Question about HP Office Equipment & Supplies
Print cartridge error (electrical failed pen) hp 4480
mdsaeed67
  • 849 Answers
SOURCE: Print Cartridge Alignment Failure
two option:-
1. cartridge is not proper. or
2. not proper installed.
Posted on Nov 29, 2008
  • 35 Answers
SOURCE: My HP 4480 stopped printing with the message.
the printer hade may be dammage or the cartidge not set correctly
Posted on Jun 14, 2010
lock123
  • 6831 Answers
SOURCE: how to remove printer cartridge from 4480 hp
Hello
You will be able to get step by step instructions o replacing the ink cartridge at the link below.
Click HERE to navigate to the page.
kind regards
Andrea
Posted on Aug 14, 2010
  • 385 Answers
SOURCE: My HP Deskjet F 4480
sounds like the alignment is off. try alignment adjustment from the utilities options
Posted on Sep 07, 2010
Testimonial: "Thanks!"
  • 1751 Answers
SOURCE: On a HP Deskjet 4480 all-in-one, I'm getting
Hi
try from printers menu to alligne printheads
If i help you pls vote me
Posted on Nov 02, 2010
Hp 4480 how do you unpause it
The HP F4480 likely has a malfunctioning ink cartridge which is causing the printer hang (i.e. internal micro-electronics damage inside the HP 60 color or black ink cartridge). You can verify the electrical condition of both HP 60 ink cartridges by activating the Tap 41 diagnostic test report (see video here for complete instructions):
http://inkjet411.com/?page_id=440 (HP 60 - Deskjet F2400/F4400/F4500 models)
    1.While holding the Power button, press Cancel (X) button 4 times, then press the Color Copy button once.
    2.Release the Power button.
    3.The 'Tap 41' diagnostic test print should print.
    Providing the color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health). A good HP 60/60XL color cartridge should display 1248 good nozzles, while a good HP 60/60XL black ink cartridge should show 336 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to 2nd video on how to read the printout.
    http://inkjet411.com/?page_id=444 (HP 60 - Deskjet F4200 model)
    If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink.
    For additional support please visit http://www.inkjet411.com
    -Thank you
Dec 09, 2013 | HP F4480 All-In-One Printer
Oxc18a0206
In most cases when the HP02 cartridge is not recognized, or has poor connectivity, you will normally receive an "Unrecognized Cartridge" or "Cartridge Problem" error message with a big RED X; in most cases (like 99.3%) the smart chip needs to be replaced with a new one - please note the chip life has 25 month expiration window from the time the HP02 (or 363 in the UK) cartridge is initially installed into the printer. Click here for more information when using refilled ink cartridges or general printing problems using any HP02 ink cartridge: http://inkjet411.com/?page_id=1372
If you observe an INK SYSTEM FAILURE message or 'Oxc' error message then the permanent PRINTHEAD may be electrically damaged (unfortunately it is not replaceable; you can verify this by performing the following):
To bypass INK SYSTEM FAILURE message please see the HP Printer Diagnostics Tests file (pdf) for instructions: http://inkjet411.com/?page_id=1813
Verify the permanent built-in PRINTHEADs electrical performance inside this legacy printer model by running the TAP 43 diagnostic test (either one of the procedures below applies to all printers which use HP02 or HP363 ink cartridges): For additional HP02 support information, please visit our HP02 system support page which includes videos of everything mentioned below: http://inkjet411.com/?page_id=1372
A.HP02 ink-series printers with KEYPAD (i.e. keypad numbers 1-9)
Tap 43 PRINTHEAD Health Diagnostics:
Video Procedure: http://inkjet411.com/?page_id=2391
    1.Press * and # keys simultaneously.
    2. "Enter Special Key Combo" will be displayed.
    3.Press 123 to display the 'Support/Service' menu.
    4.At 'Support/Service' menu, click the Right Arrow 3 times until Special Reports menu is displayed.
    5.Select Ok, then click Right Arrow 2 times until the 'print-mech button tap' menu is displayed.
    6.Select Ok ('code = 0' will be displayed); click and hold Right Arrow until 'code = 43' is displayed. Use the Left Arrow if you need to decrease numerical count.
    7.Select Ok. The test page prints.
    8.Check the 4th line at the top of the printed report; an electrically good/stable PRINTHEAD 'Pen Status' will state "Pen Status: Pen OK".........if any other message is displayed then the PRINTHEAD may have failed and may need to be replaced (if part is still available). It is suggested to perform the 'Printer Reset' procedure below to first rule out printer firmware related problem.
