Question about Lofra MXD96MFEPI Dual Fuel (Electric and Gas) Kitchen Range
Max 160 degrees celcius
My Lofra oven only heats up to a maximum of 160 degrees when the top temp is 240 degrees. How can it be fixed?
Waiting for your response in anticipation.
Kind regards,
Jen
  • Lofra Master
  • 43,501 Answers
If your electricMax 160 degrees celcius - 2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on May 06, 2010
Lofra LEF9EGP electric oven stopped working - fuse?
You probably had the heating element burn out. Disconnect it and test for continuity. If open, replace it.
murf427
Aug 01, 2012 | Kitchen Ranges
VAUXHALL MERIVA COOLING FAN
Change the relay, situated in a black plastic box up in front of the battery. Costs about 7 pounds / 11 dollars USD on ebay and takes 30 seconds to do. Until you get it fixed, protect the engine when temp get over, say, 90 degrees celcius, by opening up your side dash vents, turn the in-car fan on max and the temp up to max. The hot air will go directly out the windows and you will see the temp gauge drop back to about 80 degrees. I did this for a year until I figured out the relay needed replacing.
Jun 28, 2012 | Cars & Trucks
WHAT IS THE MAX TEMPERATURE THIS MODEL CAN SUSTAIN NN-CS599S LET SAY I WANT HEAT THE SUBSTANCE FOR 300 CELCIUS FOR 10 MINUTES..HOWEVER THE OWEN REACH THE SET TEMP AT FIRST 5 MINUTES....IS IT THE OVEN CONT...
I do not know of ANY microwave that will get you anywhere near 300 celcius, the cavity thermals are rated around 110.F and even the mag limit thermal of the comercial units are 300F No where near the celcius temps you are talkig about.
Sep 15, 2017 | Panasonic NN-SN657S Microwave Oven
MODEL E23GT-F 240 VOLT SHARP M/W
Hello there
this is tbirdfan1 here is a pict of the megatron for you
Apr 29, 2010 | Sharp R-22GT Microwave Oven
Lofra five burner gas cooker, oven door not closing properly,
It sounds like you need to check the fixing screws of the oven,failing this replace the hinges.
I hope this helps.
Jul 07, 2009 | Lofra MXD96MFEPI Dual Fuel (Electric and...
Stuck at 288 degrees
NO PARTS REQUIRED!!! DON'T PAY FOR A SERVICE CALL!!!
After a power outage, my wife's grandmother said she could no longer set her over to 300, 400, 450, whatever..
I went over to troubleshoot.
I couldn't figure out why everything seemed functional and why I couldn't set the over to higher than 288 (and thought, that's a rather odd number)... until I realized that that 288 degrees C = 550 degrees F which is the max the oven can do.
The power outage reset the computed back to celcius instead of fahrenheit.
Save them a ton of money... cause this could have been an easy cash grab to some cook out there.
May 01, 2009 | Kenmore Kitchen Ranges
Oven will not heat past 300 degrees
300 far. or cels if its celcius its to high they should run at about 260 or the high temp sensor will shut it down how fast is your belt running it should be 6.30 to 7.00
Jan 28, 2009 | Lincoln Conveyor Oven - 1133-000-A
Oven will not heat to right temp
you can calibrate you oven try presiing and holding the bake button for 3-5 secs. it should beep and put a 00 in the display. using the temp up or down arrows you should be able to adjust ther temp to a max of 35 degrees + or -. after setting to desird 25 presss start and that setting will be ingrained in the memory forever(or until you change it again)power failure will not effect it either . of that doesnt work gimme the modle and ill ck further
Mar 08, 2008 | Ovens
Fan Oven blows Fuse over 175 Celcius -Baumatic BT2760SS
Hi, I was cooking and my oven jut went off, looked in fuse mains box and had tripped. So put back on and now the fan works but no heat...Can you give me some idea what it mite be.
Sep 18, 2007 | Ovens
Lofra MXD96MFEPI Dual Fuel (Electric and Gas) Kitchen Range Logo
369 people viewed this question
Top Lofra Kitchen Ranges Experts
Paul Carew
ray gallant
Are you a Lofra Kitchen Range Expert? Answer questions, earn points and help others
