Question about Belinea 10 15 36 15" LCD Monitor
Resolution notice it says the best picture quality change to resalition to 1024x768 1 exit 2 disable how do i get rid of it
  • 1,606 Answers
LCD monitors have what is called a native resolution. This is what the actual/physical display resolution is. When you try to display outside of this then you get the error. The easiest way to get rid of this is to set you video display resolution to the native monitor resolution.
If you look at the message it is saying if you hit 2 it will disable the error. To change the resolution in windows you can just right click anywhere on the desktop that is empty. This brings up the display properties. Go to the settings tab. At the lower left is a slider. Just slide it to show the desired display size in your case try the 1024x768 setting then hit apply. The screen will change and a nother window should pop up and ask if you want to keep the settings. If you take too long or say no it just resets to the prior settings. You can change it at any time.
1024x768 is a good setting it is high enough that the display is clean and sharp. And most web pages are designed around this size. Try it not only to get rid of the error but also to see what everything looks like. You can always change it back.
Posted on May 05, 2010
  • Leona Arsenault
    Leona Arsenault Jan 09, 2013
    I have a similar problem using windows 7, I am trying to open a program that keeps giving me the message that I need to have resolution 1024x768 or higer. I already have 1280x1024 , but that does not fix the problem. any ideas? thanks
Resolution notice for best picsture quality change resolution to 1440 *900
Perform a right click on your background wallpaper. Select "Screen resolution". Set resolution to 1440 x 900 and click apply.
Aug 25, 2011 | Computers & Internet
I am using a Fujifilm FinePix JX250 digital camera. Not the best I know to photograph jewelry but cannot afford a different camera now. After I've taken the picture I open it in IPhoto. I make...
The following will help to get the best possible pictures from your Fujifilm FinePix JX250:
TO CHANGE FILE SIZE:
  1. Press MENU/OK to display the shooting menu.
  2. Press the Selector UP or DOWN to highlight the option IMAGE SIZE and press the selector RIGHT to change IMAGE SIZE to 14M. This setting has a image resolution of 4,288x3,216.
  3. Press MENU/OK to select the highlighted option.
  4. Press DISP/BACK to exit from the menu.
TO CHANGE QUALITY:
  2. Press the Selector UP or DOWN to highlight the option IMAGE QUALITY and press the selector RIGHT to change IMAGE QUALITY to FINE (Less compression than NORMAL, meaning better picture quality).
NOTE: The focus range of the JX250 goes from 1.5 ft. - Infinity (Wide Angle), 2.6 ft. - Infinity (Telephoto), also make sure to clean the lens and adjust the focus before taking the photos. If the subject is close to the camera, select Macro mode. If the subject is far away from the camera, cancel Macro mode.
May 28, 2011 | Cameras
Hanns-g JC199d monitor displays 2 messages periodically
install an AGP card into an AGP slot because internal display card does not support high resolution because of insufficient memory . use 8X AGP card for better result . then you can see high resolution ,3D games ,and movies .
Apr 17, 2010 | Hannspree HANNS·G JC199DP LCD Monitor 19...
How to disable the resolution notice on VG930m
Use your monitor buttons to look for Resolution Notice and turn it off.
To disable the notice on ViewSonic 23" LCD Monitor , use the buttons on the
front of the montior to do the following:
* Press #1 button
* Use down arrow to highlight Setup Menu and press #2 button
* Use down arrow to highlight Resolution notice and press #2 button
* Select Disable and exit!!
To disable the notice on NEC LCD 1765 monitor
* Press button #5 on the monitor
* Scroll up and down the menu list with Montior Button #4 and then select
with Monitor Button #5. Go to "Advanced menu" set the Resolution notice to
OFF.
Nov 02, 2009 | ViewSonic Computers & Internet
Viewsonic monitor
Pixel Ratio is just a parameter Measured to Produce Good Quality Display with Fine details so Do not Mix up with Resolution and Pixel ratio.
Use the Resolution that best sutes the Application you use(which may change with time to time based on applications you use)
Keep a standard Resolution 1024 x768,or which ever suits your Vision.
NViiDiA is a Grafix card and Monitor features are 2 differnt thigs so.
Dont be concerned about the Parameters and get mixed up.
just find the best possible Resolution and enjoy your Monitor with best Quality, :)
Jul 17, 2008 | ViewSonic VX924 19" LCD Monitor
Blue Resolution Box
To turn off the reminder, use the buttons on the front of the monitor to do the following:- Press #1. Use down arrow to highlight Setup Menu and press #2. Use down arrow to highlight Resolution Notice and press #2. Select Disable and Exit.
Aug 13, 2007 | ViewSonic VX2235wm LCD Monitor
S 5i Question: What are the best settings for quick pics
Hi: Let's go by parts... :) You want to print your photos in 8 x 10 inches without bluring some areas on the picture... in Europe we talk about centimeters. It's something like 20 x 25 centimeters. If you want the picture to be with the best quality for printing, then you have to set your image resolution in, at least, 300 dpi (dots per inch) - this you have to do with software, like Adobe Photoshop CS2. For you to change the resolution of your picture to print with that size without losing any quality, you have to have a picture with, at least, 3000 x 2400 pixels. So, it's better for you to take pictures with the highest quality in your camera, 2560 x 1920, and still you loose some detail. When you have a picture with the resolution 1024 x 768 taken by any normal camera, you will get a resolution of 72 dpi (the same resolution that pictures in the Internet or monitors have. When you print it at your size, 8 x 10 inches, the computer or the printer, one of them is going to change the resolution of your pictures. That process is called "interpolation" and it means that some pixels are generated with middle colors. It's dificult for me to explain the process without showing images but I think that if your search through Google engine you will find lost of pages talking about it... maybe one day I can post in my site about that subject ;) If you have any question about what I tryed to explain just post again ;) Regards
Aug 30, 2005 | Pentax Optio S5i Digital Camera
My pictures are not the quality I expected. What can I do?
Use the Quality setting on your camera to select a picture resolution. To change the quality setting: Press the Menu button. Select Picture Quality, and then press the OK button. Select the Picture Quality setting you want to use, and then press the OK button. Press the Menu button to exit the menu. NOTE: The setting remains until you change it.
Aug 29, 2005 | Kodak EasyShare CX7530 Digital Camera
Pictures are not the quality I expected
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Belinea 10 15 36 15" LCD Monitor Logo
227 people viewed this question
Top Belinea Computers & Internet Experts
David Payne
David Payne
Are you a Belinea Computer and Internet Expert? Answer questions, earn points and help others