    B.HP02 ink-series printer models that DO NOT HAVE a KEYPAD:
    Internal Test Print:
    1. Press the Menu button, press the Right Arrow button to select 'Tools', and then press 'OK'.
    2. Press the Right Arrow button several times to select 'Print Test Page', and then press 'OK'. The test page prints.
    Tap 43 PRINTHEAD Health Diagnostics - See Video Procedure: http://inkjet411.com/?page_id=2377
    1. Turn ON the printer.
    2. Press and Hold the "Print Photos" & "Red Eye Removal" buttons.
    3. Release both buttons.
    4. You will see a new screen that says, "Enter Special Key Combo"... The Key combo is: press and release in sequence the "Red Eye Removal", "Print Photos", and then "Red Eye Removal"
    5. Scroll through the menu by pressing the right arrow button until the display says 'Special Reports'.
    6. Select Ok, then press the arrow button until the 'print-mech button tap' menu is displayed.
    7. Select Ok ('code = 0' will be displayed); click and hold Right Arrow until 'code = 43' is displayed.
    8. Select Ok. The test page prints.
    9. Check the 4th line at the top of the printed report; an electrically good/stable PRINTHEAD 'Pen Status' will state "Pen Status: Pen OK".........if any other message is displayed then the PRINTHEAD may have failed (unfortunately the PRINTHEAD is not replaceable). It is suggested to perform the 'Printer Reset' procedure below to first rule out printer firmware related problem.
    NOTE: Costco USA/Canada, Fry's Electronic's, Microelectronics (along with some Best Buy stores in Canada) provide a top-notch refilling/chip re-programming service today...check it out:
    http://www.costcoinkjetrefill.com/pricing
    For additional and advanced HP printer diagnostics, please visit: http://inkjet411.com/?page_id=1813
    To help solve other HP02 ink-series printer/printing related issues please visit http://www.inkjet411.com
Aug 12, 2013 | HP Photosmart C5180 All-In-One InkJet...
Printer Photosmart 8450. Using HP black cartridge. Received message saying the printer did not recognize the cartridge because it was not HP. Removed it and tried several times to print. Gave up and...
Regarding your HP94 black ink cartridge error problem and inability to print to your HP PS 8450 printer, this type of problem is probably an internal micro-electronic failure inside the HP94 ink cartridge.
To determine which cartridge is causing the issue and/or to confirm an electrical problem with one of the ink cartridges (or possibly both), perform both the Internal Self-Test page along with the Pen Electrical tests (diagnostics) to evaluate the electrical condition of both ink cartridges....
Please first verify the age of the ink cartridge(s)....look at imprinted date on front (or back) of ink cartridge. If this 'warranty expiration date' has expired, then potential cartridge failures can occur due to internal corrosion, etc.
A. Ensure BOTH carriage/flex cables and BOTH ink cartridge contacts are thoroughly clean before proceeding: http://inkjet411.com/?page_id=1519
B. Print Self-Test Page:
1. Press CANCEL and SAVE simultaneously (SAVE is the left-most button before POWER on/off.)
2. Using left/right arrow keys, navigate to 'pen electrical test'.
3. Select Enter to print test - evaluate nozzle test pattern.
-- If the printer prints the self test page then this demonstrates the printer is generally functional and that the problem is likely with one of the ink cartridges. Please note this is a 'forced' service test...the printer will attempt to print the test page whether the cartridges are good or bad. If the Self-Test page can be successfully printed but regular/normal printing cannot, then one of the ink cartridges is likely internally damaged. Remove and replace suspect cartridge to confirm.
C. Perform Cartridge Diagnostics tests using either C.1 or C.2 procedure below (varies by printer model):
C.1. Tap 41/43 Diagnostics Test:
1. To enter the Manufacturing Tests menu, press the 3 small, round buttons on the front panel simultaneously for >5secs: 'OK', 'CANCEL', & 'SELECT PHOTOS' (or 'Print Photos')
2. Using left/right arrow keys, navigate to Special Reports (or System Menu). Select Enter.
3. Navigate to 'print-mech button tap' menu.
4. Select Ok ('code = 0' will be displayed); click and hold Right Arrow until 'code = 41' (or attempt 'code = 43' if nothing prints using '41') is displayed.
5. Select Ok. Within one minute the Tap 41 (or 43) diagnostic test pattern should be initiated and print. Refer to video to help evaluate test pattern. Refer to 2nd video for guidance on how to read the diagnostic test pattern: http://inkjet411.com/?page_id=1741
NOTE 1: A good HP 93/95/97/99 color cartridge should display 600 good nozzles, while a good HP 92/94/96/98 black ink cartridge should show 672 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. For reference only, refer to the following HP Deskjet video which shows how to read the HP 93-97 ink cartridge diagnostic test print: http://inkjet411.com/?page_id=1741 (see 2nd video)
C.2. Pen Electrical / Error Bypass Procedure:
2. Using left/right arrow keys, navigate to Reports Menu (or System Menu). Select 'pen electrical test'.
3. Select Level 1, 2, or 3. Enter to print test - evaluate nozzle electrical test print.
NOTE 2: Pen recovery level 1, 2 or 3 clears cartridge errors, unblocking the printer to permit you to print the TEST PAGE with the normal MENU / TOOLS /PRINT TEST PAGE choice to aid in printer evaluation.
NOTE 3: Cartridge Error Bypass Message (Emergency Printing only): The Pen Recovery Level 1 clears cartridge errors and permits you to print the TEST PAGE with the normal MENU / TOOLS / PRINT TEST PAGE choice.
