up, then should be ok after that. There are several things that can cause the problem. Could have a kinked line in the ref, a bad water valve or even a frozen water tank. Also, did the water ever work since you had it?
Nov 23, 2008 | Kenmore 73503 Stainless Steel Bottom...
Kenmore ice maker
yes you need to hook up a line froun the cold water supply of the house to the water valve that is located at the back of the ref to the water valve that is down at the botton right corner
follow the water line from the top going into the icemaker down to the bottom there is where the valve is located behind the back cover
Apr 11, 2008 | Refrigerators
Water and ice
you must hook up a water line to the bottom right rear of unit then push dispenser to purge air from lines, icemaker may need a day or two to purge itself before making ice.
Mar 13, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore refrigerator leaking at water filter
I am having the same problem, it leaks with a filter and without a filter, I even tried making it really really tight. What else could it be?
Dec 08, 2007 | Kenmore 53642 / 53644 Side by Side...
GE GSL25JFPBS Side by Side Refrigerator Logo
241 people viewed this question
Top Refrigerators Experts
Brad Goodale
Matt Sicignano
Level 1 Expert
JP Meneide
JP Meneide
