Question about Vga (CAT5-9000I) (EXTCAT59000I)
Wich pin is video and witch one is audio on a vga
Witch pin is video and witch one is audio on a vga port
Hi i am looking for vga cable 9 Pin Female to 15 Pin Female thanks
The 9-pin port on your PC tower is NOT a video port, it is a serial data port. All VGA connectors are 15-pin. Hooking up to the 9-pin port will not get you a picture. There should be a VGA port on the PC, or else a DVI an/or HDMI port. You can get DVI-to-VGA adapters that work, but only if the DVI port is an analog DVI, not if it is a digital DVI (DVI-D or DVI-DD).
Feb 02, 2016 | LG Computers & Internet
Behringer mx8000
is your supply gone ? difficult. check inside, you can see what leads feed what regulators, I hope. However, hard to build a supply with all them voltages... get a new one, I suggest. Luck...
Mar 26, 2014 | Audio Players & Recorders
How do I connect my Laptop Acer 5735 to my TV Sony KDL-40NX700, what kind of connection cables do I require?
If Your TV and Laptop have HDMI Port then you just need a HDMI Cable.
But if you dont have HDMI port. then you need two cables one from video and one for audio.
For Video you either VGA Cable(if you have VGA Port in your TV) or VGA to RCA Cable (Yellow Pin will be for video)
For audio You Need 3.5mm pin to RCA (white and Red for audio).
This pic is of VGA to RCA Cable
Sep 10, 2011 | Acer Aspire 5735 Notebook
Can't figure out how to connect pc to video component to my Acer laptop
You shouldn't be using video component cables, instead you should be using a VGA cable and a 1/8". stereo audio cable. Your laptop and your TV should have a VGA port; it is D-shaped and has 15 pins over 3 rows. Next to your TV's VGA port should be an audio jack that you can hook up to your laptop's headphone jack. The cables be be bought at Radio Shack or any decent electronics/computer store.
Jul 19, 2011 | Televison & Video
Hi I recently bought a Biostar A880G+ motherboard which supports VGA, HDMI and DVI video outputs. I cannot get a second monitor to run on this board. The only output wich seems active is the VGA?
The manual says
  • NOTE: The HDMI and DVI-D ports both can provide digital video signals output function, but these two interfaces cannot work at the same time. The chipset uses the same channel to control HDMI and DVI-D, so these ports cannot transmit video signal to different display panels simultaneously.
so you should be able to use one of them as well as the VGA. Maybe you need to change something in the BIOS settings? I don't have this motherboard myself, just found the manual online at
http://www.biostar.com.tw/upload/Manual/A88PC-M3S%20&%20A88GC-M3S_100519_B.zip
Apr 20, 2011 | Biostar A880G+ AMD 880G Socket AM3 mATX...
How do i connect my pc to my LG 32LF77SO I CAN GET SOUND AND VISION
Most HDTVs today have a 15-pin VGA input so to hookup a PC, just connect a VGA monitor cable from the PC monitor output to the HDTV VGA input port. This gives you video. For audio, you can connect a stereo audio cable (3.5mm) from the PC soundcard speaker jack (usually green) to the HDTVs audio input port next to the VGA port. Next you need to adjust the settings for video resolution and refresh rate on the PC so that the HDTV is compatible. Look in the HDTVs owner's manual for a chart showing the acceptable video screen resolutions (1024 X 768) and refresh rates and adjust the PC accordingly. You should now have video and audio on the TV. For a laptop, it depends on what outputs it has, VGA, HDMI or S-Video but this can be done as well.
Mar 26, 2011 | LG Televison & Video
I have a Dell computer that runs Windows Vista and I want to hook it up to use my TV as a monitor to watch a webcast. Please advise.
The first step is to inspect both your laptop and TV and identify the connections, easily located on the back of either component. There are five basic types of jacks, or ports involved:
*Composite/phono plug (RCA)
*S-Video
*Video graphics array (VGA)
*Digital video interface (DVI)
*High-definition multimedia interface (HDMI)
*An RCA connector, sometimes called a phono connector, is used for analog audio and video components. Three round, colored sockets are standard — left audio is white, right audio is red, and composite video is yellow. These are standard jacks on older TV’s and laptops. A three-prong cable, readily available at any computer or electronics, is the easiest way to make an RCA laptop to TV connection.
