Question about Dishwashers
Indesit dishwasher wont come on
Power supply ok on indesit dif04 dishwasher but on/off button will not come on.no lights-nothing. checked fuse box thats ok. unplugged dishwasher, changed fuse and still no life in it.
This might be a little late but i ahve the same problem, an indesit engineer has been and there ia a metal bar the control wires rub against when opening/shutting the door. major design fault if you ask me. it tripped my entire kitchen and extention out.
Posted on Nov 09, 2010
Dishwasher will not turn on, no lights, power source ok
Unit is Dead, No Lights, No OPS Some units will have thermal fuse of some sort in the wiring before the control. If this fuse is open, no power will get to the control or display. Before checking this fuse, make sure the correct voltage is present at the junction box for the dishwasher. If all is OK, you have a control or keypad issue FAULTY.God bless youff922825-6f57-4ac4-a46d-9ed3b3fedd7b.gif
Apr 02, 2013 | KitchenAid 24 in. KUDI02IRBS Stainless...
Getting no power to Kenmore Quiet Guard 587-16163401
Of course, theck the power supply the dishwasher is plugged into. The next place to check is the junction box on the bottom of the dishwasher, behind the toe kick panel. If everything is okay there, then it is probably the thermal fuse located inside the door, attached to the dishwasher controller. If you need a new thermal fuse, you can check SearsPartsDirect.com, RepairClinic.com, EasyApplianceParts.com, or AppliancePartsPros.com.
Aug 16, 2012 | Kenmore Dishwashers
No power to dishwasher
Start by checking for loose or melted wires under the dishwasher underneath in the "junction box". if the wires arent melted and the plice is ok. then you may need to look for the thermal fuse by the control board. make sure your breaker isnt tripped. go and turn it all the way off then back on.
Nov 28, 2008 | Dishwashers
Our bosch dishwasher is not working, when we press the button to turn on nothing happens, no lights, nothing, we have checked the fuse and thats ok. many thanks gail
you may have to turn off power at main box, and check wires at bottom of machine and any other junction box , from dishwasher to main power box. pull on wires to see if they will come apart.
Oct 30, 2008 | Bosch Dishwashers
Indesit IDL 530 Dishwasher
Switch off, turn off power, turn off water, disconnect water inlet hose, check for blockages, remove filters, clean filters, refit filters, check water supply, reconnect water supply, reconnect power, turn on - problem solved.
Apr 12, 2008 | Indesit Dishwashers
Indesit DIF04 integrated dishwasher
Dishwashers normally are hot or cold feed.
My wife runs water at the sink to get it hot going in before turning on the dishwasher.
You can use either cold or hot water.
We have ours hooked up to the hot water side.
They work better hooked up to the hot water.
Mar 21, 2008 | Dishwashers
INDESIT DW S 60
check and make sure the door switch is activating
Jan 03, 2008 | Indesit 23 in. DV62 IX Built-in Dishwasher
Indesit D167. When cycle selected no water pumping or filling but 1 & 2 green indicators on.
Tilt your dishwasher forwards. Be aware that water will come out ouf the bottom. Once this is clear your washer should be Ok.
Good Luck
Sep 23, 2007 | Indesit 24 in. DI67 Free-standing...
Dishwashers Logo
832 people viewed this question
Top Dishwashers Experts