For additional information on North American ink refill services at a major retailer near you (should you wish to save ~50% on ink costs), general printing problem resolutions or advanced HP printer diagnosis procedures (error bypass/printer reset methods, etc.), please visit Inkjet411:
Aug 03, 2013 | HP Photosmart 8450 InkJet Printer
Had ink refilled at costco and now printer has an air message that says incompatable ink cartridge
The 'incompatible cartridge' error message is not a common error message associated with the Photosmart C5180 printer model - in most cases when the HP02 cartridge is not recognized, or has poor connectivity, you will normally receive an "Unrecognized Cartridge" or "Cartridge Problem" error message with a big RED X; in most cases (like 99.3%) the smart chip needs to be replaced with a new one - please note the chip life has 25 month expiration window from the time the cartridge is initially installed into the printer. Costco and Fry's Electronic's provide this top-notch refilling/programming service today.
I suggest you also verify the permanent built-in PRINTHEAD performance inside this legacy printer model (either one of the procedures below applies to all printers which use HP02 or HP363 ink cartridges): For additional HP02 support information, please visit our HP02 system support page which includes videos of everything mentioned below: http://inkjet411.com/?page_id=1372
A. HP02 ink-series printers with KEYPAD (i.e. keypad numbers 1-9)
1. Press * and # keys simultaneously.
3. Press 123 to display the 'Support/Service' menu.
4. At 'Support/Service' menu, click the Right Arrow 3 times until Special Reports menu is displayed.
5. Select Ok, then click Right Arrow 2 times until the 'print-mech button tap' menu is displayed.
6. Select Ok ('code = 0' will be displayed); click and hold Right Arrow until 'code = 43' is displayed. Use the Left Arrow if you need to decrease numerical count.
7. Select Ok. The test page prints.
8. Check the 4th line at the top of the printed report; an electrically good/stable PRINTHEAD 'Pen Status' will state "Pen Status: Pen OK".........if any other message is displayed then the PRINTHEAD may have failed and may need to be replaced (if part is still available). It is suggested to perform the 'Printer Reset' procedure below to first rule out printer firmware related problem.
B. HP02 ink-series printer models that DO NOT HAVE a KEYPAD:
Jun 17, 2013 | HP Photosmart C5180 All-In-One InkJet...
How do i fix a printer documentation, error oxc19a0021
If you observe an INK SYSTEM FAILURE message then the permanent PRINTHEAD may be electrically damaged (unfortunately it is not replaceable; you can verify this by performing the following):
May 20, 2013 | HP Photosmart C5180 All-In-One InkJet...
Get error oxc 18a0001, when I turn on Hp Photosmat c5180 all in o
THAT 0X ERROR IS AN INK SYTEM FAILURE IT MAY HAVE BEEN CAUSED FROM THE REFURBED CARTRIDGES... THE HP WILL WORK WITH THE REFURBS FOR A FEW TIMES BEFORE REJECTING THE CARTRIDGE OR CAUSING AN 0x ERROR. THE UNIT NEEDS TO GO THRU AN ELABORATE INK SYSTEM RESET. OR HAVE THE PRINTER REPLACED
Mar 29, 2010 | HP Photosmart C5180 All-In-One InkJet...
Screen showing the message "remove and check right cartridge". Have done this several times and still can't print
I've had the same error:
Hold down the following keys:
Photosmart Express, Photo Fix, Reprints, Print Photos and then Help.
You'll get the message: "Enter Special Key Combo"
Press OK.
Scroll over to Reports then self test: and press ok, it should print. a selftest report.
If you get an error Pen in Chute 1, or 2, has tsr failure: Call/Chat with an HP technician.
Jan 19, 2010 | HP Photosmart C4180 All-In-One InkJet...
C-4480 error message cartridge jams after
please make sure you no pieces of paper left inside the printer the restart it
Oct 18, 2009 | HP Photosmart C4480 All-In-One InkJet...
Ink System Failure HP C5180
-------solution 1---------
HP C5180
Hidden tech menu For resetting and repair, FIX UIAUX
Fixes error 0xc18a0507 error ink system fail
press <left arrow> then press <setup> button together
then press <ok>once support R0631m comes on screen
right arrow 2 times to the System configuration menu
then <ok>
then <ok> to select and ok to confirm reset error.
then <cancel> to escape ( all of witch are onscreen instructions.)
presto restart and no further error
http://www.thecomshack.com/hpc7180.htm
------------- solution 2 ----------------------------------
HP C5180 All-In-One Printer HARD RESET:
Hold down HELP + OK button and unplug printer
Hold down HELP + OK button again as you plug the printer back in.
Then power it on, if it doesn’t power on automatically.
Be Safe: keep holding the buttons until the printer turns itself off. (It took mine less than a minute.)
Now you can release the buttons and simply power it back on.
I got an error message about “improper shut down” since I unplugged it w/out powering down. After I clicked “OK” the printer was just fine and didn’t mind anymore. And now I can print.
Dec 04, 2008 | HP Photosmart C5180 All-In-One InkJet...
916 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