*S-Video, or Super-Video, a more advanced analog video connector, uses a four-prong round plug, like those used in TV cable installations. Separate audio cables are the same as for the RCA connector, left audio/white, and right audio/red. S-Video is commonly found on older TV sets and some laptops.
With S-Video on both TV and laptop, connecting a laptop to a TV is a simple matter of a single S-Video cable. If your laptop has a great sound system, you won’t need audio cables, but for better quality you’ll also want audio cables.
RCA to S-Video cable, a special laptop to TV cable, is available when you have RCA jacks on one device and an S-Video port on the other.
*A VGA connector and cable are used to carry analog video signals plus display and graphics data. The VGA is a 15-pin connector commonly found on laptops and other devices. With this port you need a PC-to-TV Convertor to connect laptop to TV. You simply plug the VGA cable from the source into the convertor, and use an S-Video or RCA cable out to the TV. The converter is USB powered, so there’s no external power adapter to carry around, making this laptop to TV connection entirely portable.
*A DVI port is rectangular with 24 pins arranged in three horizontal rows of eight pins for digital video; separate RCA analog audio cables fit into white and red plugs. DVI ports are found on Macintosh laptops; sometimes they are smaller than normal DVI ports and require an adapter, which usually comes with the laptop.
*The HDMI port, one-half the size of the DVI port, is also rectangular with 19 pins. It provides digital audio in addition to digital video, despite it’s smaller size, for a complete TV to laptop connection. These ports are found on new HDTVs, and sometimes there are two or more. TVs with HDMI ports are the only ones that do not require additional audio cables.
TV’s with a single digital port labeled HDMI/DVI require only one cable when the source is another HDMI component. But when source is a DVI laptop, you need a DVI-to-HDMI cable for the video and a separate pair of RCA analog stereo cables.
NOTE: Whenever ports do not match, you can by adaptors and/or cables to make any connection.
NEED MOre HELP check this link for video :
http://www.online-tech-tips.com/computer-tips/how-to-connect-your-laptoppccomputer-to-your-tv/
Jan 20, 2010 | Computers & Internet
What cable do I need to connect latitude D600 to a hdtv ?
*S-Video
Nov 22, 2009 | Dell Latitude D600 Notebook
Dell Inspiron 2200 to Phillips 47 " TV
check this out http://answers.google.com/answers/threadview/id/762913.html *A VGA connector and cable are used to carry analog video signals plus display and graphics data. The VGA is a 15-pin connector commonly found on laptops and other devices. With this port you need a PC-to-TV Convertor to connect laptop to TV. You simply plug the VGA cable from the source into the convertor, and use an S-Video or RCA cable out to the TV. The converter is USB powered, so there’s no external power adapter to carry around, making this laptop to TV connection entirely portable. you will need a seperate audio cable unless you are going to use your laptop's speakers
Feb 04, 2009 | Toshiba Tecra M1 Notebook
I don't know the parts of the motherboard.
What motherboard would you like to know the layout of? Although, many motherboards are different, most of them have the same basic parts. From back to front, you have the communication ports; (usually from top to bottom, varies by manufacturer)mouse/keyboard, usb 1.0/1.1/2.0(make and model dependant) serial, paralell, vga/monitor, then sound: midi, headphone/speaker out, line out, microphone in.
then on the board, processor, somewhere near it, cache, i/o chip, north bride chip, wich is responsable for memory(ram) access, ide(cd rom/ hard drive access) ports and power connector/s,
memory slots
then the south bridge chip witch controls isa port(old), pci slot, agp/pci-e slot (video card) along with the cmos battery, bios, and various other slots/connectors (such as fan, power button and so on) and chips, wich vary by manufacturer and model.
Dec 27, 2007 | Computers & Internet
Computers & Internet Logo
32 people viewed this question
Top Vga Computers & Internet Experts
Tony
mukhtar21 shaikh
mukhtar21 shaikh
John Hong
John Hong
Are you a Vga Computer and Internet Expert? Answer questions, earn points and help others
