Question about Kenmore Elite 45986 Front Load Washer
No matter what the temp setting is at it only has very hot water
We have a Kenmore elite he3 washer and no matter what the temp. setting is set to it only puts out very hot water. My first thought was the mixing valve is stuck but it seems that if it was the valve it would not put out any water if the setting was on cold. Any ideas???
    Problem Solver:
  • 19 Answers
Your water temp is determined by 2 things. First the hook up to your water supply. If you are able to turn off the hot water valve that feeds the unit and then select a cold water only wash, do you get cold water?? If not then someone hooked up the hoses to 2 hot water feeds. If hot and cold feeds are installed right, the second thing is your computer which monitors the incoming temp through the boards atc control and a thermister. If you select cold, and only get a hum and the cold water valve is on, you may have to clean the screens in the valve of any sediment. If no hum, and no cold, dead solenoid on valve, but that would throw an error code usually. All fills are monitored by the board and usually begin with a hot/wrm mix and then changeover to a monitored cold temp , about 70 degrees.
Posted on May 05, 2010
How do I repair my dryer?
Hi Is two sample resolution:
1 the out taken pipe is clog
2 the limit cycle sensor is broken
Clean pipe disconnect from dryer, open back dryer cover exchange the sensor.
Oct 15, 2014 | Kenmore Elite HE3 Steam 8676 Dryer
Why does my Kenmore Elite HE3 fill with water when it's off
The water valves are leaking usually from grit in the seat of the valve. They are a pair and can be easily replaced.
Aug 03, 2014 | Kenmore HE3 Steam 7.2 cu. ft. Super...
Kenmore Elite HE3 does not work with Pure Wash system
One of the things to try is get a Y connector for the machine. Hook both ends of the Y to the washer at the hot and cold, then connect the last part to the pure wash. The HF error is HOT FLOW so it is not seeing any hot water pressure. The actual temperature should not be an issue. Also if you have too much water pressure you wont see the bubbles. If that happens just start turning down the cold water valve on the connection to the pure water unit until you see bubbles in the viewing window. I ams sceptical about these machines because you have to reduce the surface tension of water in order for it to clean, that is partly the job of heated water and laundry soap. Also if there is an ozone generator in that unit, there is a consumable part because ozone needs electrolysis to be generated. I cant help but wonder where the hydrogen goes when it is generated.
Feb 26, 2014 | Kenmore Elite Washing Machines
No hot water comming out. Both water valves open. Doesn't matter which temp switch is on still comes out cold.
Remove the top & unplug the harness from the hot water side of the valve and with a meter check for 120v at plug. If you have voltage replace water inlet valve, if thers is not 120v at plug at valve replace control board
Dec 22, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore elite he3.on spin cycle makes lots of noise like a motor mount broke.
It could be that you are not setting the water level high enough when you do large loads.also the strap that holds the cement block could have come undone and now the block is unsecure.
Jul 18, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore HE 3.8 washer has only hot water even with cold settings
If the washer fills very slowly when you have it on a cold setting the cold water may be shut off behind you washer or possibly the hot and cold are switched. if that is not the problem then you have a relay problem with the machines electrical system.
Jul 01, 2009 | Kenmore Washing Machines
Kenmore HE3 will not hold water leaks into the pedestal
run you fingers into the door boot and inspect for holes ,, that probably what it is ,,,,,,big tear
Dec 30, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3 washer keeps filling with water
The inlet valve will need to be replaced. Its a fairly simple procedure and a pretty inexpensive part.
Nov 15, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3 will only wash with hot water, need help!
yes hot water is best in washer /oil and grease will remove.
Nov 06, 2007 | Kenmore 44832 Front Load Washer
set the washer to fill. open the lid and depress the lid switch. might be in the rear of the cover or on the side. watch to see where the water level comes to. once the tub is filled, the water height switch operates the timer motor for the different cycles.
Sep 10, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
209 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
