Question about Whirlpool Duet GHW9150P Front Load Washer
This code keeps coming up on my washer
I put in a load to wash it appears to be washing and when I come back in to check it says 5d what does this mean?
  • 2 more comments
  • lbychick Mar 27, 2008
    Thanks for your help
  • arcirod Apr 08, 2008
    I had an error 5d today.  using He detergent and no it does not say suds.
  • Anonymous Apr 09, 2008
    washer says f21, then 5d, is empty now, starts to add water then stops, we have unplugged ect...
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    Are you sure the error code is "5d"? Or, could it be "Sud"? The reason I ask, is that I cannot find a "5d" error code for a Whirlpool Duet.
  • 5,911 Answers
Thanks, wilbur 24 for the input.
If this is a Suds error, then you will need to run the washer on a Rinse & Spin cycle with no detergent added to get rid of any excess soap. NOTE: You may have to repeat this cycle several times in order to clear the error.
Are you currently using HE detergent? If not, it is strongly recommended that you do. HE rated washers are supposed to use HE detergents because they are formulated for wash tubs that only use 5-7 gallons of water (like yours). If you use regular detergents you are, in affect, adding a higher concentration of soap that is formulated for wash tubs that have a 35 gallon capacity. This can cause damage to the tub and pump seals. Most manufacturers now have a disclaimer that states that the warranty becomes null and void if it is doscovered that you have used the wrong detergent.
In addition, some HE detergents are DOUBLE-CONCENTRATED, which means you only use HALF the amount you normally use. Make sure you read the label carefully to ensure you aren't inadvertently adding too much detergent.
Some other things that can cause over-sudsing include washing too little clothing with too much soap and soft water. Its best to wash full loads with front loaders as they are rated for large capacities. Cut back on the amount of detergent when washing smaller loads. Soft water can make detergents work better and create excessive suds. Try using less detergent.
I hope I don't insult your intelligence. I'm just trying to give you some sound advice in the event that you are not aware of some of the common causes of this problem. I hope this helps you.
Posted on Mar 27, 2008
I am having the same problem with my washer. It says 5d, there is no space in between for a "U" (suds). My washer also takes an hour and a half to wash a regular load of laundry. It just started doing this. We purchased our washer and dryer about 10 months ago. Never had a problem before this.
Posted on Jul 27, 2008
  • 185 Answers
There is a 5d its a suds lock overdose of detergent detected during the wash cycle
SOURCE:
5d code
5d is suds warning. The motor is being overworked from too much suds caused by improper measurements or detergent or both.
Cabrio service manual is on my service manual page
Run your washer without detergent a few times. Remember this washer uses less water than a normal washer it has 2 pumps. one recirculates a small amount of water over them clothes. You go adding in a regular amount of clothes and that washer fancy electronics gonna have a cow.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 13, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
What does 5d mean when it comes up on front load whirlpool duet
5d is: It denotes suds lock (overdose of detergent dectected during the wash cycle).
Chances are you just put too much detergent in, or maybe the wrong detergent - make sure you're using the HE detergent.
These codes and more details are printed on the service technician diagnostic manual that is affixed to the inside of the washer's front panel.
Unplug your washer, and unscrew the three 1/4" socket screws at the bottom of the washer. The manual should be taped to the back of the panel, and the code and some recommended procedures will be right inside.
Jun 01, 2010 | Kenmore Elite 45986 Front Load Washer
Code 5d comes on and it stops running
5d means the follow; possible causes * If too much detergent was used -Run the unit thrugh a RING/SPIN cycle. -Run a NORMAL cycle with out adding detergent. PROCEDURE * This should clear the unit of execess detergent. 1.- Check the draing hose and male sre it is not plugged or ****. 2 Unplug washer or disconnect power. 3.-Check wires harness connections to the drain pump, pressure switch, and center Cotrol Unit (CCU). 4.- Check/clean drain pump filter of foreign objects. 5-Plug in washer or reconect power. 6.- Check draing pump. 7.- Check the pressure switch. 8.- Verify CCU operation bu running a Diagnostic Test or any cycle. "Was this helpful?"
May 11, 2009 | Kenmore HE2 Plus Front Load Washer
Code 5d
its a water senser error code check for loose wire bottom front of outer tub ,i have never had a bad one "less soap plz"
Nov 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Maytag Neptune Frontloading Washer
5d is actually Sd, which means too many suds. Make sure you're using "he" types of laundry detergent.
Jun 14, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Error code 5d???
sure it's not sud? if so may be oversudsingbe sure you are using an he detergent if you are and suds are and issue try cuting back on detergent
May 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet sport
5d is: suds lock (overdose of detergent dectected during the wash cycle).
Whirlpool Duet GHW9150P Front Load Washer Logo
179 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
